Gramovox Floating Record player
Mr Spock
demokratischer - sektor
FLOATING RECORDVERTICAL TURNTABLE
Built in Chicago.
A high-performance turntable that plays your records vertically through built-in, dynamic, full-range stereo speakers. Get ready to spin vinyl right out of the box.
ALL-IN-ONE
You don't need to set up your cartridge or purchase additional outboard gear such as phono pre-amps, amplifiers and speakers (although you have the option to). All of these are included in our integrated design.
We designed the Floating Record for everyone from the first-time record listener to the seasoned vinyl enthusiast. We've developed a robust cueing mechanism that allows you to effortlessly cue your records. You’ll be spinning tunes out of the box in a matter of minutes.
FULL RANGE SOUND
The Floating Record comes with a dynamic, full-range audio system. We use two Tymphany 2" neodymium speakers driven by a 15w per channel digital amplifier. We achieved the best possible sound without compromising aesthetics or performance.
SEE YOUR SOUND
We wanted to create a visceral vinyl experience that showcased the record as both art and a medium to produce analog sound. The result is a high-performance turntable that plays your records vertically—producing the illusion that it’s floating.
LISTEN YOUR WAY
With built-in RCA line out ports, you can bypass the integrated speakers and use the Floating Record as a standalone Hi-Fi turntable for your own audio setup. Additionally, you can use your headphones through the built-in 3.5mm stereo jack.
33 ⅓ OR 45
You can easily switch between 33 ⅓ or 45 RPM by moving the silicon belt over the inner or outer groove of the middle gear.
"My vinyl has re-emerged into the light of day and there are sounds in my home that have lived only in my head since all my albums went to storage years ago. This machine brings a hefty dose of happy built into it and makes "playing records" all groovy again!"
MIKE PASSALACQUA | KICKSTARTER BACKER
DIMENSIONS
  • 17” Wide x 10” Deep x 16” Tall
FEATURES
  • Easy to use, all-in-one system
  • Walnut or Maple Veneer Wood Base
  • Carbon-Fiber Tone-Arm
  • Hi-Fi Phono Pre-amp
  • International Voltage Compatible
  • Built-in 2" full-range stereo speakers
  • Belt-Drive System (33 1/3 or 45 RPM)
  • RCA Line Out
  • Vibration Dampening Feet
  • Pre-installed AT95E Cartridge
  • Hand-assembled in Chicago, IL
https://www.gramovox.com/pages/floating-record
Mr Spock
- υποθέτω πρώτα σετάρεται οριζόντια με τις γνωστές μεθόδους ( αλλά χωρίς δύναμη αντιολίσθησης ) και μετά ως έχει στήνεται κατακόρυφα , το δε βάρος ανάγνωσης τελευταίο ( με ελατήριο προφανώς )
- αν και τώρα που το ξανασκέφτηκα θα χρειαστεί antiskating . . . όμως το ζητούμενο σ΄ αυτές τις περιπτώσεις είναι απλά να παίζει
Έχει μια οπτική ιδιαιτερότητα που σε άλλους μπορεί να αρέσει και σε άλλους όχι , βασικά για μένα το μόνο που σκέφτηκα όταν το είδα είναι πως δε βλέπω το νόημα ύπαρξης μιας τέτοιας κατασκευής ηχητικά πέρα από λόγους καθαρά αισθητικούς
Mr Spock
- συμφωνώ
Mr Spock
. . . και μάλιστα περισσότερο του συνηθισμένου και προοδευτικά αυξανόμενο διότι όσο θα πλησιάζει η κεφαλή στο κέντρο του δίσκου , η κατακόρυφη απόκλισή της από το pivot , συνεπικουρόυμενη από την βαρυτική έλξη . . . ολοένα και θα αυξάνει την τάση της προς το κέντρο αυτό
ika
News
Να δούμε και πως δεν θα τρέμει από ανάδραση.
jimacid
