SYBASONIC 192 KHz 24 - M-AUDIO Super DAC
Τι παιζει εδω?
Η sybasonic κατασκευαζει για την M audio?
http://www.globalsources.com/gsol/I/USB-audio/p/sm/1134206408.htm#1134206408
http://www.ebay.com/itm/Hi-Fi-192K-...827745?hash=item3f6397baa1:g:cIYAAOSwTdJXRXfG
http://www.m-audio.com/products/view/super-dac
http://www.ebay.com/itm/M-AUDIO-Sup...219393?hash=item3abc3d0781:g:F60AAOSwL7VWpkTI
M-AUDIO
  • 24-bit/192kHz high-definition audio conversion over a USB 2.0 connection
  • High-quality headphone amplifier with 1/4" and 1/8" outputs
  • Stereo analog line in
  • Stereo analog RCA line outputs
  • Coaxial and optical digital outputs
  • Wolfson digital conversion
  • USB-bus-powered
    SYBASONIC
  1. Asynchronous USB signals - asynchronous USB audio data transfer protocol resolve the timing errors which have long been the plague of digital audio playback
  2. Hi-end USB audio controller and DAC - UAU07 equipped Hi-End Cmedia CM66xx USB audio controller supporting asynchronous transfer, ASIO and WASAPI, Wolfson WM8740 inside gives you high resolution 192Khz 24 bits conversion
  3. High quality headphone amplifier - powerful headphone amplifier inside to provide up to 210mW power output to driver your headphone
  4. Smart LED indicator - smart LED indicators show the resolution (44.1/48/88.1/96/176.4/192KHz) of the incoming signal
  5. Volume control - high-resolution analog volume control carries out the instructions in the analog domain for the best sound quality
Kαι σε 24/96
http://www.ebay.com/itm/Digital-96K...576864?hash=item3f63a328e0:g:J9sAAOSwoJZXRk9x
Επαναφερω το θεμα λογω του οτι απο εχθες το βραδυ κανει διακοπες ηχου και πολλες φορες παιζει το ενα καναλι, η καρτα ηχου ενος ξαδερφου στο λαπτοπ.
Βαση χαρακτηριστηκων αξιζει να την παραγγειλει? Ψαχνοντας δεν βρηκα τι παιζει μεταξυ αυτης της καρτας,και της M-AUDIO.
Σκεφτηκα να παρει μια http://www.ebay.com/itm/Red-NEW-Beh...711810?hash=item58e2e3f342:g:CFgAAOxyOlhSqY5i οπου εχω διαβασει παρα πολυ καλα λογια,αλλα παιζει μεχρι 16/48,και η κατασκευη της δεν βολευει για πανω στο γραφειο.
H αλλη λυση που μου ηρθε στο μυαλο και ποιο ακριβη ειναι αυτη.http://www.ebay.com/itm/AUDIOTRAK-P...770600?hash=item19cac01de8:g:j6kAAOSw7ThUl3f- αλλα δεν θελει να ξεφυγει σε τιμη πανω απο 50€
Υπαρχει κατι αξιολογο σε ηχο σε αυτη την τιμη? Αν και θεωρω οτι η sybasonic θα ειναι αξιολογη στα λεφτα της.
[DOUBLEPOST=1473963784][/DOUBLEPOST]δεν ειναι η συγκεκριμενη πλακετα, η σωστη ειναι η προηγουμενη, πασιφανες οτι ειναι οπτικα αλλα και στα σπεκς ιδια πραματα με την
m-audio.
Κ.Κωνσταντίνος
