m1ts0s
News poster
Εξαιρετική ιδέα, δεν το είχα σκεφτεί ποτέ με αυτή την οπτική.it is not comparing audio systems using human hearing, but human memory.
Έντεχνη καταστρατήγηση της επιστημονικής μεθοδολογίας (κοινώς ντρίπλα) παρόμοιας τεχνικής με τις φανφάρες της ομοιοπαθητικής. Αγωνιώδης προσπάθειες καλωδιάδων. Οταν η επιστημονική μεθοδολογία καταρρίπτει όλες τις εξωφρενικές αιτιάσεις για πανάκριβα καλώδια usb και cable suspension devices αυτές ειναι οι αντιδράσεις των εμπλεκομένων, είτε ειναι πωλητές είτε αγοραστές.Double Blind Testing
"I think the people promoting DBT show a lot of misunderstanding of neuroscience, memory, and perception. Short term, long term, makes no difference. It is not an instrument for measurement and comparison for such fine resolution. Sure if A is an apple, and B is a banana, it works fine. When A is a Pioneer and B is a Mark Levinson, that's not going to work the same way.
1. We DO NOT RECORD all input! And just in that fact alone, the use of memory should be tossed out the window. We only store essential patterns, partial inputs, enough to make the recall. If we were storing ALL sensate input in full bandwidth, our brains would have to be the size of Texas. (EX: If you drove an hour on the freeway tonight to get home, can you recall the license # of each car that passed you? The year, make and model of each car? Description of all the occupants? Obviously not---but you "saw" it all with your eyes. If you tried to store all the sound you heard in a few minutes at something like CD resolution, your brain would explode.)
2. A "memory" of a sound is not a recording of the soundwaves! Nor is it a digital representation, nor is it necessarily even stored in a contiguous brain space. Electrical impulses from the ear system are "mixed" (yeah, like a 16 track mixer) along with visual inputs, other sense inputs, emotional content, other similar patterns from previous events, and wellness stimulus. Point being, there is no discrete memory object of "just the sound" that was heard when A was played or when B was played. Proponents of this are pretending that the brain functions like a tape recorder. Ain't so.
3. DBT depends on this real time analysis: A past memory must be compared to a current stream of conscious perception and a determination for differential must be made. Well, hang on, these are two vastly different brain processes. You might as well try to compare volt meter readings to the direction a weathervane is blowing. It's nonsense. That's why it only works with "Apple and Banana" level comparisons.
There's just absolutely no science behind using DBT in audio. All the assumptions are flawed."
https://therationalaudiophile.wordpress.com/2015/06/22/article-about-listening-tests/
"Along with many other very perceptive points, the argument is that the ABX test is based on a completely flawed premise: it is not comparing audio systems using human hearing, but human memory.
I can’t vouch for whether the author and I would agree on most audio matters, but I certainly agree with him on the idea that listening tests are non-scientific on many levels."
Εννοω πως οσοι ειναι ΚΑΤΑ των double blind testing, οπως για παραδειγμα οι ομοιοπαθητικοι, ειτε δεν κατανοουν τις αρχες τις επιστημης, ειτε εχουν κατι να κρυψουν με ντριπλες. Ειτε και τα δυο. Συγνωμη αν δεν το εξεφρασα σαφως.Θεωρεις ότι η καταστρατήγηση γίνεται απο την πλευρά των υπέρμαχων των blind test ή αυτών που είναι κατά; (Ρωταω απλώς γιατί δεν κατάλαβα έτσι όπως το γράφεις)
