Και Bruno Putzeys's Hypex class-D και λάμπα προ, καλός εικάζεται
Z
Zdimis
Rogue Audio Sphinx: $1395 $$$
The Sphinx is that rarity in contemporary audio: a US-made integrated amplifier with a tubed (12AU7) line stage, a MM-appropriate phono stage, and a headphone jack, all for less than the price of a round-trip ticket to Paris—and Rogue Audio doesn't even make you buy their remote handset ($100). Using Bruno Putzeys's Hypex class-D power modules in tandem with a nonswitching power supply, this hybrid integrated delivers 100Wpc into 8 ohms or 200Wpc into 4 ohms. HR enjoyed his time with the Sphinx, noting its "greater scale and bass force" than his Creek 4330 integrated, and praising its line stage as perhaps "the best of [its] many good features: Everything I played was enjoyably detailed, transparent, and spacious." HR's verdict: "Judging by my experiences with the Sphinx, Rogue's owner and designer, Mark O'Brien, has taken this stigmatized, lower-class mode of operation to a new, more refined level." According to JA, apart from a bit of ultrasonic noise in its output, the Sphinx's amplifier section avoided most of the usual class-D pitfalls, and he particularly praised the MM phono section. 2017 version has upgraded components. (Vol.37 No.8 WWW)
Read more at https://www.stereophile.com/content...integrated-amps-receivers#WADohvfQ3iioz5JZ.99
Σοβαρα τωρα λετε να υπάρχει μεγαλύτερο κελεπουρι στο 1,5 χιλιαρικο?
Yπάρχει και αυτός https://www.nordacoustics.co.uk/nord-one-int-a-integrated-amplifier με NCore NC252MP 2Χ200 βατ στα 8Ω!
Z
Zdimis
θελουμε κ λιγη λαμπα για εκουαλαιζερ.αυτος αν βγει στεγνος δεν μπορεις να παιξεις.
Γιατι, δεν εχει εκουαλαιζερ το σοφτγουερ που χρησιμοποιείς;
Εκτός αν εννοείς “εισαγωγέα παραμόρφωσης”, και όχι equalizer :D
Z
Zdimis
Εισαγωγεα παραμορφωσης εννοω λαμβανομενης ευχαριστα ωστόσο,ανάλογα και με την ηχητική υπογραφή ης καθε λυχνιας (της διαφορετικης παραμορφωσης που εισάγει στο σήμα αν θέλετε να ακριβολογούμε).Τωρα οτι οπου μπει λάμπα ο όγκος μιας ορχηστρας ,ενος οργανου κλπ μεγενθυνεται κανοντας το αποτελεσμα πιο πειστικό απο πλευράς "μεγεθους" ειναι κατι που πολλοί ευτυχώς δεν θα αντιληφθούν η θα αντιληφθουν με τροπο που δεν τους κανει να το προτιμουν, ειναι θέμα αισθητικής.
Σαν να βαζεις πρασινα γυαλιά ηλίου για να δεις προβολέα ενα πράγμα. Αν σου αρέσει να τα βλέπεις πιο πράσινα, ναι, γιατί οχι. Ειναι θέμα αισθητικής.
Μαζί σου.
Ημίθεος
στεγνός! Νέος όρος για ενισχυτή αυτός;
Τς τς τς!, πώς φαίνεται ότι είσαι νιούμπης! :p Ο όρος εισήχθη τη χρυσή -για τους χαϊεντάδες- 10ετία του '90, και εξακολουθεί να χρησιμοποιείται. Όπως και η κλινικότητα, που την είχαν κολλήσει ως ρετσινιά στα ATC.
Για μισό λεπτό, έτσι στο ντούκου θα περάσει αυτό;
Λάμπες με class-D έφτιαξε ο άνθρωπος!
Δεν θα διαρρήξετε τα ιμάτιά σας;
Προενισχυτή με λάμπες.....και τελικό στάδιο class D....δεν είναι ούτε ο πρώτος ούτε ο τελευταίος που χρησιμοποιεί τέτοιο συνδυασμό
Δυο τραγουδίστριες, Κάρμεν-Μελίνα, δεν μπορεί, καλό θα είναι το πρόγραμμα
Z
Zdimis
Προενισχυτή με λάμπες.....και τελικό στάδιο class D....δεν είναι ούτε ο πρώτος ούτε ο τελευταίος που χρησιμοποιεί τέτοιο συνδυασμό[/QUOTE
για δωσε καποιο προιον λοιπόν,με λάμπα προ και class d τελικο που να δινει και 100 βατ -και δεν ειναι απλά class d ειναι του γκουρου υλοποιηση.
Μπορείς να χρησιμοποιήσεις τελικό class D οποιουδήποτε γκουρού θέλεις και έναν λαμπάτο προενισχυτή της αρεσκείας σου..αυτό εννοώ
Z
Zdimis
ετσι οπως τοπες ειναι σα να υπήρχαν δεκα προτασεις ετοιμων προιοντων σεταρισμεμα ο προ για τον τελικο και τουμπαλιν.Δεν ειναι το ιδιο να αρχισεις τα μαγειρεματα με διαφορετικες συσκευες προ και τε καθως οι επιμερους ευαισθησιες εισοδων εξοδων κλπ παραμετροι ΠΑΝΕ ΣΤΗΝ ΤΥΧΗ.
Ή μπορείς να κατουρήσεις έναν ενισχυτή του Μπρούνο, για να πάψει να είναι στεγνός.
Να τονε'πάρουνε τα ζουμνιά.
[DOUBLEPOST=1521823597][/DOUBLEPOST]
Ναι, ναι, ο κλινικός ήχος.
Κλινική σκέφτεται ο άλλος, δε θα είναι για καλό.
Κάποιος θα έχει αρρωστήσει, γιατροί, σύριγγες, φάρμακα γενόσημα, άσε, μακριά.
Νταχτιριντάδικο ήχο έχετε κύριε; Τίποτα σε σοκολάτα υγείας; Λες κι αν τη φας από άρρωστος γίνεσαι υγιής. Σοκολάτα υγείας. Τι μ@λακία όνομα θεέ μου. (Κόγια, εσένα λέω)
gonis
Luger
Και τα κρελλ ξυριζαν,κόντρα αν συνδυάζονταν με ΑΤC που ήταν σύνηθες λόγω και του ίδιου αντιπροσώπου:D
Z
Zdimis
εχετε μια αδυναμια καποιοι να αποδεχθειτε οτι ενα χ ηχητικο αποτελεσμα μπορει καλιστα να περιγραφει με λέξεις.Ναι κλινικα ειναι τα atc ,αυστηρα επίσης.Σε ενα chario delphinus διπλα το atc 11 ακουγεται κλινικο κ στεγνο.Νομιζω?
Εγώ νομίζω ότι το ATC ακούγεται νορμάλ, σωστά, γλυκά και με προδέρμ.
Το άλλο παίζει ό,τι θέλει, τονίζει τα μεσαία και λίγο τα μπερδευει, έχει κι ένα φούσκωμα στα ανώτερα χαμηλά, αν θυμάμαι καλά. Κάπου έχει γίνει ένα λάθος, αν ακούσεις το ATC δίπλα του, θα το καταλάβεις εύκολα..
Grigoris1966
