QSC: ανακοίνωσε το K Cardioid Subwoofer
QSC "Keeps Bass in Its Place" with the K Cardioid Subwoofer
Ήταν να μην ξεκινήσει το...κακό. :)
As QSC, LLC approaches the celebration of nearly one million K Family loudspeakers sold since their introduction in 2009, the company is pleased to announce the newest member of the family, the K Cardioid Subwoofer. Deploying innovative design, legendary QSC amplification and advanced DSP in a single, compact enclosure, the K Cardioid Subwoofer represents the world’s first-in-class single-box powered cardioid subwoofer solution for highly portable entertainment and installation applications.
Typically, subwoofers radiate sound equally in all directions, resulting in troublesome, unwanted low-frequency build-up on stage as well as undesired, wasted LF energy at the rear of the system. In more recent years, concert sound providers have been able to create cardioid (heart-shaped) coverage of their subwoofer arrays through some clever manipulation of placement, delay and polarity, redirecting desired LF energy forward and minimizing energy at the sides and rear. Unfortunately this technique is costly and requires multiple enclosures, amplifiers and processors.
Representing a breakthrough in innovation and design, the K Cardioid Subwoofer uniquely provides all the benefits of a cardioid subwoofer array but in a single, compact enclosure. “Keeping bass in its place” for mobile entertainers, AV production and rental professionals, as well as modestly-sized performance venues, the K Cardioid Subwoofer is unparalleled in its ability to manage low frequencies on the stage, or any application where undesirable low frequency energy needs to be minimized. Powered by a 1,000 Watt Class D amplifier, processed with the latest DSP technology, and featuring dual 12-inch long excursion drivers each arranged in a 6th order bandpass chamber, these elements all combine seamlessly to produce a staggering 15 dB more output at the front of the cabinet than at the rear. Highly portable, the cabinet features comfortable, aluminum handles and four, rear-mounted casters. Two M20 sockets are provided to accept a 35mm speaker pole in either vertical or horizontal deployment of the sub. Additional features and specifications to be announced.
The K Cardioid subwoofer will have an estimated US street price of $1,399 and is expected to be available in the first half of 2017.
http://www.qsc.com/news/news/detail/qsc-keeps-bass-in-its-place-with-the-k-cardioid-subwoofer/
Alex_Zapantis
Δεν "παίζουν" αυτά, είναι επαγγελματικά...
Άντε να σου αποδώσουν τη "ντελικατέτσα" των χαμηλών ενός πιάνου, ή το "παιχνίδισμα" των χορδών ενός κοντραμπάσσου...
Για σας που είστε όλο εκρήξεις και μπαμ μπουμ καλό είναι...
Ελα που και εκει θελεις πολυ χαμηλες , οι εταιριες κοντραρονται ποια θα κατεβει χαμηλοτερα max db low thd ...
Αυταμαλλον για stage προοριζονται για να μην δεχονται την οπισθια ακτινοβολια τους οι μουσικοι περαν της εμπροσθιας βελτιωσης, ομως αυτο με συστοιχιες και παραταξεις μπορει να επιτευχθει οπως και υλοποιειται δηλαδη, ενταξυ αυτο ισως να παρεχει μεγαλυτερη ευκολια τοποθετησης-ρυθμισης η και σε μικρης εμβελειας στησιμο.
καρδιο σε ht δε ξερω ενα αξιζει κιολας, ποιο το οφελος τετοιας ακτινοβολιας αν κολλησεις το σαμπ,τοιχο, γωνια?
dapost
Rehdeko & Harbeth lover
Πολυ ωραιο ερωτημα που με εχει απασχολησει και εμενα. Τι λενε οι ειδικοι;
Alex_Zapantis
Έτσι.
Ποιος διαφωνει?η qsc δεν το γνωριζει? Γιατι τα εβγαλε? θεωρω οτι σε μικρες σκηνες περιορισμενου χωρου μπατζετ και ευκολιας ειναι αστερια..
Ερωτησης ποσα σαμπ χρειαζονται για να πετυχεις την ιδια καρδιοειδη αποκριση στο ευρος συχνοτητων που πετυχαινει ενα (1) τετοιο ? μη βιαστειτε να απαντησετε μπορει να πεσετε πολυ εξω ...:whistling: το λεω αν και δεν αναγραφει η εταιρια συγκεκριμενα χαραχτηριστικα ..
zakman35
Αν το σύστημα (HT) προσανατολιζεται στην ποιότητα, ίσως να έχει νόημα η χρήση ενός cardio sub.
dapost
Ακύρωση δεν έχουμε αν το ηχείο (σαμπ) είναι κολημένο σε γωνία.
Αρκεί όμως αυτό;
dapost
Και όλη η ενέργεια που εκπέμπει το ηχείο σφαιρικά και κατά συνέπεια και προς τους τοίχους και πάτωμα δημιουργεί θέματα;
dapost
Σχετική ερώτηση: το waterfall / csd διάγραμμα ενός κλασσικού σαμπ κολημένου σε γωνία θα είναι ίδιο με αυτό ενός cardio στην ίδια θέση;
Περνωντας πασα, ποσο διαφορετικο θα ειναι εαν με peq κοψουμε σε απλο σαμπ τις κορυφες?
Καμία σχέση. :)
Άλλο πράγμα είναι να μην έχεις πρόβλημα, κι άλλο να προσπαθείς να το καλύψεις. :)
Βεβαίως, τα software κάνουν μικρά θαύματα, κι απ'το ολότελα, καλή κι η παναγιώταινα..
Ναι και οχι :D ,(για το καμια σχεση) γιατι ο κοινος παρανομαστης(οχι η ομωνυμη ελληνικη ταινια):o που πρεπει να κοιταμε ολοι ειναι το vfm...
1)σε γωνια δουλευει το καρδιο?
2)το απλο μηπως σε γωνια θα αποδωσει με λιγοτερες παραμορφωσεις τις πολυ χαμηλες συχνοτητες με ολα τα ωφελη της αθροισης που αυτη(η γωνια προσφερει?)
3)απο τη στιγμη που δεν εχουμε ακυρωσεις στη γωνια με το απλο μηπως τελικα συμφερει με ενα eq να μας μεινουν οχι μονο λεφτα αλλα και να παιζει καλυτερα απο ενα απλο καρδιο χωρις eq?για να μην πω και με ...(αν η αυτη λειτουργεια του δουλευει σε γωνια)
dapost
Και τι γινεται ολη η ενέργεια που εκπέμπει το μονοπολο προς τη γωνια και ανακλάται ολιγον καθυστερημενη; Δε δημιουργεί συντονισμους στα διπλανα ντουβάρια; Group delay; Smearing; Αυτα διορθώνονται με eq;
(Σωστη η παρατήρηση περι παραμόρφωσης! )
Ioanniss
