darTZeel NHB-468 monoblock power amplifier
Mr Spock
demokratischer - sektor
The instruction manual avers that the amplifier should not be considered as either a theoretically ideal voltage source or an ideal current source, both of which, in addition to many flaws, have good qualities. To paraphrase the manual's "Franglish," a perfect voltage source has zero output impedance and in practical terms requires 100% negative and global feedback, which produces temporal (phase) distortion. An ideal current source has infinite source impedance, which is good for controlling a speaker's back EMF, but produces poorer measured performance and sound quality that is overly speaker-dependent. The company claims that the CP2C circuit produces an amplifier-to-speaker connection equivalent to the matched impedance links—the 50 ohm "transmission line" Zeel connection—that darTZeel uses between their NHB-18S preamp and its amplifiers.
The 468 is rated as outputting 475W RMS (550W peak) into 8 ohms, 625W (700W peak) into 4 ohms, and 222W RMS (300W peak) into 2 ohms. That's bound to raise some eyebrows, especially considering the massive power supply, with 750 joules of available energy. Power measurements for its predecessor, the NHB-458, are 530W into 8 ohms, 800W into 4 ohms, and 1025W into 2 ohms. Note that both amps use the same massive power supply, featuring one of the biggest power transformers I've encountered in an audio product, which floats on a suspended platform that's tuned to absorb frequencies between 40Hz and 70Hz.
Conclusion
The darTZeel owners I've met seem to be a happy, enthusiastic group, satisfied with their purchases and with the sound produced by whichever darTZeel products they have. Count me among them. The new NHB-468 has made me even happier. This amp does what the NHB-458 does—just better. It's got power to spare and sounds as if it's just loafing, even on the most demanding material.
I haven't seen the measurements and won't until I see the final proofs of the finished article, but I assume the distortion measurements will be good but bettered by some. I believe Delétraz is capable of reducing distortion to as low as is measurable, but he's going for something beyond measured perfection, and I think he's achieved his goal in terms of a unified, holistic, natural sonic pictur
frequency response at 2.83V into: 16 ohms (gray), 8 ohms (blue), 4 ohms (magenta), 2 ohms (red) (0.5dB/vertical div.)
distortion (%) vs 1kHz continuous output power into 8 ohms.
Description: Solid-state monoblock power amplifier. Inputs: one unbalanced (RCA); one unbalanced Zeel (BNC); one balanced (XLR). Output power: 475W (26.8dBW, 550W peak) into 8 ohms, 625W (25.0dBW, 700W peak) into 4 ohms, 222W into 2 ohms (17.45dBW, 300W peak)—"design limited because CP2C power is delivered differently into speakers than when statically measured." Voltage gain (user selectable): 26 or 32dB into 8 ohms. Input impedance: >30k ohms, (RCA); 50 ohms, ±1 ohm (Zeel); 10k ohms per phase (XLR). Output impedance: <0.28 ohm, 20Hz–20kHz (into 8 ohms). Frequency response: 0.7Hz–700kHz, +0/–3dB; 20Hz–20kHz, +0/–0.2dB. THD: <1%, 7Hz–77kHz. Signal/noise: >115dB, A-weighted, ref. nominal power. Risetime: 0.9µs. Slew rate: >200V/µs, peak-peak. Temporal distortion: "none, at any level and load as specified above." Power consumption: 2W in standby, 40W at idle, 2kW at maximum output power.
Dimensions: 18" (460mm) H by 11" (277mm) W by 20" (511mm) D. Weight: 154lb (70kg).
Serial numbers of units reviewed: TZ-UE1468.010L/R.
Mr Spock
Για να καταλαβετε σε ποιους απευθυνονται...
- είναι πανάκριβος . . . λογικά θα απαρτίσει συνδετικό κρίκο σε σύστημα εκατομμυρίου . . . άρα μάλλον θα απευθύνεται σε κάποιον που έχει λεφτά για τα οποία δεν κουράστηκε να τα αποκτήσει , σε κάποιον ''φανφαρόνο'' , σε κάποιον που θέλει να ζήσει το παραμύθι του . . . σίγουρα όχι στον μέσο μουσικόφιλο
- κάποιες φορές τέτοια μηχανήματα είναι απλά ακαδημαϊκές ασκήσεις τεχνολογίας και μόνο ( υποθέτω , δεν έχω τις κατάλληλες γνώσεις )
Βρε παιδιά αυτό είναι χρυσο-κόκκινο....
Σαν κουτί με σοκολάτες ελβετικές.
Κ όμως
Υπάρχει εδώ ζευγάρι μονομπλοκ με μετατροπή για ακουστικά .
Το άσχημο είναι ότι έβαλε την μάνα του να πουλήσει χωράφι για να τα πάρει...
Δεν ξέρω ποιος είναι πιο τρελός αυτός η η μάνα του ...
Mr Spock
. . . Το άσχημο είναι ότι έβαλε την μάνα του να πουλήσει χωράφι για να τα πάρει...
- σίγουρα όχι ο κατασκευαστής
.. εγινε μετατροπη και στα ακουστικα ?! να παιρνει το καθε ενα ακουστικο απο διαφορετικο μπλοκ ? ή μισες δουλειες?
Ναι
Του έστειλε τα ακουστικά κ τροποποιήθηκαν για αυτά οι μονομπλοκ
Πως προκύπτει ότι αυτός που έχει λεφτά δεν κουράστηκε να τα αποκτήσει? :eek:
Γιατί άν είχε κουραστεί να τα αποκτήσει δεν θα τα ξόδευε σε τέτοια μηχανήματα, εκτός και αν ήταν καμιά εκκεντρική γκόμενα.
Mr Spock
- δεν προκύπτει , αναφέρομαι σε συγκεκριμένους πλούσιους που δεν κουράστηκαν για την απόκτηση της περιουσίας τους . . . κληρονομιές , απάτες , λότο κλπ . . . νομίζω πως ήταν σαφές
- αλλιώς θα έγραφα . . . άρα μάλλον θα απευθύνεται σε κάποιον που έχει λεφτά . stop
Για να πω και εγώ τη μπούρδα μου, αν ισχύει κάτι τέτοιο, τότε ισχύει και το οτι οι "εξωτικών τιμών" κατασκευάστριες εταιρείες (μηχανημάτων ήχου, εικόνας, μηχανοκίνησης, υψηλής ωρολογοποιίας κ.τλ.) απευθύνονται σε ένα πολύ μικρό target group:
- αυτών που έχουν κληρονομήσει περιουσίες,
- των bimbo που είναι πλούσιες
Μήπως να τους ενημερώσει κάποιος -και ταυτόχρονα να τους σώσει- προκειμένου να αλλάξουν το product+pricing mix ?
Τα λεφτἀ του ο καθἐνας, τα ξοδεὐει ὀπου και ὀπως γουστἀρει.
:idk:
Κἀποτε ο Κὀγιας αποροὐσε γιατἰ πἐταξα 28+12+8 = 48.000 €, γιἀ να πἀρω ἐνα πικἀπ
(Symphonic Line RG6 + Pluto 9A + VDH Colibri XPP) , ενὠ θα μποροὐσα να τα εἰχα χὠσει γιἀ μιἀ Mercendes. (η αγορἀ ἐγινε το 1994)
Προσπαθοὐσε ο καψερὀς να καταλἀβει, πιστεὐοντας πως ἐχει να κἀνει με λογικὀ ὀν !
:roflmao:
Το hi-end εἰναι αυτοσκοπὀς ὀπου εξαντλεἰται στο υπερφἰαλο γιἀ να καλὐψει ψυχολογικἐς ανἀγκες.
Τα συστατικἀ που περιἐχει, δεν στοχεὐουν παρἀ μὀνο στην ικανοποἰηση της ματαιοδοξἰας.
Η παγἰδα στἠνεται με το να πλασἀρονται ως μιἀ μορφἠ τἐχνης, ὀπου αυτὀματα αποκτἀ ἐτσι σκοπὀ και συγχρὀνως απενοχοποιεἰ το target group.
Δεν υπἀρχει λογικἠ. Εδὠ τα κριτἠρια βρἰσκονται σε ἀλλο κομμἀτι του εγκεφἀλου.
(αυτὀ με τις κλανιἐς)
:laugh:
Klipschlascala_pro1988
