ROTEL MICHI SERIES , Επιστροφή
Mr Spock
demokratischer - sektor
The Michi P5 Control Amplifier delivers the ultimate performance in audio processing with a full complement of analog and digital source inputs. Over 3 years in the making, every aspect of the P5 has been carefully crafted including the power supply, circuit design and critical component selection to ensure the highest integrity of the audio signal eliminating unwanted noise and distortion.
The Dual AKM 32-bit DACs feed the Class-A preamplifier circuit ensuring detail, accuracy and the highest musical fidelity while maintaining crucial rhythm and timing for all musical genre regardless of your listening style. These circuits are supported by an array of 17 independent voltage regulators driven from 2 custom designed and factory built toroidal transformers with low ESR smoothing capacitors to deliver ripple free current to all critical circuits.
Accuracy and detail are essential in reproducing audio and equality important is delivering music that is enjoyable and entertaining. The P5 excels in all aspects building on over 55 years of audio design experience. The bespoke in-house manufacturing facility ensures this preamplifier is built to highest of quality standards allowing it to proudly wear the Michi logo.
Automation and control system integration is easily supported with RS232 and Ethernet connections.
The Michi P5 includes MQA (Master Quality Authenticated) technology, which enables you to play back MQA audio files and streams, delivering the sound of the original master recording.
INTERMODULATION DISTORTION (60Hz:7kHz, 4:1)
<0.002%
INPUT SENSITIVITY
Line Level Inputs (RCA): 160mV
Line Level Inputs (XLR): 250mV
Phono Input (MM): 2.5mV
Phono Input (MC): 250uV
Digital Inputs: 0dBFs
INPUT IMPEDANCE
Line Level Inputs (RCA): 47kΩ
Line Level Inputs (XLR): 100kΩ
Phono Input (MM): 47kΩ
Phono Input (MC): 47kΩ
Digital Inputs: 75Ω
INPUT OVERLOAD
Line Level Inputs (RCA): 12V
Line Level Inputs (XLR): 12V
Phono Input (MM): 199mV
Phono Input (MC): 22mV
OUTPUT LEVEL
Unbalanced (RCA): 1V
Balanced (XLR): 2V
OUTPUT IMPEDANCE
Unbalanced (RCA): 470Ω
Balanced (XLR): 100Ω
CHANNEL SEPARATION
Line Level Inputs: >85dB
Phono Input: >55dB
TONE CONTROLS
±10dB at 100Hz / 10kHz
COAX/OPTICAL DIGITAL INPUT SIGNALS
LPCM (Up to 24-bit/192kHz)
PC-USB
USB Audio Class 1 (up to 24/96)
USB Audio Class 2 (up to 32/384)*
*Driver Installation Required
DSD and DoP Support
MQA Support
Post automatically merged:
The stunning control and authoritative power of the Michi M8 Monoblock Amplifier is the result of a perfect balance of science meets art delivering 1,080 watts of Class AB power into 8 ohms and an astounding 1,800 watts to the most demanding 4 ohm loudspeakers. The M8 is powered by a pair of custom engineered, low noise, in-house manufactured toroidal transformers supported by 4 British patented slit foil, high efficiency, low ESR bulk storage capacitors for impactful bass with exceptional control under extreme loading conditions.
To achieve accuracy and its unsurpassed performance, the M8 is equipped with an array of 32 high current output transistors thus reducing the load on individual components and maintaining the crucial energy, rhythm and timing throughout the amplification stages. Musical expression and detailed refinement were further accomplished through acoustic tuning of all critical components and a balanced circuit design.
A high resolution display adorns the front panel supporting a peak power meter or spectrum analyzer. With XLR and RCA inputs, 2 sets of custom Michi speaker binding posts, remote control and fully featured RS232 and Ethernet connections the M8 provides ultimate installation flexibility. Power amplification at its best in the most elegant of industrial designs.
<0.03%
DAMPING FACTOR
200
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
Unbalanced (RCA): 1.85V
Balanced (XLR): 3V
INPUT IMPEDANCE
Unbalanced (RCA): 12.5kΩ
Balanced (XLR): 100kΩ
The Michi S5 Stereo Power Amplifier is a best in class linear amplifier delivering 500 watts of Class AB power in 8 ohm and over 800 watts to 4 ohm loads. The dual monoblock architecture is equipped with twin, custom engineered oversized, in-house manufactured 2,200 Volt Amp toroidal transformers in individual epoxy filled enclosures eliminating noise and vibration. A bank of 4 British patented bulk storage capacitors totaling 188,000uF delivers exceptional bass energy while maintaining precise detail and control to 32 high current output transistors ensuring effortless accuracy of the timing and rhythm under even the most difficult of load conditions.
Audio performance must be engineered from product concept through production. This is evidenced in the S5 as the result of countless hours of engineering design reviews, critical component evaluation and sonic tuning. Accuracy at its best while delivering on a promise to ensure the audio provides entertainment deserving of the Michi logo.
An elegant industrial design puts the finishing touch on this amplifier with a font panel color display and Michi exclusive custom high current 5-way rhodium plated binding posts. The included remote control provides easy setup and operation with RS232 and Ethernet connections supporting all popular control systems.
<0.03%
DAMPING FACTOR
350
SPEAKER IMPEDANCE
4Ω minimum
INPUT SENSITIVITY
Unbalanced (RCA): 2.6V
Balanced (XLR): 4.2V
INPUT IMPEDANCE
CHANNEL SEPARATION
>65dB
. . . εδώ η ιστορία , το θρυλικό τους phono . . .
The PCB of the RHQ-10 is made of high-grade fiberglass with 0,1% and 0,01% tolerance metal film Vishay resistors in the signal paths, eq and NFB loop.
The first and head-amp stage is a triple parallel differential fully complementary push-pull ; the second stage is a passive pole low-pass filter ; the third is a low frequency boost and gain stage.
The output stage is a single-ended fully complementary push-pull circuit in Class A. Discrete components throughout.
One input is available, with two outputs : Fixed 1 is for connection to a passive controller or preamplifier which bypasses the volume control ; Variable is for going directly into a power amplifier ; Fixed 2 is for connection to a passive controller or preamplifier when using a moving coil cartridge of extremely low output.
The MM / MC gain & impedance selection however remains mysterious and rests on "an ingenious method to minimize any adverse effect upon sound quality often cause by mechanical switching" - anyone ?
Input sensitivity: 0.3mV (mm), 2.5mV (mm)
RIAA accuracy: 20Hz to 20kHz +-0.1dB
Output level: 0.775V
Total harmonic distortion: 0.005%
Signal to noise ratio: 75dB (mc), 90dB (mm)..............!!!
Overload: 30dB
Dimensions: 470 x 76 x 332mm
Weight: 6.8kg
jpaudio
High Class μηχανήματα (με high class τιμές φαντάζομαι...) με μια αίγλη που δεν έσβησε ποτέ, ακόμα και σήμερα. Τους ανεμιστήρες όμως τι τους θέλουνε; Είναι ζωρισμένος για 500 Watts δεν λέω αλλά γιατί δεν κάνουν το κουτί μεγαλύτερο ή με άλλο τρόπο ψύξης όπως παλιά με υγρό;
Φαινόμενα των καιρών Γιάννη.
Ισως και κάποιες περικοπές από τους Λογιστές. Θα έπρεπε να έχει πολύ μεγαλύτερες ψύκτρες για την ισχύ αυτή , χωρίς ανεμιστήρια. Και καθ ύψος και κατά μήκος. Ισως και διπλή επιφάνεια . Δεν θα τους έβγαινε σε λογικές διαστάσεις το κουτί.
Οσο για αυτό που λέει ο BHUTIA για απουσία λογισμικού διόρθωσης απόκρισης χώρου , είναι μάλλον κάτι εξεζητημένο στην στεροφωνία. Επειδή εμείς εδω ψειρίζουμε την μαϊμού δεν σημαίνει ότι το αυτό κάνουν και όλοι οι άλλοι στον κόσμο.
Ή θα μπορούσαν να χρησιμοποιήσουν Class D τεχνολογία και να μην ασχοληθούν καν με το πρόβλημα της ψύξης.
Αλλά, ναι, ξέχασα, η Class D, δεν είναι hi-end.
Υ.Γ.: "τη λέω" στη Rotel, όχι στον Γιάννη.
Κοίτα Γιώργο, δεν έχουν πεισθεί όλοι ότι η class D ως τεχνολογία είναι ώριμη και μπορεί να αντικαταστήσει την AB παντού. Δεν μπορώ να πω κάτι άλλο , από την στιγμή που εταιρίες σαν την rotel , την bryston, την accuphase και κάποιες άλλες ακόμα επιμένουν στην τάξη ΑΒ θεωρώ ότι κάτι ξέρουν παραπάνω . Δεν τους έχω για τόσο χαζούς να κάνουν τσάμπα τέτοιου είδους σχεδιάσεις και να χαλάνε ένα σκασμό λεφτά σε εξέλιξη νέων προιόντων χωρίς να έχουν κάνει κάποιες οικονομοτεχνικές μελέτες.
Τι να πω?
wnet
Nearfield
αυτή η Rotel..... ανικανοποίητο παιδικό όνειρο....
που πλέον δεν έχει πια καμιά σημασία (δίότι έστω και με κάτι vintage θα μπορούσα να το ικανοποιήσω...) αλλά εντούτοις συνεχίζει και ασκεί γοητεία πάνω μου... έτσι, χωρίς να έχει πάντα σοβαρό λόγο...
Ναι και αν κρίνω από τις διαφημίσεις τους και το όλο σκηνικό , δεν πρέπει να πουλάει και πάρα πολύ.
πολυ αντρικο το μονομπλοκι
βεβαια απο τοτε που το γυρισαμε στα ψηφιακα ειναι μονο για χαζεμα
Από σχεδίαση είναι πάρα πολύ καλά. Και από αυτά που λέγονται για την υλοποίηση επίσης.
Καλά θα ακούγονται. Και από γκάζια μια χαρά είναι. ΑΒ.
δεν αντιλεγω
ιαπωνικο κοσμημα
αλλα αναχρονιστικο για την εποχη που ζουμε.
πριν 5 χρονια πχ θα το βλεπα στον υπνο μου, σημερα το θαυμαζω αλλα μεχρι εκει.
εχουν
αλλα ΟΕΜ
nc1200 , nc2000
απο τα νουμερα καταλαβαινεις
ωστοσο το θεμα ειναι αλλο.
στα hypex χρειαζεσαι ισχυ ανα μεγαφωνο , οχι ανα ηχειο και δεν ταιζεις παθητικα κρος συν τοις αλλοις (πιο σωστα πλην τοις αλλοις :boast:)
δηλαδη αν εχεις να ταισεις κατι με 2χ15αρια + 2χ12αρια + 2χ7αρια + tweeter μπορεις "απλα" να βαλεις 7 modules και καθαριζεις.
χωρια που παιζει και η γεφυρα ειδικα στα μεγαλα μεγαφωνα.
JAndronikos
