Ενδιαφέροντα plugin κτλ. για δέκτες linux.
Απάντηση: Ενδιαφέροντα plugin κτλ. για δέκτες linux.
Τελικα τα δοκιμασες ?
Φτιαξανε λεει τους υποτιτλους και το media player γενικως .
Για να δουμε ......
Black Hole 2.0.5 galaxy
"The Black Hole is expanding in our galaxy.
We need more space..."
Starting from this version, the Black Hole image will fully support an internal hdd larger than 2 TB.
The new initialise function will partition your hdd with optimal alignment and will format it in the linux ext4 filesystem, which will give the best performance.
Warning: Duo2 requires a Cfe upgrade to V2 before you flash this image.
Main changes:
New Support hdd larger than 2TB
New Subtitle customisation
Ttx subtitle font size
subtitle delay when timing lags
subtitle delay when timing is bad
yellow Dvb subtitles
centered Dvb subtitles
Dvb subtitles black transparency
New support for coldboot "Wake on Lan" (Duo2)
New firmware upgrade option for Vfd controller and Front Processor (Duo2)
New hotkey for Subtitle window: (2x Yellow button)
Vu+ Drivers updates (duo2):
Fix WOL problem
Add proc entry for WOL
Fix loop-through problem when 2 dual tuners are installed
Improve VFD controller update(VFD controller update will resolve remote control sensitivity issue)
Fix Play/Pause key problem
Support FP update
Support VFD controller update
Fix recording problem
Fix no audio in radio channels
Misc:
Add Tools/Alternatives
Add WOLSetup (WakeOnLan) plugin (Duo2)
Add parted tool to partion and format internal Hdd
Switch to parted and ext4 in hdd inizailise function
Change module description from RT2870 to RT3070/3370/5370/5372 and fixed module installation in the correct place
Add patches for RT3070 ralink driver
Fix rt5572 driver
Add some devices not yet included into rt5572 supports
Add web-manual Duo2
[HbbTV] fix rtl auth problem
Add fuse-module and fuse-utils for ntfs-3g
[Kernel] Solo2 & Duo2: Add Nls modules for other charsets
[Kernel] Fix flash_erase option on postinst
[Dvbmediasink] Fix switching between aac and other codecs
[Gst-plugins-bad] Update SRCREV & patches
Add checkvfd package
Added new driver mt7610u (802.11a/b/g/n/ac support)
Update languages cs, da, fr, sk, sv.
To περασα σε Cloud Ibox και δεν βλεπω καποιο προβλημα,καποια ασυμβατοτητα των σημαντικων plugin, και εχω μια αισθηση οτι ο δεκτης εχει γινει λιγο πιο γρηγορος .
Νομιζω οτι αξιζει να περαστει στους δεκτες .
προσπαθησα να περασω το τελευταιο που βρηκα Ts Online 1.3,μεσω ipk
σε newnigma2 και dreambox 500hd.
ξεκιναει και κανει εκγατασταση,αλλα τελικα βγαζει error.
υπαρχει καποια εκδοση που παιζει,ή καποιο αλλο pluggin που να κανει την ιδια δουλεια?
Τι δουλεια ?
To TSMedia ?
Τι δουλεια ?
To TSMedia ?
iptv εννοω.δεν ξερω εαν ειναι το ιδιο με το tsonline,αλλα δοκιμασα και το tsmedia και βγαζει και αυτο error
στην εγκατασταση.
Πως το κανεις εγκατασταση ,xειροκινητα η' απο το image που χρησιμοποιεις ?
Aν το κανεις χειροκινητα μαλλον χρησιμοποιεις λαθος εκδοση .
Το TSMedia μπορεις να το κανεις εγκατασταση απο το TSPanel .
newnigma2 σε dreambox 500hd(γνησιο).
ναι-το περναω manual.το ts panel(απ`οσο θυμαμαι)παλι δεν μου το κανει εγκτασταση το newnigma.
Δες το image τι ειναι , ΟΕ2.0 η' ΟΕ1.6 και ετσι θα διαλεξεις και το καταλληλο TSPanel κτλ .
Μετα διαβασε πως γινεται η εγκατασταση του χειροκινητα :
post no.5
http://www.avsite.gr/vb/showthread....-%EA%F4%EB-%E3%E9%E1-%E4%DD%EA%F4%E5%F2-linux
post no.5
μεσω telnet εκγατασταθηκε χωρις προβλημα το tspanel.
απο εκει εκανα και εγκατασταση του tsmedia.
κολλαει βεβαια σε αρκετα σημεια(γραναζια..)αλλα δεν ειναι κακο.
thx
ξέρει κανείς αν μπορώ να περάσω σε κλώνο
dreambox 800se sim 2.10 το XMBC plugin?
Θα πρεπει να βρεις την αναλογη εκδοση που υπαρχει για τον δεκτη σου και με telnet η' μεσα απο το μενου του δεκτη αφου βαλεις το αρχειο στον φακελο .tmp
φιλε μου johnny78 εχω βαλει το Black Hole 2.0.5 galaxy και δουλεύει μια χαρα. το μόνο προβλημα μου ειναι η ώρα . μπορεις σε παρακαλω να μου πεις τι πρεπει να κανω για να δειχνει σωστα?
Το εχω κανει αυτο. Οταν βλεπω ενα καναλι εχει λαθος ωρα και ημερομηνια 1. 1. 1970. Αυτο ειναι το προβλημα μου. Αν μπορεις να με βοηθησεις.
Αυτες οι πληροφοριες λαμβανονται απο τον δορυφορο & απο το καναλι που εισαι .
Συνδεσε τον με το καλωδιο του lnb και πηγαινε σε καποιο καναλι του Hotbird η' Astra η' σε οποιον δορυφορο στοχευεις και θα παρει την σωστη ωρα .
Παιδια εγω θελω να ρωτησω κατι, υπαρχει καποιο addon για να βαζει μονο υποτητλους οταν βλεπω ενα ξενο καναλι η ολα τα addons ειναι μονο για ταινιες ;;;;
Εχω ενα VU+ZERO με OpenBlackHole image.
BBCiPlayer
RTE Player
ITV Player
Ειναι τεσταρισμενα σε VU+ ,ομως ο καθενας τα δοκιμαζει με δικη του ευθυνη καθως δεν ειναι επισημα.
unzip the folder, and FTP to your receiver in
usr/lib/enigma2/python/plugins/extensions
restart enigma
BBCiPlayer
http://www.uploadmb.com/dw.php?id=1358534464
RTE Player
http://dl.dropbox.com/u/31328853/rteplayer Alpha 2.zip
ITV Player
http://www.uploadmb.com/dw.php?id=1358535035
Δουλευει μονο για ΙP UK οποτε οι υπολοιποι μπορουν να κανουν αυτο :
http://www.unblock-us.com/
Αλλος τροπος δωρεαν δεν υπαρχη για την IP μιλαω παντα.
Katerinanota
