387.37 kg - full , turntable !
Mr Spock
demokratischer - sektor
TechDAS Air Force Zero Turntable . . .
TechDAS debuted the Air Force Zero turntable at a recent (March 16th) event in Japan that commences a "world tour" for the 771 pound turntable (not including power supply and air pumps) that will make its American debut April 9th and 10th at The Audio Salon in Santa Monica California. It will next appear at Munich High End May 9-12th.
The base frame of stainless steel weighs 220 pounds. The platter base of extra super duralumin weighs 77 pounds while the combined weight of five (count them) five platters weighs 260 pounds. Broken down there's a bottom 66 pound platter of forged stainless steel atop which is a second forged stainless platter weighing 44 pounds, topped by one of gunmetal weighing an addition 44 pounds, topped by a fourth forged stainless platter weighing an additional 44 pounds followed by a top platter of powdered sintered Tungsten weighing 61 pounds.
Belt drive is via a 3 phase 12 pole AC synchronous limited edition German Pabst motor. An electric motor powers the built in air suspension system. There are three power supply/air pump units weighing a total of 83 additional pounds. Dimensions are: 35" (W)x26" (D)x13" (H).
https://www.analogplanet.com/conten...-debuts-if-you-have-ask-price-you-cant-afford
https://techdas.jp/
Naturally, you can dial in 33.3 rpm / 45 rpm, with a precise speed adjustment function. Wow & Flutter is stated at below 0.03%.
Holding all that up is an air suspension system provided by an in-built electric air pump.
https://www.stereonet.co.uk/news/techdas-air-force-zero-specifications
Κόγια; Έλα να κάνουμε πάουερ μπάι. Ένα γω, ένα συ.
Ο Μάρκου θα περιμένει το 400-αρι, Άστον αυτόν.
Πόσα λεφτά λες να θέλουν; Σε 12 δόσεις γίνεται;
Όχι ρε εγώ θα περιμένω να βγάλει η SANSUI.
Παρακαλώ προσπαθήστε να χαλιναγωγήσετε τον ενθουσιαζμό σας! Το μηχανάκι είναι αρκετά καλό, η τιμή του είναι της τάξης των 385.000$ και παίζει πολύ καλά για τα λεφτά του. Βέβαια, δεν μπορεί να φτάσει τον ήχο ενός άλλου πικάπ των 850.000$. Πόσο μάλλον κάποιου άλλου των 1.500.000$. Και βέβαια, υπάρχει πολύς δρόμος ακόμα για το σπάσιμο του ψυχολογικού ορίου των 100.000.000$.
Μη τα οισωπαιδώνουμαι όλα...
Mr Spock
Εγώ πάλι έχω πολλά λεφτά και το ποθώ διακαώς.
Όμως δεν έχω καταλάβει γιατί έχει δυο βραχίονες.
Για να δίνουμε τα διπλά για κεφαλές?
- "είναι θέμα οπτική γωνίας, όπως το βλέπεις ναι θα δίνουμε τα διπλά για κεφαλές, ,, αλλά γλιτώνουμε από δεύτερο πικάπ εάν θέλουμε να έχουμε στημένες δύο κεφαλές
Mr Spock
- λοιπόν να σοβαρευτούμε, και οι δύο κεφαλές είναι μονοκαναλικες οπότε σε συνδυασμό με buffer χρόνο καθυστέρησης, έρχονται ακριβώς σε δικαναλη φάση,
- το buffer χρεώνεται extra
Decembered
Μαϊμού
.. χαχα... ε μου χει παρει τα μυαλα...μια μελαχρινια ?!
σοβαρα τωρα, πανε και φτιαχνουν το "υπερτατο" και μετα το αναβαθμιζουν, γιατι δεν το εκαναν σωστα απο την αρχη ?
Alex_Zapantis
Και στο σύνολο 800 κιλά αηδία: :p
DAMBO
