AUDIONET AMP II G2 Monoblocks
Audio Harmony
Audionet AMP II G2 2x200 Watt RMS Monoblocks 11 years 2 months old,
ελαχιστα και πολυ προσεκτικά χρησιμοποιημένοι σε smoke free περιβάλλον.
2.750 € pair ( 7.800 αρχικη αγορας, 10.900 current model)
E76664D3-549B-4879-ADBD-029A9C39A648.jpeg 01FF57F4-0A5A-4BA2-9AFB-454FC15D694B.jpeg 6B6C8030-50B1-4FEB-B93A-ED4FB9723AAA.jpeg 11553024-8EC7-4230-A9B2-D1C2108F9298.jpeg
o 350 Watts into 4 ohms
o 550 Watts into 2 ohms
o 750 Watts into 1 ohm
Damping factor
o > 1800 at 10 kHz
o 10.000 at 100 Hz
Signal to noise ratio o 110 dB at 10 Veff
Intermodulation o < -110 dB SMPTE 100 Hz: 20 kHz, 4 : 1, 50 W/4 ohms
THD + N o < -105 dB at 1 kHz, 35 Watts into 2 ohms between 20 Hz and 20 kHz
Harmonic distortion
o k2 typ. -117 dB for 25 Watts into 4 ohms
o k3 typ. -140 dB for 25 Watts into 4 ohms
Review:
Sound Balance:
Neutral.
Resolution: World class. Very detailed throughout the whole spectra but not at the expense of the music.
Transparency: Crystal clear like a mountain creek, as we say in Sweden.
Treble: Very detailed. It feels almost like there is no stop in that high frequency. You will also be able to hear that sparkling top.
Midrange: Very natural. Voices are filled with body. Piano is presented in an unstrained way.
Lower register/Bass: The words that come to mind will be control, modulation and impact.
Dynamics: This is one of the strong points. The dynamic will even scare you if you are not prepared.
Soundstaging is exceptional. It gives 3D a new meaning to me.
Visceral impact: This is the truth and nothing but the truth. Listening to a full-scale classical concert will give you goose bumps. The impact of those entire instruments playing together in a crescendo is something I hope everyone will experience some day.
Manosmathiou
