Ενισχυτης ATOLL IN 30 SE
ATOLL. IN30 se Ενισχυτης HI - END Integrated, designed and entirely manufactured in FRANCE ,
ATOLL. IN30 directly emerged from the experience and background of our up-level models. It is a mix-up of all our savoir-faire for lovers of all kinds of music
Symmetric Scheme with discrete components MOS-FET transistors
170 VA toroïdal transformer
1,5 mm châssis steel
Connecting:
4 Inputs (CD, TUNER, DVD, AUX)
1 Tape Input (or by-pass);
1 jack Input (3,5mm) for media player;
1 headphones output (3,5mm) ;
1 preamp. Output ;
Main Functions:
Volume setup operated by digital command
Balance setup
Optional « wattmeter »
Electronic protection
The optional remote is the same as for SE series.
Technical Specs:
Power 2x50Wrms 8 Ohm 2x70Wrms 4 Ohm
Impulse Power : 90 W
Sensitivity : 280 mV
Rise Time 3µs
Power Supply : 170 VA
Total Capacity : 20 000 μF
Input Impedance : 220 kOhms
Bandwidth 5 Hz-100 kHz
Dimensions 425x270x80 mm
Κατάσταση Άριστη σαν καινούργιος ζήτημα να έχει δουλέψει λίγες ώρες
τον εχω τρίτο ενισχυτή ,
Ήχος καταπληκτικός με δοκιμή
Τιμή 260€ Τακης Τηλ 6956033668
roberto_portale
