Fanless HTPC (ιδέες, λύσεις, εμπειρίες)
m1ts0s
News poster
Akasa confirms 4 new fanless cases
"We had a glimpse of things to come at COMPUTEX and here they are. Starting with the Plato X, a bigger version of the regular Plato. At about 240 x 240 mm the Plato X will cope with the heat of Intel's i7 NUC (NUC5i7RYH) but it's also compatible witll ALL Broadwell NUCs.
On the other end of the spectrum, the Newton P will handle the ultra low power Braswell NUCs (NUC5CPYH and NUC5PPYH). The small 140 x 111 x 51 mm chassis still has room for a 2.5" SSD.
Designed for the HTPC market, the Max S offers either a slot loading or a tray loading optical disc drive bay. The 174.6 x 179 x 79.6 mm case weighs a whopping 1630g and is compatible with i3 and i5 Broadwell NUCs.
With storage in mind, the Max MT packs a very interesting 2 bays 2.5" SATA mobile rack. Akasa's fanless cases collection is now incredibly diverse, and vastly successful. As much as we love Akasa, a question comes to mind: just where is the competition?"
http://www.akasa.com.tw/
m1ts0s
News poster
ECS Core
Platform: Intel® Broadwell Core M-5Y10C SOC
Memory: DDR3L 4GB
Storage: 1 x 80G/120G M.2 SSD
Audio: 1 x Combo Jack
2 x D-MIC (internal)
LAN: 1 x Gigabit LAN
USB: 4 x USB3.0 Ports
Video Output: 2 x HDMI Ports
Wireless: WiFi 802.11ac & Bluetooth 4.0
Dimension: 136 x 84 x 38 mm
Card Reader: Yes,Micro SD
Adapter: Input: AC 100-240V,Output: DC 19V / 3.43A
OS Support: Windows 7 / 8.1 / 10
m1ts0s
News poster
WindBOX III Advanced Slim and Fanless System with 5th Gen Intel® Broadwell ULT Platform
  • Slim and fanless system design with Mini-ITX board
  • 5th Gen Intel® Broadwell ULT Core i7/i5/i3, Celeron CPU
  • Support DDR3L SO-DIMM up to 16GB memory
  • 3 independent display: 2 x DP, 1 x DVI-I
  • 2 x GbE LAN, 4 x USB 3.0 and 2 x USB 2.0
  • 1 or 2 COM ports, audio, and lockable DC jack
  • Easy maintenance for 2.5” drive, memory, and mini-PCIe
  • DC-in 19V/65W adaptor
http://ipc.msi.com/product/pages/ipc/MS-9A75.html
m1ts0s
News poster
Braswell BRIX
GIGABYTE unveils the GB-BACE-3000 and confirms its fanless nature. Last week's leak was spot on (well the SD card reader is actually micro SD). Unlike other fanless Braswell mini-PCs (ECS LIVA X2, ASUS VivoMini UN45, ASRock Beebox) the Braswell BRIX allows some room for convection, and thus wins.
The GB-BACE-3000 will make a fantastic entry-level desktop PC or Kodi-powered HTPC. No news on pricing yet but the previous model sold for only $125.
"Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact,versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand."
    • Features 14nm Intel® Celeron N3000 to deliver to the most intuitive and integrated operating systems in the world
    • Supports 2.5” thickness 7.0/9.5mm Hard Drives (1 x 6Gbps SATA3)
    • Ultra compact PC design – 0.69L (56.1x 107.6 x 114.4mm)
    • 1x SO-DIMM DDR3L 1.35V Slots (1333 MHz)
    • Intel® IEEE 802.11 ac, Dual Band Wi-Fi & Bluetooth 4.0 NGFF M.2 card
    • Supports dual displays via a VGA and a HDMI port
    • Gigabit LAN
    • Audio jack (Headphone/MIC)
    • VESA mounting bracket (75 x 75mm + 100 x 100mm)
    • Supports Fan less design
http://www.gigabyte.com/products/product-page.aspx?pid=5569#ov
m1ts0s
News poster
Crater Innovation R50 Compact Fanless PC
"The choice of materials fell on a sensual combination of brushed copper and matte black anodised aluminium. Being CNC machined from solid blocks of metal, the chassis feels extremely robust and durable.
Copper was used for the section of the chassis that is closest to the main source of heat, the CPU, enabling the heat to spread quickly along the chassis. High-purity oxygen-free electronic copper was specifically selected to maximise dissipation, because of its unique ability to conduct heat.
Aluminium is another excellent heat conductor, while also being very light. The heat travels from the copper to the aluminium and is dissipated by both radiation and convection."
http://www.craterinnovation.com/portfolio/product-development-r50-fanless-pc/
Stunning Mini PCs Offer Fanless Core i5 Power
m1ts0s
News poster
HDPLEX (2nd Gen) H5
"The plot thickens: here are more pictures of HDPLEX's upcoming superchassis. Tested with no less than an i7 4770K and a GTX 750 Ti, the 16 heat pipes monster is doing a hell of a job with 35°C at idle, and 70°C at full load. The H5 is shaping up as a landmark case."
http://www.hd-plex.com/forum/showpost.php?p=5705
http://www.fanlesstech.com/2015/09/exclusive-hdplex-h5-unveiled.html
The world's first 16 heat pipes fanless case (8 dedicated to the CPU / 8 optional for the GPU) will be available next week. We're lucky enough to preview this monster of a case, courtesy of HDPLEX. This 8kg chassis / cooler will handle CPU up to 95W TDP, meaning that builds with Intel's Skylake-K processors are entirely possible.
The extremely flexible H5 will accommodate ATX, microATX and mini-ITX motherboards. On the power-supply side, ATX, SFX, FlexATX, as well as HDPLEX's nanoATX and external PSUs will be compatible.
A special HDD rack will support two 2.5" SSD / HDD and one 3.5" HDD at the same time (each H5 comes with two of these racks). The H5 also comes with one rack set for 5.25" optical drive or any 5.25" device such as hotswap HDD cage, and one slim 12.7mm optical drive rack.
The H5 will also offer customized brushed aluminum power button and faceplate options to users. A Kodi or Steam logo will definitely compliment the H5's stylish design. Stay tuned to HDPLEX for the final details and the sub-$300 price.
✓ Support ATX / microATX / ITX motherboards
✓ Eight-Heatpipe and Copper Heatsink
✓ Passive Cooling for 95W TDP CPU
✓ Passive Video Card Cooler (Optional)
✓ Swivel Open Faceplate
✓ 5.25" ODD / Hotswap HDD Supported
✓ ATX / SFX / Flex Power Supply
✓ HDPLEX nanoATX Solution
✓ Designed for 300W ATX Linear PSU
✓ Dual Slot PCIE Card Supported
✓ 15mm Brushed Aluminum Faceplate
✓ Touch Sensitive Power Button
✓ Low Light and No Light Dual Mode
m1ts0s
News poster
SilverStone PT18
Includes single 2.5” drive slot
Premium aluminum construction & SilverStone styling
Fan-less thermal design
Super small at 1 liter in size
Includes stand for vertical orientation
Includes VESA MISD-75 wall mount clips
The Petit PT18 is a case designed to support Intel’s NUC platform. It is built using premium aluminum construction to provide stylish exterior and excellent fan-less thermal performance. The size increase over standard NUC cases is well utilized for not only cooling, but also creates room for an additional 2.5” drive mount. Sized to fit nearly anywhere from under the TV, behind digital signage, or next to security cameras, the PT18 will serve to fill the task brilliantly and silently.
http://silverstonetek.com/product.php?pid=637
m1ts0s
News poster
A-Tech Fabrication
Ενδεικτικά ένα από τα μοντέλα της εταιρίας:
HeatSync 2800HP
Detailed Information
  • 100% Made in the USA
  • Low Profile High Performance Computer Case
  • Passively Cooled Design - No Noise!
  • Precision CNC machined from heat-treated aircraft quality billet aluminum
  • Heavy-duty aluminum Heatsink Case absorbs and disperses system heat
  • Modular heatsink system increases performance and functionality
  • Large aluminum fins optimize natural convection cooling
  • 75% increased cooling capacity compared to Mini-Client 2500 case
  • Highly efficient HeatSync®CPU cooling system transfers heat directly into chassis
  • Integrated HeatSync®GPU video card cooling system (optional)
  • Proprietary High-Mass Drive Isolation System eliminates noise from drive vibrations
  • Fanless External AC power adapter (optional)
  • Fanless internal high efficiency DC-DC converter (optional)
  • Holds up to one 3.5" or four 2.5" HDD's
  • Standard slim-line slot-loading optical drive mounting
  • Designed for mini-ITX motherboards only
  • 1/2 height PCI or PCI-E adapter slot for tuner card or RAID adapter
  • Faceplate available with either black or silver anodized finish
  • Standard black anodized finish on chassis
  • Outstanding workmanship and finish quality
  • Dimensions - 17-1/2" wide x 13" deep x 3" high (+ 3/8" with feet)
Options Include:
  • HeatSync® Cooling System for processor
  • HeatSync® Cooling System for motherboard chipset
  • HeatSync® Cooling System for video card
  • IR receiver and remote
  • USB 2.0 or USB 3.0 front panel port
  • Secondary 2.5" HDD mounting
  • 2U one-piece rack mount faceplate
  • Billet aluminum case feet
http://www.atechfabrication.com/index.htm
m1ts0s
News poster
IN WIN H-Frame 2.0 teased
"Open-air cases are perfect to insure proper functioning of passive CPU coolers and fanless power supplies. IN WIN has mastered the art of PC enclosures, their D-FRAME and S-FRAME are truly something to behold. The Taiwanese manufacturer is back with a second iteration of the case that started it all. Although no details are available yet, there's one certainty right now: it's not going to be cheap."
m1ts0s
News poster
HDPLEX H1 (2016)
"The unstoppable Larry is about to update his best-selling mini / Thin mini-ITX case (pictured). The new H1 will feature aluminum fins on the CPU area for additional cooling, and move the SSD to the bottom plate.
The H1.SODD (Optical Disc-Drive) model will now support 2.5" SSD and mini-ITX motherboards (previous model is limited to mSATA / M.2 SSD and Thin mini-ITX). Larry is also working on a cube-like mini-ITX / NUC chassis. Stay tuned."
[DOUBLEPOST=1455630435][/DOUBLEPOST]
Akasa Euler ST
"Akasa
's Euler ST will be the very first fanless case designed for Intel's mini-STX motherboard format. Mini-STX is basically a NUC-size motherboard (5 x 5") with a LGA socket.
While mini-STX will support 65W processors, the Euler ST will most likely be limited to 35W chips. More details available soon."
m1ts0s
News poster
Aleutia R5
Carved and Crafted in the UK. Stunning Design
Just like one of our competitor’s in Cupertino, the R50 is made using CNC milling technology with a single block of aluminium carved by a 5 axis drill. We carve and craft our systems in the UK and we’ve used copper for the first time in the industry to achieve amazing thermal performance and be completely fanless, even in the high temperatures of classrooms in Ghana where we work.
World’s Smallest Business Computer
At just 0.6L volume the near pint-sized R50 is the world’s smallest Intel Core-based computer. And yet it offers:
  • 6th Generation Intel Core i3 and i5 Processors
  • Intel Iris Graphics
  • up to 32GB of DDR4 2133MHz RAM
  • World's Fastest Solid State Drives with 2GB/s Read Speed
  • Integrated 802.11ac WiFi and Bluetooth
  • 5 Year Global Warranty
Silent. Beautiful. Reliable.
A Personal Computer designed for longevity with a case that's instantly recyclable - let's move away from forced obsolescence.
Dramatically Reduce Your Energy Consumption
We have power consumption of just 7.1 Watts. Unlike every other OEM, we not only disclose idle power consumption but peak. Under full CPU and GPU stress the R50 consumes just 21.3 Watts. That’s a synthetic test - you just won’t hit anywhere near that in real world scenarios. Full CPU load with Prime95 is just 14 Watts.
That's 90% less than traditional tower computers and translates to real cost savings.
Made for Explorers - Get Projects Done
Have a project you need to get done? Need something that can run 24/365 in remote areas? And is actually decent performance?
High Performance in High Temperatures
Under full 100% CPU load, the miracle of copper and our patented design means we cannot get the processor temperature above 51 C (in office temperatures of 21 C).
http://www.aleutia.com/products/r50-fanless-server
i3-6100U, 8GB DDR4 RAM, 128GB SSD from £599
i3-6100U, 16GB DDR4 RAM, 256GB SSD from £699
i5-6260U, 16GB DDR4 RAM, 512GB SSD from £899
i5-6260U, 32GB DDR4 RAM, 512GB SSD from £1099
DJCHRISTIANO13
