Yamaha CX-A5000, 11.2 ch Preamplifier, black, αψογος, με το κουτι του
LUXMAN
Yamaha CX-A5000 black μονο 1200 ευρω. Σε απολυτα αριστη κατασταση , χωρις αμυχες , με το κουτι του , με το τηλεκοντρολ και το μικροφωνο σε επισης αριστη κατασταση. Η τιμη ειναι αδιαπραγματευτη.
Για οποιαδηποτε πληροφορια 210 3828281 , 210 3811720 , κος Μαρινος , 9:30πμ με 4:00μμ
Absolute Quality, Absolute Realism.11.2-channel AV Pre-Amplifier at the pinnacle of the AVENTAGE Series. Superb sound quality combined with fine craftsmanship ensures an unequalled listening experience. Latest technologies include high rigidity chassis, ESS DACs and reliable balanced connection.
  • AVENTAGE Concept 11.2-channel pre-amplifier
  • XLR balanced connection (11-channel pre-out and 2-channel input)
  • ESS 9016 DAC for all channels including front and rear presence channels
  • Cinema DSP HD3 with 33 DSP programmes
  • High density presence and richly detailed sound ensured by high sound quality parts and design
  • Specially designed high rigidity chassis eliminates the effects of vibration for greater sound purity
  • MHL supports full HD video and audio from mobile phones and portable devices
  • Network functions such as AirPlay, Napster®* music streaming service (*Music service availability varies by region.)
  • AV Controller app for operating various functions from a smartphone or tablet
  • FLAC or WAV 192kHz / 24-bit audio playback
  • 4K Ultra HD Pass-through and Upscaling
  • Yamaha video processing optimises video content
  • High-resolution Music Enhancer further heightens musicality from the original content
  • Advanced HDMI Zone Switching allows unprecedented AV switching to multiple zones
  • HDMI (8 in [1 on front] ) / 2 out) with 3D and Audio Return Channel
  • YPAO R.S.C. (Reflected Sound Control) sound optimisation with multi-point / speaker angle measurement
  • Full LED Backlight Learning and Preset Remote Unit
  • Versatile Zone control up to four Zones including party mode
  • Handy trigger control
CX-A5000
AV Receiver
Surround Sound Processing
CINEMA DSP Yes (HD3)
DSP Programs 33
Dialog Level Adjustment Yes
Virtual Presence Speaker Yes (with Virtual Rear Presence Speakers)
Dialogue Lift Yes (no presence speakers required)
SILENT CINEMA / Virtual CINEMA DSP Yes
Dolby TrueHD Yes
Dolby Digital Plus Yes
Dolby Digital Yes
Dolby Pro Logic IIx Yes
DTS-HD Master Audio Yes
Audio Features Pure Direct Yes (with video on mode)
Compressed Music Enhancer Yes
High-resolution Music Enhancer Yes
YPAO multi-point measurement Yes with R.S.C. (Reflected Sound Control) and Angle measurement
Adaptive DRC (Dynamic Range Control) Yes
Initial Volume & Maximum Volume Setting Yes
A.R.T. Wedge Yes
Audio Delay Yes (0-500 ms)
192kHz/24-bit DACs for all channels Yes (ESS) 192kHz/32-bit DACs for all channels incl. presence speakers
Video Features 4K Ultra HD Pass-through and upscaling Yes
HDMI 3D passthrough Yes
HDMI Audio Return Channel Yes
Component upconversion Yes
HDMI upscaling Yes (Analogue to HDMI / HDMI to HDMI)
Video adjustment Yes
Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync Yes
Connectivity HDMI Input/Output 8 (front 1) / 2 (assignable for zone 2 / 4)
HDMI CEC Yes (SCENE, Device Control)
MHL Support Yes
USB Input iPod / iPhone / iPad, USB Memory, Portable Audio Player
Network Port Yes
AirPlay Yes
Front AV Input HDMI (MHL support) / USB / Analogue Audio / Optical / Composite
DC Out Yes
Digital Audio Input/Output: Optical 4 (front 1) / 1
Digital Audio Input/Output: Coaxial 3 / 0
Analog Audio Input/Output XLR Balance: 1 / 0, RCA Unbalance: 9 (front 1) / 1
Phono Input Yes
Component Video Input/Output 4 / 1
S-Video Input/Output 4 / 1
Composite Video Input/Output 5 (front 1) / 1
Multi-Channel Input 8ch
Preout XLR Balance: 11ch, RCA Unbalance: 11.2ch
Headphone Output 1
Tuner Section FM/AM Tuner Yes
User Interface On-screen display Graphical User Interface
SCENE SCENE PLUS (12 sets)
App Control Yes (iPhone / iPad / Android phone / tablet)
Web Browser Control Yes
Remote Control Unit Yes (Preset, Learning, Macro, Full LED Backlight)
Zone Control Zone 2 Audio Output Preout / HDMI
Zone 3 Audio Output Preout
Zone 4 Audio Output HDMI
Zone Video Output HDMI / Component / S-Video / Composite
Zone HDMI Yes (Advanced HDMI Zone Switching)
Zone B Output HDMI
Zone GUI Yes
RS-232C Interface Yes
+12V Trigger Output 2
Remote (IR) Input/Output 2 / 2
Party Mode Yes
General Standby Power Consumption (IR only) ≤0.3W (typical)
Auto Power Standby Yes
Dimensions (W x H x D) 435 x 192 x 448 mm; 17-1/8” x 7-1/2” x 17-5/8”
Weight 13.6 kg; 30 lbs.
LUXMAN
Τελικα δεν ειναι τελικη για παντα ! Τελικη των τελικων (τιμη) 1000 ευρω.
Όχι δεν είναι ατμος αλλά για ότι απορία έχεις καλύτερα να στείλεις pm γιατί πέρασε η μέρα και δεν επιτρέπεται το up από τους κανονες του φόρουμ.
Στις αγγελίες γίνεται το σώσε.
Υπάρχει 3 σελιδη αγγελία από σχόλια και όχι μόνο !!! εκεί οι νόμοι τον αγγελιών έχουν άβατο??
Όχι ρε συ απλά όταν γίνονται την ίδια μέρα με το up δε λεει κανένας τίποτα. Τώρα όταν βλέπω απαντήσεις του στυλ "έχεις pm" μου ανεβαίνει το αίμα στο κεφαλι πραγματικα. Δηλαδή αυτός έχει pm και καλά κάνει. Εμάς τι μας νοιάζει να το διαβάσουμε ότι του έστειλες pm και να πάει η αγγελία στη πρώτη σελίδα ξανα; Έλεος δηλαδη.
Διάβασε τον κανονισμό και μετά βρες ένα άβατο. ;)
Jiovani75
