Ισχύει το ίδιο με τα υπόλοιπα (πλην Shield) media players.Και τα Zappiti έχουν και atmos και dts:x. Eπίσης παίζουν τα πάντα και έχουν και netflix.
The Netflix App is not optimized for media players. For this reason we recommand to install it from another App which is called "Aptoide TV".
Please follow this procedure:
Setup of Zappiti Player 4K for Netflix
As the Netflix App doesn't use the Harware decoding, the Auto Framerate won't work on it that may cause some fluidity problems.
There is nonetheless a solution:
In the Video settings of the player ("Settings / Display/ TV System"), select 1080p@24Hz and check the 24p box.
Netflix will be smooth again!
Attention! Netflix resolution is limited at 720p.
