και η Akai Professional . . . πικαπ
Mr Spock
demokratischer - sektor
Akai Professional BT500 streaming turntable
AKAI Professional presented its new BT500 belt-drive turntable at NAMM 2016, which according to company officials is a response "to the rapidly growing demand for high-performance turntables in the resurgent vinyl market". The BT500 is a nice-looking looking hi-fi turntable, with an elegant walnut finish and aluminum controls, featuring built-in Bluetooth connectivity allowing you to send the signal to any Bluetooth speaker system.
It has a built-in switchable phono preamp, so it can be used with an external preamp or connected directly to powered speakers. The turntable also has a USB port for quick connection to any computer, to facilitate analog to digital conversion with a selectable sampling rate of 44.1kHz or 48kHz. The heavy MDF base is supported by adaptable feet and has a mounted leveling bubble under the platter to ensure a perfectly level installation. The 2-speed, mechanically-isolated DC motor with a belt-drive system ensures silent operation and minimizes vibration. It comes with a die-cast anti-resonance aluminum platter with heavy non-slip rubber mat, and a low-mass straight tonearm with precision damped cueing, removable headshell and a pre-mounted Audio-Technica moving-magnet phono cartridge.
The Akai Professional BT500 will be available this spring and have a U.S. retail of $399.99.
Winter NAMM 2016: Akai Professional BT-500 Bluetooth Turntable
http://turntablemag.com/news/akai-bt500-streaming-turntable
Specifications:
  • 2-speed (33 1/3 RPM and 45 RPM) Belt Drive Turntable
  • Motor: Isolated DC
  • Signal-to-Noise Ratio: 67dB (A-weighted)
  • Wow and Flutter: Less than 0.2%
  • Dimensions: 444mm (17.5") W x 123mm (4.84") H x 347mm (13.7") D
  • USB Function:
  • A/D 16-bit 44.1 kHz or 48kHz selectable
  • Computer interface - USB 1.1 Compliant Windows 10/8/7/Vista/XP, Universal Binary for OS X 10.5 to 10.10.x
  • Weight: 14 lbs. (6.4kg)
  • Output Level:
  • Pre-amp "OFF”: 2.5mV
  • Pre-amp "ON”: 155mV
Requirements:
  • Computer interface: USB 1.1 Compliant Windows 10/8/7/Vista/XP, Universal Binary for OS X 10.5 to 10.10.x
http://www.akaipro.com/products/turntables/bt500
Nick Arvanitakis
Audio Pro
Το look είναι υποκειμενικό.
Αν φέρεις μισή στροφή πίσω το πλατώ και φύγει ο ιμάντας είναι mal@κία.
Το ότι το προέρχεται (?) από εταιρία με το επίθεμα "professional" δεν σημαίνει ότι απευθύνεται σε επαγγελματίες - είπαμε, Hi-Fi!;)
Κατά τα άλλα, τρικυμία εν κρανίω η ΑΚΑΙ όπως και πολλοί άλλοι που "είδαν φως στο tunnel του βινυλίου"...
JAndronikos
