Denon AVR-X6300H
πολλα η λιγα ?
τον Αυγουστο βγαινει ο 6400 και πεφτουν οι τιμες...;)
σε αυτον με προβληματιζει το γεγονος οτι εχει αυτο
ενω δεν το εχει ο marantz av7703 !!
For the following models, Denon will issue a firmware update to additionally support Dolby Vision and HLG (Hybrid Log Gamma) HDR pass-through:
AVR-X1300W, AVR-X2300W, AVR-X3300W, AVR-X4300H, AVR-X6300H.
Dolby Vision offers an end to end HDR solution to deliver smooth transitions between bright and dark levels with compatible source material, compatible players and compatible TV sets. Dolby Vision will offer higher contrast and more vivid colors and this dynamically based on picture by picture. Content and playback equipment is expected to arrive in the market during 2017.
HLG (Hybrid Log Gamma) is the optimum HDR solution for broadcasting systems since it is backwards compatible with SDR content allowing to save bandwidth while delivering best possible quality with future HDR content from TV stations, HLG compatible satellite receivers and TV sets. Regular HLG transmissions from broadcasting stations are expected to start in late 2017.
With this update, Denon delivers on the promise to do the utmost to keep already available products future-proof. The update for all above mentioned Marantz models is currently scheduled for late 2017 / early 2018.
he X6300H is unique in that it’s the first Denon AV receiver to come with 11 channels of on-board amplification. Denon says that the X6300H’s amplification stage is a monolithic design with custom transistors. Each channel is rated at 140 watts into 8 ohms with 2 channels driven. That means that the X6300H can drive a full 11-channel, 7.1.4 immersive audio setup without any further amplification needed. However, if more power is needed, the AVR-X6300H offers 11.2CH preouts so you could literally use it as an AV preamp along with external amplification.
http://www.audioholics.com/av-receiver-reviews/denon-avr-x6300h-avr-x4300h-preview-1
τελικά έχει multichannel input ο 6300 ή οχι;
αξιζει η αγορά του ή εχουν βγει καινουργια καλυτερα μοντέλα; οχι απαραιτητα απο denon..
μέχρι 2500€ ποιον θεωρείτε τον κορυφαίο ενισχυτή;
Γιατι 2500 ; 1650 εχει mediamarkt black friday
αλλο ρωτάω..
ποιον ενισχυτή μέχρι 2500€ θεωρείτε κορυφαίο ενισχυτή και θα αγοράζατε;
καλο θα ηταν να υπαρχει δυνατότητα σύνδεσης και 2 ενισχυτή, για καλυτερη οδήγηση (τουλάχιστον των front speakers), αν πάμε σε 11 ηχεία μάλλον σίγουρα θα χρειαστεί.
ευχαριστώ!
melina
Cargo 200
αν σου ειναι εύκολο, μπορείς να εξηγήσεις τους λόγους;
τι παραπάνω εχει o marantz 7011 σε σχέση με τους άλλους;
ευχαριστώ
σου απάντησα ήδη δίπλα :)
susano lx90
Professional Home Cinema
οπως γραφω εχω προενισχυτη (avm60) τελικο 5καναλο (mca525) που οδηγει τα 5 κυρια ηχεια μου
αρα μου λειπουν ενας 5καναλος η 6 καναλος τελικος για τα υπολοιπα surround k οροφης ηχεια
και το auro 3d απο τον προενισχυτη μου
και ειπα μηπως με εναν πολυ καλο ολοκληρωμενο σαν αυτον και 2500ε εκανα την δουλεια μου
mix and match :)
η πουλας τον προενισχυτη που εχεις και παιρνεις με auro 3d;):D
Χα ειχε περασει κ αυτο απο το μυαλο μου
Αλλα οταν ειχα ρωτήσει τον φιλο μου τον Γ.Τσατσο που μου πουλησε ουσιαστικά τους anthem ποσο κοστιζει ο προενισχυτης του auro 3d μου χε πει ενα ποσο :o
Ετσι αντ' αυτου τελικα αγορασα και ενα 208 Diesel για να παρκαρω ευκολα στην πολη κ να μετακινουμαι οικονομικα
:D:D:D:dance2:
[DOUBLEPOST=1511468987][/DOUBLEPOST]
αλλο ρωτάω..
ευχαριστώ!
Δες προς integra :)
JAndronikos
