Ypsilon Electronics Hyperion monoblock power amplifier
Mr Spock
demokratischer - sektor
Michael Fremer | Mar 22, 2018
Designers of hybrid amplifiers can use solid-state devices in an amp's input stage and tubes in its driver and output stages, as Music Reference's Roger Modjeski did in his RM-200 Mk.II—or they can use tubes in the input and transistors in the output, as Ypsilon Electronics' Demetris Baklavas prefers . . .
Description: Hybrid monoblock power amplifier. Tube complement: one 6H30 Pi or 5687 (input), one 6CA4 or EZ81 (rectifier). Inputs: unbalanced (RCA), balanced (XLR). Output power at 1kHz: 370W into 8 ohms (25.7dBW, (first 100W in class-A), 650W into 4 ohms (25.1dBW), 1150W into 2 ohms (24.6dBW). Frequency response: 6Hz–80kHz, –3dB (input transformer peak: +2.5dB at 50kHz). Voltage gain: 26dB (x20). Input impedance: 47k ohms. Output impedance: 0.3 ohm. THD (1kHz into 8 ohms, 6H30 Pi tube): 0.7% at 100W, 1.2% at 300W. THD (1kHz into 8 ohms, 5687 tube): 1% at 300W. Signal/noise: N/S.
Conclusions
Ypsilon Electronics' Hyperion is a powerful, cannily designed, exquisitely voiced monoblock power amplifier. Inside and out, its construction quality is as impressive as it should be for $93,000/pair. Because of its tubes, its distortion spec of 0.7% at 100W into 8 ohms will probably freak out the measurement fetishists, to whom I say: Just listen to it, and keep in mind that the tube microphones used in the making of many of your favorite recordings probably measured similarly.
The Hyperion strikes the ideal balance between tube-amp richness and flow and solid-state quiet, authority, and dynamic swagger. And it does this without making you conscious of each technology's contribution to the whole—something I felt that Ypsilon's far less expensive Aelius didn't manage quite as well.
https://www.stereophile.com/content/ypsilon-electronics-hyperion-monoblock-power-amplifier
http://ypsilonelectronics.com/newz/
dapost
Rehdeko & Harbeth lover
E, ξέχασες και τις μετρήσεις και το recommendation του JA :)
Εννοείται ότι αγαπάμε την Ypsilon και τη συγχαίρουμε για την παγκόσμια επιτυχία της!
Τιμή ξέχασες ....
Για προσγείωση ....
Conclusions
It did meet its specified power when I relaxed the definition of clipping to between 1.4% and 2% THD+N, but these are disappointing results.
Read more at https://www.stereophile.com/content...er-amplifier-measurements#dSDwibaaMv8uBL0k.99
Of more concern in these graphs is the Hyperion's linear increase in distortion with increasing power output above a few hundred milliwatts. While the THD+N percentage remains acceptably low below 10W or so, above that power, and especially at low frequencies, it reaches levels that will be audible with continuous pure tones (fig.6)
I have no reason to believe that this sample of the Ypsilon Hyperion was broken and my measurements are not out of line with its specifications. Given that, it is not an amplifier that I would recommend, especially given its price. While I have found that power amplifiers tend to sound different from one another, I feel they should be engineered to be as close to neutrally balanced as possible, and not designed to produce a "tailored" sound, as the Hyperion seems to be.John Atkinson
Kotsidis John
Photography
Προφανως και θα ναι ετσι κουρδισμενος, θελω να πιστευω.
Αρχιστε να βαρατε τωρα με τις μετρησεις και τις παραμορφωσεις, αν κ δε νομιζω να πτοηθουν...
Εξαλλου, τι ποσοστο αγοραστικου κοινου να υπαρχει αναμεσα μας;
0.5 % και αν ;
T
Tadakis
Τους έκραξε αν και σώστα τα λέει. Βέβαια αν ήταν Parasound ή άλλο αμερικάνικο 'φιλικό' προιόν θα τα έβλεπε με άλλο μάτι...
deleted user 10898
δεν ειναι κουρδισμένος Γιάννη... τυπική εικόνα μετρήσεων πολλών high-end ενισχυτικών...(όχι ότι δεν υπάρχουν χαι που να μετρούν άριστα αλλά γενικά....)
μα βρε καλέ μου αν θες hi end τι τα θες τα Pdf και τις μετρήσεις?
και αφού σχολιάζεται... όπως σωστά παρατήρησε και ο tadakis... τι έπαθε ξαφνικά ο atkinson και σχολιάζει έτσι όταν σε άλλα αντίστοιχων μετρήσεων όλα τα έβγαζε μέλι γάλα? ε? (όλα εγώ θα σας τα αποκαλύπτω?)
A
AKARL
0.5 % και αν ;
Έτσι, πες τα χρυσόστομε!
Εγώ θα πσηνόμουν να τσι τζιμπήσω τσι μονομπλόκους!
Γιατί όχι; Επαρκείς φαίνονται για τα ηχεία μου, με μνιά υποπσία χέντρουμ για καβάντζα, με πσιλοκαλές μετρήσεις για λαμπάτα μηχανάκια, νταξ πρέπει να καίνε πολύ ρέβμα αλλά δε μπορείς να τα 'χεις όλα ... Ιλ γκούστο περφέττο.
Δυστυχώς, όμως, έχω ήδη πσωνίσει καλύτερο εργαgλείο και αν με πχιάσει η upgradentitis μου θα πάρω τον 2502.
Λογική και νοημοσύνη ψόφχιας κάμπγιας και βγάλε.:p:D:lol:
Αϊ λοβ χάι εντ! :lolsign:
Χαχαχ τι λες ρε blasphemer? :roflmao: Ο δικός σου είναι καλύτερος από αυτά τα εκπληκτικά μονομπλόκια των 93k? :dance2:
dapost
Βλεπω τωρα στη DW τον γερο Chris Rea. Ωραια γρατσουναει την κιθαρα του. Η παραμορφωση της πρεπει να ειναι γυρω στο 50%. Αλλα πολυ το φχαριστιεται και αυτος που παιζει και εγω που τον ακουω! :geek: Κατι ξερει ο Φρεμερ, μη διαβαζετε Ατκινσον!
Με το μπαρδόν...
Από τα 8 Ωμ στα 4 αύξηση ισχύος κατά 1,75.
Από τα 4 Ωμ στα 2 αύξηση ισχύος κατά 1,77.
Κάτι πρέπει να αναθεωρηθεί.
A
AKARL
Ναι ρε συ. Ο δικός μου τέτχοια τραγούδια τα παίζει άνετα και όπως προβλέπεται. ;)
Οι μονομπλόκοι με τέτχοιο υλικό πρέπει να κλ@νουν Σέρτζιο Μέντες... :stinker: :D
[DOUBLEPOST=1521836513][/DOUBLEPOST]
Μετρημένα στο 1ΚΗz!
However, as figs. 3–5 reveal, at our usual definition of clipping, at which the THD+noise reaches 1%, the Hyperion delivered 239W into 8 ohms (23.8dBW), 400W into 4 ohms (23dBW), and 315W into 2 ohms (19dBW).
Και αυτά μετρημένα στο 1ΚΗz!
Λαμπάτη συμπεριφορά!
Μετρημένα στο 1ΚΗz!
Με το μπαρδόν...
Είναι αδύνατον ένας ενισχυτής να έχει μεγαλύτερο συντελεστή αύξησης ισχύος από τα 4 στα 2 Ωμ, από ότι έχει από τα 8 στα 4.
Είναι σαν να λέμε <<Όσο ποιο πολύ τρέχω, τόσο ξεκουράζομαι>>.
A
AKARL
Έτσι νομίζεις εσύ.
Ο ίδγιος ο κατασκευαστής δίδει τα εξής χαρακτηριστικά ισχύος:
Άρα, σύμφωνα με τον κατασκευαστή, οι συντελεστές αύξησης ισχύος είναι αφτοί που αναφέρεις. Είναι χαϊέντ τα μηχανήματα λέμε γιαφτό και κοστίζουν 93Κ $! Τι δεν καταλαβαίνεις πχιά;
Σύμφωνα, όμως, με τις μετρήσεις του Άτκινσον "the Hyperion delivered 239W into 8 ohms (23.8dBW), 400W into 4 ohms (23dBW), and 315W into 2 ohms (19dBW)".
Δηλαδή:
Από τα 8 Ωμ στα 4 αύξηση ισχύος κατά 1,67.
Από τα 4 Ωμ στα 2 "αύξηση" ισχύος κατά 0,79. :rofl:
Λαμπάτη συμπεριφορά σε λέω ... Άμα τα ακούσεις, όμως, θα καταλάβεις ότι παίζουν πολύ πάνω από τα λ7 που ζητάνε! :roflmao::roflmao::roflmao:
  • rose.athens
hatzopou
