Windows 10
gkontoletas
trouble in my brain
Περισσότερα για τη δυνατότητα αναβάθμισης σε Windows 10.
Θα μπορεί να γίνει αναβάθμιση σε λειτουργικό σύστημα που δεν είναι αυθεντικό, μετά την αναβάθμιση σε Windows 10 δεν θα γίνεται αυθεντικό.
The consumer free upgrade offer for Windows 10 applies to qualified new and existing devices running Windows 7, Windows 8.1 and Windows Phone 8.1. Some editions are excluded from the consumer free upgrade — including Windows 7 Enterprise, Windows 8/8.1 Enterprise, and Windows RT/RT 8.1. Active Software Assurance customers in volume licensing have the benefit to upgrade to other Windows 10 enterprise offerings.
We have always been committed to ensuring that customers have the best Windows experience possible. With Windows 10, although non-Genuine PCs may be able to upgrade to Windows 10, the upgrade will not change the genuine state of the license. Non-Genuine Windows is not published by Microsoft. It is not properly licensed, or supported by Microsoft or a trusted partner. If a device was considered non-genuine or mislicensed prior to the upgrade, that device will continue to be considered non-genuine or mislicensed after the upgrade. According to industry experts, use of pirated software, including Non-Genuine Windows, results in a higher risk of malware, fraud (identity theft, credit card theft, etc), public exposure of your personal information, and a higher risk for poor performance or feature malfunctions.
http://www.polygon.com/2015/3/18/8252373/windows-10-free-upgrade-pirates
gkontoletas
trouble in my brain
Spartan και IE11 θα συνυπάρχουν στα Windows 10, o Spartan θα είναι ο βασικός browser και ο IE11 για λόγους συμβατότητας κυρίως σε εταιρικά περιβάλλοντα.
However, based on strong feedback from our Windows Insiders and customers, today we’re announcing that on Windows 10, Project Spartan will host our new engine exclusively. Internet Explorer 11 will remain fundamentally unchanged from Windows 8.1, continuing to host the legacy engine exclusively.
http://blogs.msdn.com/b/ie/archive/...m-the-project-spartan-developer-workshop.aspx
gkontoletas
trouble in my brain
Η επίσημη ονομασία του Project Spartan είναι Microsoft Edge, το ανακοίνωσε ο Belfiore στο Build 2015.
gkontoletas
trouble in my brain
Windows 10 Insider Preview Build 10074
Hi everyone from the Build 2015 conference happening right now in San Francisco! If you haven’t already, check out Terry’s blog post about all the Windows 10 announcements we made today. If you’re at Build this week or at Ignite in Chicago next week – keep your eye out for me and say hello!
Today we have a new build available to both the Fast and Slow ring for Windows Insiders (that means we’ll have ISOs available too for those of you who like a clean install.) With this build we continue to evolve the features and design for Windows 10, and you’ll see a lot of subtle changes and improvements, many of which were influenced directly by Windows Insiders. One of those changes is the reintroduction of some Aero Glass elements in the UI, but there are many more things throughout the product as well. We continue to use your feedback directly day to day in how our feature teams operate, and we hope that Windows 10 will be the best version of Windows yet because you had a direct hand in its creation.
One other subtle change that you’ll notice is that we’ve changed how we talk about the builds from “Technical Preview” to “Insider Preview” to reflect the importance of the Windows Insider community in how we’re building Windows 10.
http://blogs.windows.com/bloggingwi...10-insider-preview-build-10074-now-available/
gkontoletas
trouble in my brain
Windows 10, DirectX 12 and 4 Titan X
όσοι έχουν κάρτες γραφικών με nVidia GPU μπορούν να δοκιμάσουν τον οδηγό GeForce 352.63 beta για Windows 10, υποστηρίζονται μόνο οι σειρές 900, 700 και 600.
lakiss51
Ντεν καταλαβα ντιπ:) Δηλ ενω εχω τα 8.1 πειρατικα θα μου επιτρεψουν να τα αναβαθμισω σε 10., μα παλι θα ειναι πειρατικα. Και βεβαιως αφου θα ξερουν ποιος ειμαι εγω ο ¨κακος¨πειρατης θα μου τα "κλεισουν" οποτε γουσταρουν - ή μηπως κατι...χειροτερο -πχ κανα προστιματακι;
lakiss51
Ψιτ..υποθετικα μιλαμε;)
Κι ομως, ειμαι βερος Γουιντιανος απο τοτε που τα πουλουσε 29€:):):)
Γιώργο θα καταργήσουμε το SLI ή Crossfire bridge?
DirectX 12 will remove the 4 + 4 = 4 idea and will work with a new frame rendering method called SFR, which stands for Split Frame Rendering. Developers will be able to manually, or automatically, divide the texture and geometry data between the GPUs, and all of the GPUs can then work together to work on each frame. Each GPU will then work on a specific portion of the screen, with the number of portions being equivalent to the number of GPUs installed.
http://www.tomshardware.com/news/microsoft-directx12-amd-nvidia,28606.html
SFR / AFR / SLIAA κάνουμε και τώρα
gkontoletas
trouble in my brain
πολλά θ' αλλάξουν με το DirectX 12...
στην επερχόμενη gamescom θα δούμε αρκετά νέα κόλπα
Tasos Tsekouras
