Ερώτηση για HDMI 1.4 και 9.1 ?
Tο 1.4 hdmi μπορεί να δώσει max 8 κανάλια (ομολογώ δεν το γνώριζα αυτό)
άρα τα άλλα 2 σε ένα σύστημα 9.1 ή τα 4 σε ένα σύστημα 11.1 κλπ είναι πατέντα αποκωδικοποίησης του ενισχυτή?
Που το δες αυτό ρε Χάρη; Αφού ο avr κάνει decoding την πληροφορία που παίρνει από την πηγή όταν κάνεις streaming. Από θέμα bandwidth δεν πιστεύω να "μένει" πάντως με το 1.4
Atmos:
Home theater implementation details - differences from commercial installations
Because of limited bandwidth and lack of processing power, Atmos in home theaters is not rendered the same way as in cinemas. A spatially-coded substream is added to Dolby TrueHD or Dolby Digital Plus. This substream represents an efficient representation of the full, original object-based mix. This is not a matrix-encoded channel, but a spatially-encoded digital signal with panning metadata. Atmos in home theaters can support 24.1.10 channels,[24] and uses the spatially-encoded object audio substream to mix the audio presentation to match the installed speaker configuration.
In order to reduce the bitrate, nearby objects and speakers are clustered together to form aggregate objects, which are then dynamically panned.[25] The sound of the original objects may be spread over multiple aggregate objects to maintain the power & position of the original objects. The spatial resolution (and hence the strength of the clustering) can be controlled by the filmmakers when they use the Dolby Atmos Production Suite tools. Dolby Digital Plus has also been updated with Atmos extensions.[5]
DTS:X
Rather than define a fixed number of channels, one for each speaker, DTS:X allows the "location" (direction from the listener) of "objects" (audio tracks) to be specified as polar coordinates. The audio processor is then responsible for dynamically rendering sound output depending on the number and position of speakers available. Dolby Atmos uses a similar technique,[13][14] although the speaker layout employed by cinema DTS:X is the sum of Dolby Atmos and Auro-3D. The layout showcased at AMC Burbank theatre number 8 has a standard eight channel base layer, a five channel height layer on top of the base layer (on the front and side walls) and three rows of speakers on the ceiling. The surround arrays are bass managed by woofers suspended from the ceiling.[15]
Απο Wikipedia.
Αν δεν υπάρχουν κανάλια ύψους η πληροφορία τροφοδοτείται στα 6-8 κύρια, αλλά αν υπάρχουν μοιράζεται σε όλα τα κανάλια προκειμένου να επιτύχει τη θέση η οποία έχει οριστεί κατά την επεξεργασία.
Atmos:
DTS:X
Απο Wikipedia.
από απάντηση σε μειλ που ρώτησα για το NanoAvr που υποστηρίζει 8 κανάλια και τους ρώτησα αν έχω 9.1 (όχι Ατμος) τα άλλα 2 ή 4 θα τα έχω? κάτι σαν passthrough ή θα μου τα κόψει?
Tech support team replied:
Hello
Ok, I see.. HDMI can only carry 8ch maximum as PCM though. We’ve never tested a 9.1PCM connection so unfortunately wouldn’t know what happens.
Maybe try on your AVR? I’m pretty sure that this setup from a source point of view is actually a 7.1 (i.e. on blueray) that is then upmixed by your AVR.. We could be wrong..
If you put a nanoAVR in place, it would indeed be 7.1 max.
Hoping this info helps
Best Regards
DevTeam
miniDSP Ltd
Office Hours: Mon-Fri 9am-5.30pm Hong Kong Time zone / Thanks for your patience.
Αφού HDMI μπαίνει κι HDMI βγαίνει, λογικά θα περάσει. Αλλά δεν ορκίζομαι. :p
Φυσικά δεν θα ισοσταθμίσει τα κανάλια ύψους.
EDIT: Τι εννοείς όχι Atmos; Presence;
Αφού HDMI μπαίνει κι HDMI βγαίνει, λογικά θα περάσει. Φυσικά δεν θα ισοσταθμίσει τα κανάλια ύψους.
για την ισοστάθμιση σίγουρα...και δεν με απασχολεί...υπάρχει και η ισοστάθμιση του Denon...
και εγώ από όσο διαβάζω αυτό πιστεύω,ότι θα περάσει...αλλά δεν το βλέπω κάπου δοκιμασμένο μέχρι στιγμής:unsure:
μάλλον θα πέσει ρίσκο8-)
Δεν πρόλαβες το edit.
Δεν καταλαβαίνω ποιά 9.1 κανάλια εννοείς χωρίς Atmos.
να καλέ..ούλοι με το Άτμος...ξεχάσατε τα παλιά:D
χωρίς τα s.back...
Αυτά τα κανάλια δεν υπάρχουν, τα δημιουργεί ο AV. Δεν υπάρχει τίποτα να περάσει απο το NanoAVR.
και τα για s.back το ίδιο?
έτσι κατηγορηματικό σε θέλω...όχι σαν κάτι σαπορτ μινιντιεσπιδες από το Χονγκ κονγκ:D
Αν το υλικό είναι 5.1, το NanoAVR δεν θα ισοσταθμίσει τα SB.
δεν μιλάω για ισοστάθμιση του ΝΑΝΟ...
ρωτάω αν θα λειτουργήσουν σε περίπτωση που τα τοποθετήσω, όπως τα φροντ χάι που είπες
[DOUBLEPOST=1508352654][/DOUBLEPOST]Υ.Γ. Η σύνδεση θα γίνει σε pc
Φυσικά θα λειτουργήσουν. Τίποτα τεχνητό δεν αφορά το Nano, αφορούν τον ενισχυτή που έπεται στην αλυσίδα.
Πρώτα θα συνδέσεις τον ενισχυτή μέσω HDMI με το player και μετά το Nano; :rolleyes:
Nikos67
