Denon Av A10se
Ενισχυτής AV Denon A10SE σε άριστη κατάσταση. Ο ενισχυτής είναι αγορασμένος το 2001 από γνωστό κατάστημα του χώρου. Είναι σε χρώμα σαμπανιζέ. Υπάρχει το κουτί του καθώς και όλα τα Manual. Επιγραμματικά αναφέρω ότι είναι 5 Χ 125W και THX Ultra. Όποιος ενδιαφέρεται παρακαλώ ας μου στείλει PM για να συμφωνήσουμε σε μία τιμή. Ο ενισχυτής έχει αγοραστεί 1900 Ε. Ακολουθεί πίνακας με τα χαρακτηριστικά του.
THX Ultra Specification and Equal Power Front 125 W + 125 W, Centre 125 W, Surround 125 W + 125 W
Robust Power Supply
New D.D.S.C. (Dynamic Discrete Surround Circuit) - Digital
Dual Analog Devices SHARC 32 Bit Floating Point DSP
24 Bit, 96 kHz D/A Converter For All Channels
THX Ultra & THX Surround EX, For Accurate Movie Soundtrack Reproduction
THX Surround EX Auto Mode
Assignable Power Amplifier Configuration
Widescreen 7.1 Channel Playback of Conventional Sources - A Denon Original Technology
Dual Surround Mode Speaker Selection
6-/8-channel External Inputs For Future Sound Format Upgrade Capability
Wide-Range Play Capability For Next-Generation Audio
Component Video Switching Capability
On Screen Display
Programmable Learning Remote with Installed IR Codes
The AVC-A10SE continues Denon's heritage of innovation by incorporating Lucasfilm's THX Surround EX decoding, another world first. Optimized for the latest in DVD soundtracks and for future audio formats, the AVC-A10SE brings a new level of sonic performance in home theater A/V Amplifiers. THX Surround EX, developed jointly by Lucasfilm and Dolby, made its debut in movie theaters with the release of the movie "Star Wars - Episode 1: The Phantom Menace". Featuring a specially-encoded 5.1 discrete soundtrack, the THX Surround EX function includes a center back surround channel in addition to the left surround and right surround channels, providing heightened spatial realism and more convincing surround imaging. Now that Surround EX-encoded movies are available for home theater playback, the AVS-A10SE's THX Surround EX function provides thrilling home theater surround sound reproduction. Compared to simpler and less accurate "6.1" unlicensed simulations, the AVC-A10SE's accurate THX Surround EX decoding function provides the full suite of required decoding parameters, and can be automatically or manually selected, according to the program material characteristics. In addition, the AVC-A10SE surround decoder is DTS ES-compatible, along with accurate decoding of Dolby Digital and DTS 5.1 channel soundtracks, with or without THX 5.1 post-processing. For THX Surround EX operation an additional power amplifier such as the POA-T10 is required. This can be set via the AVC-A10SE to power either the front Left and Right (recommended mode) or the "Surround Back" channels.
Robust Power Supply
On Screen Display
Φώτη καλή σου μέρα. Θέλω να μου πεις την άποψή σου για τον AVC-a10se μιας και τον είχες στην κατοχή σου. Είχα τον Yamaha DSP-A1 και τον δούλευα μόνο σαν στέρεο δικάναλο. ¨Ηταν απίστευτα βαρύς, μουσικός, ζεστός, γεμάτος και τρελά διαυγής. Απόλυτα φτιαγμένος για ακουστικές μουσικές. Blues, jazz, latin, κλασσική. Θα τον αγόραζα πάλι !! Στα ίδια σημεία ο AVC-a10se πώς συμπεριφέρεται ? Γλυκύτητα, ζέστη στα μπάσσα, μουσικότητα ? Θέλω τη γνώμη σου. Ευχαριστώ,
τον εχω στην κατοχη μου ακομα,ηταν ο πρωτος AV που ειχα παρει.Ακουω πολυ μεταγενεστερους που βγαζουν προβληματα στην πλακετα ηχου,στην πλακετα HDMI,στην μια εξοδο,στην αλλη.Τον εχω πανω απο 15 χρονια και παιζει μια χαρα (στην κρεβατοκαμαρα μεν) αλλα δεν μου παει η ψυχη να τον δωσω για 150 ευρω.Αν τα ηχεια σου ειναι ευκολα,δεν θα εχεις προβλημα ουτε στην οδηγηση ουτε στην "μουσικοτητα".Τωρα βεβαια δεν τυθετε μετρο συγκρισης με το να βαλεις τελικο επανω.Ηταν ομως απο τα μηχανηματα που ειχν φτιαχτει για να παιζουν και να αντεχουν.Αν το μπατζετ σου ειναι χαμηλο,μια χαρα θα κανεις την δουλεια σου
Ευχαριστώ για την πληροφόρηση. Ρωτάω μόνο για την άποψή σας σχετικά με την χροιά του ήχου. Δεν θέλω να αγοράσω τον ενισχυτή της αγγελίας. Γνωρίζω ότι η καταχώρηση είναι πάρα πολύ παλιά. Αν κάποιος άλλος έχει γνώμη για τη χροιά, ευχαρίστως να την ακούσω. Γεια σας φιλιά σας και αέρα στα πανιά σας :gamer: φιλούσκια !
Η χροιά ,χροιά δεν έχει και χαρά στον που την έχει!
[DOUBLEPOST=1511862554][/DOUBLEPOST]
Η αγγελία είναι σχεδόν δεκατριών χρόνων. :)
Και δεν έχει και τιμή πώλησης.
Τι κάνουν οι μοντεράτορες επί 13 χρόνια?
Μόνο να φωνάζουν στους βοηθούς τους ξέρουν...
petepappas
αυτοι οι ενισχυτες ειναι τελεια λυση για οποιoν εχει htpc κ δινει αναλογικα 5-7.1 απο εκει αρκει να εχει ρευματα οπως ο a1se-a1sr-ax10-ax1
Nickk
