Shindo Cortese Single-ended ενισχυτής 8W
Mr Spock
demokratischer - sektor
Χαμηλής ισχύος σε τάξη Α είναι αυτός ο νέος λαμπάτος ενισχυτής της Ιαπωνικής Shindo Laboratories.
O Cortese έχει ισχύ μόλις 8W, είναι Τάξης Α και βασίζεται στις λυχνίες 300Β. Είναι κατάλληλος για ηχεία με ευαισθησία από 90dB και επάνω.
Ζυγίζει 14,7 κιλά και έχει λόγο σήματος προς θόρυβο 90dB, ενώ φέρει στην πρόσοψη ρυθμιστικό στάθμης ανεξάρτητο για κάθε κανάλι. Ο ενισχυτής έχει μόνο μια είσοδο…
http://www.hxoseikona.gr/nea/5657-shindo-cortese-single-ended-enischyths-8w.html
Effective output power:8W in calss A. Input(RCA Pin Jack)
Input sensitivity/Impedance:1V/100KΩ.
Signal to Noise Ratio:90dB.
Frequency Response:20 - 20000Hz.
Power Consumption:130W.
Power Requirements:AC 120V or 220V - 240V, 50/60Hz.
Demensions:W 380 × H 225 × D 295 mm.
Weight:14.7kg.
http://www.shindo-laboratory.co.jp/Front/indexe.html
- πολύ ενδιαφέρουσες κατασκευές , το site τους όμως Λακωνικό . . . ρίξτε μιά ματιά πάντως
In conclusion there are just a few things to wrap up.
I noticed that I forgot to mention the Cortese seemed more powerful than any 10 to 7 watt amp I have heard. Both it and the WAVAC MD300B are rated at 10 watts, but the Cortese seemed much more powerful. In fact, it sounded more powerful than a certain Italian 845 tube amp I had here for a while.
Another thing I think I should mention, is that while I know Shindo is really a devotee of vinyl, I think this amp brings out the best of a very good digital source. Some might say that means it is a forgiving amp, but I’d rather say that somehow it lets you hear the best of either source as long as it is a good musical source.
I want to thank Matt of Pitch Perfect Audio in San Francisco for all his help and for letting me have his demo Cortese for so long. It was nice to know I was getting the same amp that customers were hearing and to have it already broken in. I had the chance to listen to the amp for a couple of hours in Matt’s flat in his all Shindo system. I want to say that the amp was just as impressive and seemed to have a little more immediacy in that system with the Shindo Latour field coil speakers. I also think this amp would be great on any of the better horn systems, and I would love to hear what it could do with Khorns. I think this amp would really help their bass. The one other speaker I know this amp sounds great with is the DeVore line of speakers. The Silverbacks and the Cortese are a match made in heaven. I want you to understand that I think the Cortese would be a great choice for any speaker that is SET friendly and has a good open midrange.
There are several very good tube amps at this price, including a push-pull one from Shindo. I can’t imagine buying an amp at this price or any other for that matter and not hearing it first or better yet with a return option. But having said that, there are two things I don’t want you to forget about the Cortese: you have to hear this thing play strings and don’t forget, it just sounds fundamentally RIGHT!
https://www.dagogo.com/shindo-cortese-f2a-tube-amplifier-review
https://www.stereophile.com/content/listening-55-page-2
http://www.6moons.com/audioreviews/shindo3/shindo_2.html
Mr Spock
. . . το οποίο το προτιμώ από το balance
- φτηνά και καλά τα croft , αλλά με home made φινίρισμα
Οταν βλέπω τέτοιου είδους ενισχυτές αφήνω ελεύθερες τις αισθήσεις μου και ξεχνώ την οδήγηση , παω μια, βόλτα με το ποδήλατο
8w σε τάξη Α, 130w power consumption, μήπως μεταπηδά και βγάζει κανένα 25αρι 30αρι ανα κανάλι;
Για bi amplification θα ειναι ωραιος να παίζει ενα ζευγαρι κορνες και χαμηλα ενας δυνατός τρανζίστορ. Και εγω έτσι ελεγα παλια πως με 2χ35 λαμπατα βατ μια χαρα παίζουν τα ηχεια μου (105db)... Μεχρι που δοκίμασα την διενισχυση.
platon
Ακριβως αυτο γινεται με τα Avantgarde που εγραψα πιο πανω. Τα χαμηλα τους ειναι ενεργα, αρα τα 8 βατακια εχουν να
κουνησουν μονο μεσαιο (αφιλτρο) και τουητερ.
Γενικα τα χαμηλα σε ολα τα ηχεια, πρεπει να ειναι ..........τουλαχιστον ενεργα.
Nikos67
