OPTOMA UHD projectors
o uhd550x!!αμα ξερει κανεις την γλωσσα να μας πει περιπου τι λεει εκει στο 14:00 που συγκρινει με τον epson tw7300
http://www.projectorreviews.com/optoma/optoma-uhd65-4k-home-theater-projector-review/
UHD65 Pros, and Cons!
Pros:
  • Well priced for a 4K UHD projector
  • Supports both HDR and expanded color space in 4K
  • Reasonably bright for normal non-4K viewing
    • Over 850 lumens calibrated in best mode (non-4K)
    • Over 1100 lumens calibrated in HDR mode for 4K
  • Very good skin tones
  • Adjustable Brilliant Color
  • Dynamic Black – lamp dimming for modestly enhanced black levels
  • Great warranty!
  • Better than most placement flexibility
    • 1.6:1 zoom
    • Modest amount of vertical lens shift
  • 2 HDMI inputs – one is HDMI 2.0 / HDCP2.2 (needed for Blu-ray UHD…)
    • One has MHL for mobile device support
  • Reasonably quiet
  • Internal speakers: 2 x 4 watts
  • Variety of features – CFI, detail enhancement, Digital Zoom, Image Shift,
  • Good backlit remote control
  • Allows one to emulate HDR from non HDR content (interesting)
    • reminds me of projectors that let us convert 2D to 3D on the fly, in that there are limits to what one can expect, but why not provide the feature, let folks choose.
  • Very long lamp life
  • A projector worth serious consideration
Cons:
  • Could calibrate better
  • Lacks the ability to tackle BT.2020 color space, as well as some of the competition, colors not quite as intense
  • When using HDR, too much near brights, and a little light detail loss, lacks as much pop as some other HDR projectors
  • Really not bright enough for HDR / BT.2020 – but then that’s true for pretty much all home theater projectors – so there are trade-offs
  • Came up over 10% short on 2200 lumen brightness claim
    • Very good color starts around 1400 lumens, down a full 1/3 from claim
  • Gaming – input lag time of 83ms is considered too much by most gamers. Acceptable tends to start at around 50ms and below, with good, below 35ms. This is not a projector for serious gaming.
  • No 3D – what were they thinking of? This projector is likely to be an upgrade/replacement for another, and many of us have collections of 3D movies
  • Remote control has white backlight – which is terrible. It’s easy to read, but forget trying to subtly adjusting colors, etc., after being blinded by the brightest remote control I’ve every encountered. (fun fact – I picked on their overly bright blue LEDs on previous Optoma remotes – this is worse)
  • Potential issue – but likely the fault of both the UHD65 and my Anthem receiver, in that when watching content from my DirecTv box, I lose audio if using the HDMI 2.0 port. No problem with the DirecTv using HDMI 1.4, but that complicates setup. I’ve seen this same problem in my theater with at least one other Taiwanese 4K UHD projector, but three other projectors have no problem with their HDMI 2.0 port, and same box
  • No wireless capability
petepappas
οταν σου ζητανε κατι benq η αλλοι 6κ βαλε χιλιαρικα ο optomakos θα γινει best buy.για jvc δε μιλαω παραμενουν η κορυφη αντικειμενικα
Καμμία αναφορά για την έλλειψη ίριδας με αποτέλεσμα το μέτριο μαύρο.
Είναι ουσιαστικά προβολέας τωρινός των 800ε με 4κ πανελ.
Αν είχε μια δυναμική ίριδα, θα άξιζε.
Είναι ήδη best buy και οι δύο! o uhd65 ειναι out of stock παντου κάί ό uhd60 πηγαινει μπάλα και αυτος.
petepappas
κριμα που εδω ακουστηκε οτι η τιμη θα ειναι 3.500 με 4,000ε.........
Nelsy
Ιεράπετρα
Για τον '65' έψαξα σε Αγγλία,Γερμανία και η τιμή του(ανωτ.λιανική)είναι ~3.300€.
Παντος στο αμερικα ο uhd65 έχει 2.500 $ και 1999$ ο uhd60 .σκέφτομαι αφού έχω θείο στην Αμερική να μου βαστάει έναν. 1999 $ είναι περίπου 1800 ευρώ έτσι δεν παει η μου διαφεύγει τιποτα;
Προ φόρων (στις ΗΠΑ) και δασμών (για την μεταφορά του εδώ). ;)
Και με 2 χιλιάρικα παίρνεις δυόμισυ μεταχειρισμένους JVC από τον @stathis. :lolsign:
Ποιός Optoma...:whistling:
Ναι αλλά εμένα με ενδιαφέρει πρώτα το gaming μετά ταινίες και οι jvc έχουν υψηλό lag οπότε δεν μου κάνουν...Αν ο θείος μου αγοράσει μια συσκευή από Αμερική και μου την φέρει εδώ με το αεροπλάνο θα πληρώσει δασμους;1999 είναι τελική τιμή σε δύο γνωστά eshop
TERMATOGAZI
Bass!
αν δεν τον σταματησουν οι τελωνειακοι οταν ερθει η Ελλαδα , τοτε ναι θα γλυτωσει δασμους και φπα.
αν σου βγαλει προβλημα τοτε τι κανεις?
akoustiklab
