DD Turntables
Για αυτους που τους αρεσουν τα DDs. To link εχει αρκετες αναφορες σε καποια απο τα ποιο ιστορικα του ειδους.
Sony PS-8750
Sony's little big star for three short years, and part of the ES-II series, as grradually launched by Sony from 1974 onwards.
Its Magnedisc and X-tal Lock systems weren't really Sony (or Denon's or whoever's) inventions but the marketing tags were : the X-tal compares the reading of a barium-ferrite magnetic strip printed inside the platter's rim with a Quartz oscillator to further insure speed stability ; the system was featured on many Sony units from World receivers to the TTS-8000 and PS-X9 masterpiece.
The PS-8750 is also fitted with a special OL-2K mat containing a micron-thick plastic "skin" itself containing a very thick oil, an SBMC base (Sony Bulk Mold Compound), a separate motor for the tonearm's cueing, a big AC direct-drive motor and an even bigger power transformer (seems bigger than that of the TTS-8000...).
Other nice touches : the lid has an anti-static treatment (the white printed grid ; it really works), the output plugs are gold-plated and the arm's pivots rest on two sapphire bearings.
The fitted (and fixed) tonearm is a variation of Sony's own PUA-1600S
(S for short) version, a tonearm available a year before the 8750 but upgraded for the latter with a carbon-fiber tube ; the SH-160 dedicated headshell is also carbon-clad. When properly setup, this 1600S / 160 duet makes sonic wonders (do yourself a favor and use an MC cartridge).
Despite being quite expensive and marred by Sony's usual scant and scarce advertising for its high-end audio output, the PS-8750 sold very well, even in Japan - that's how good it was and that's how good it still is.
The total production run should be of 5000 units, less than half of which must be still alive today (if not even less).
Only one other component bears that "8750" name which was inherited from the TA-8650 's last prototyping stages : the TC-8750-2 (aka TC-880-2) - they both were and still are in the top league.
Ενα ακομα κορυφαιο απο μια εποχη που οι μηχανικοι των μεγαλων εταιριων διναν μαχη για το τελειο και την λεπτομερεια. Yamaha GT 2000
In 1982, the year that saw the debut of the CD, Yamaha's turntable lineup, up to then always following a high technology course, saw a new model that suddenly took analog back to its origin. This was the GT-2000 large heavyweight player, taking the GT part of its name from the first two letters of the words "Gigantic & Tremendous."
While its predecessor PX series had features like a state-of-the-art symmetrical linear arm and feather touch full auto mechanism, the new GT-2000 was a simple manual player with a conventional S-shaped long arm, not even having pitch control. With a density and accuracy on a par with solid wood thanks to a hot forging method, the turntable measured 374mm in diameter and weighed 5.8kg including a 300g rubber sheet. With a unique shape featuring a high outer edge it achieved a massive inertia of 1200kg/㎠. A powerful direct-drive motor boasting startup torque of 2kg/cm made possible a positive and negative two-way servo that could instantaneously apply torque in the opposite direction during both acceleration and deceleration, and when used with the external power supply sold separately it was possible to operate the electronic brake by using the main body power switch as in broadcasting equipment.
Because of the turntable's non-standard size it might be hard to understand its scale in the photograph, but the cabinet measured 545mm wide.
The rounded protrusions in the right front of the turntable were finger rests, positioned to prevent the palm from touching the edge of the large rotating turntable while lowering the needle.
The GT-2000 also made owners swoon with a range of attractive accessories that let them enjoy customizing their units with their own hands. These included the previously mentioned YOP-1 external power supply, the YAB-1 32kg anchor block that held the cabinet from the left and right, the YDS-1 disc stabilizer utilizing a brass platter and electric absorption pump, and the YSA-1/YSA-2 straight tonearm. Also on the accessories list was an 18kg gunmetal turntable that when installed to replace the standard turntable tripled its rotational inertia. The 120,000 yen price tag for this turntable was surprising enough, but a bigger deal was that the GT-2000's motor and bearings were tough enough to handle a turntable three times heavier.
At 138,000 yen (accessories separate) this unit's price could be called reasonable, helping it become a big hit as an analog player in the CD era. While expanding the series, production continued until 1989, and in 1991 it was reissued in a limited edition for 198,000 yen. The GT-2000 had a birch veneer black paint finish, while the GT-2000L model featured a walnut veneer finish and was equipped with an auto-lifter.
Ξερω οτι υπαρχει ελαχιστο ενδιαφερον για τα Direct drive του παρελθοντος. πλην του MK2 που εχει οπαδους σε ολο τον κοσμο αλλα αξιζει για οσους ενδιαφερονται να κανουμε ενα αρχειο με σπουδαια μηχανηματα που χαθηκαν στον χρονο. Οποτε βρισκω χρονο θα ποσταρω μερικα απο τα πικαπ που θα ηθελα να εχω αλλα μαλλον ποτε δεν θα αποκτησω. Οποιος θελει να προσθεσει κατι καλοδεχουμενος
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Ωραίο το ΥΑΜΑΗΑ.
Από τα παλιά μοντέλα πάντα μου άρεσε το JVC QL10
Λέγανε ότι μηχανολογικώς ήταν από τα πιο τέλεια πικάπ που έγιναν, αλλά δεν ευδοκίμησε στην αγορά όσο άλλα μοντέλα.
Συμφωνω απολυτα. Βασισμενο στο JVC TT 101 που μπορουσεw να το παρεις μεμονωμενα και να χτισεις το δικο σου πικαπ ή να παρεις καποια απο τις ετοιμες υλοποιησεις οπως το QL -10 ή to QL - 7
Ωραίο το ΥΑΜΑΗΑ.
[/QUOTE]
Οπως ειπα και νωριτερα οι μεγαλοι του χωρου διναν μαχη και ριχναν λεφτα στο R&D για να φτιαξουν το κορυφαιο. Πολλοι πιστευουν οτι ειναι αυτο
Kenwood L07D
Στα ορια της τελειοτητας και με μυστηριο ως προς την ομαδα σχεδιασμου του με φημες να θελουν Micro Seiki να κρυβεται απο πισω. Πληροφοριες στο καταπληκτικο Vintage Knob, αλλα και στο dedicated site που σας επισυναπτω. Προσωπικα νομιζω οτι η Kenwood που μας εδωσε την Accuphase με καταπληκτικα μηχανηματα και κατασκευες απο το 1960 κατι και μετα με το L07D και την αντιστοιχη σειρα ενισχυτων εφτασε στο peak της και μετα πηρε λιγο διαφορετικο δρομο
Και μια μικρη σταση στην Micro Seiki που γενησε τοσες καινοτομιες και τα προϊιντα της ηταν μερος πολλων αλλων προϊόντων των Ιαπονων κατασκευαστων της εποχης. Στα ορια του παραλογισμου με εως 4 tonearms για να αλλαζεις κεφαλες και να συγκρινεις...ή αναλογα με το κοματι και τις προτιμησεις σου. Ποιος ειπε οτι τα direct drive δεν ειναι audiophile. Παμε
DDX 1500
DDX 1000
Micro Seiki DQX-1000
MICRO SEIKI DQX-1000
Design Integrity -
These unique design concepts have been exhaustively researched and tested by our engineers. All the manufacturing and assembly stages conform to the highest quality standards in order to produce this definitive turntable system. The result is surely one of the finest turntables available. Absolutely superb mechanical stability and precision.
The Ideal Comprator -
Itself incomparable, the DQX-1000 can help you enormously in comparing cartridges and tonearms. The turntable is so neutral, you effectively remove it as a variable in your judgment. And since up to three arms can be mounted simultaneously, your comparative evaluations will be much more accurate and definitive.
The Unique Turntable System -
The three large insulators on the DQX-1000 form a unique absorber mechanism taht not only eliminates entirely the hazards of external vibration, but also serves to isolate the arm mount from the turntable. Up to three high quality tonearms may be mounted simultaneously, and tonearms are interchanged easily and quickly. The power supply and transformer are completely isolated in a separate control unit, thus eliminating any feedback or hum interference.
Turntable
The exceptional performance stability of the DQX-1000 can be attributed to the large: 31 cm; 2,9 kg, the platter has a significantly high moment of inertia: 600kg/cm². Additionally, a low shaft burden has been achieved by distributing the weight around the perifery of the platter. The rotational momentum is accordingly very even and constant. Sroboscope markings are inscribed on the turntable, and as the stroboscope is aligned to a buuilt-in oscillator, power line variations have no effect whatsoever on the rotational speed.
PLL Quartz locked Servo Motor
The DQX-1000 uses a direct drive, frequency governed servo motor for optimum speed stability. A strong 1,5 kg (3,3 lbs) starting torque facilitates fast, accurate speed attainment. And even under extreme conditions, the constant speed characteristics are unsurpassed: a 3 gram stylus pressure at 30 cm from the center of the platter produces non speed deviation
Turntable Frame
A unique 3-point supporting frame has been developed in order to increase the stability of the DQX-1000 system. Thus the mechanism is contained within the most stable operating conditions possible. The 1,9 kg frame is made of aluminium alloy.
Motor Shaft Reinforcement
The motor frame features a structure which is integrayed with the unique 3-point supporting frame. The resonance which is generated as the platter rotates is improved with the resulting mechanical strength. A reinforcement effect is also provided for the motor shaft (platter shaft) since it serves as a supporting pillar. This is a structure which clearly defines the fulcrum of the platter when the records are being played.
Insulators
The two-layer absorber system consists of cushion rubber and fulcrum lies in the upper part of the insulators, the resulting low center of gravity both horizontally and vertically.
Arm Mounts
Six modular arm mounts are available optionally for precise, convenient installation of any high quality tonearm on any of the three positions. Now you can easily compare performance characteristics of tonearms and cartridges in order to maximize the efficiency of your total system interface. The DQX-1000 allows you to match specific disc playback characteristics with your cartridges and loudspeakers for the fullest possible enjoyment.
Control Unit
The turntable controls and power supply have been incorporated in an independent unit for optimum ease of access to the power button, speed select buttons, and fine speed adjustment controls, which can very the rated speed ±6% - a full octave.
Magnetic materials are excluded from the cover, and a wooden case is employed in order to improve the sound quality. The quartz circuit has an On/Off control, and when it is set to Off, the signals bypass the PLL servo circuit entirely.
SPECIFICATIONS DQX-1000
Turntable Section
Drive System: Direct Drive
Motor: Quartz Locked PLL DC servo motor
Speeds: 33⅓ and 45 rpm
Turntable Platter: 310 mm (12¼ inch) diameter, aluminum diecast platter
Platter Weight: 2,9 kg (6,38 lbs)
Moment of Inertia: 600 kg · cm²
Wow and Flutter: less than 0,02%
S/N Ratio: More than 75 dB (DIN-B)
Starting Torque: 1,5 kg · cm
Power: 120 V, 60 Hz (USA & Canada); 220 - 240 V, 50 Hz (other areas)
Power Consumption: 11 W
Dimensions (W x H x D): 444 x 125 x 444 mm (17½ x 5 x 17½ inch)
Weight: 12,0 kg (26,4 lbs) without control unit
Το δευτερο βιντεο που το δειχνει εν λειτουργια (εστω και με εναν βραχιωνα!) ειναι εξαιρετικο
Σειρα της Sansui. Με τα ιδια γονιδια της Ιαπωνικης DD σχολης και των υπεροχων υλοποιησεων μια γρηγορα ματια στα
SR 838
SR 929
he SR-838 was near the top of Sansui's turntable range of 1979. It was a quartz-locked direct drive model with a plinth contructed from 1.5 inch thick chipboard finished in a lovelly jet black finish with a piano-like high gloss lustre with a contrasting silver coloured control panel. It relys on a rubber and coiled spring suspension system to provide isolation from external vibrations.
The strobe pattern appearing on the lower part of the platter's rim is illuminated by a built in strobe lamp whose frequency is locked to that of the quartz oscillator. Since the strobe is always synchronised with a servo frequency, not with the AC power frequency, only one stroboscopic patten is needed. This has aesthetic and ergonomic benefits.
The SR-838 also incorporates an electronic brake implemented by a special circuit in the servo system which generates a reverse drive current for the reverse drive torque to achieve rapid decelleration. This allows rapid, fuss free speed change while the platter is rotating.
Το Goldmund ήταν αφρός, και με παράλληλο βραχίονα, αλλά βαρουσαν στο ψαχνό...
200.000 ευρω περιπου!!!!!!. Θα ειχε ενδιαφερον αν καποιος εχει ακουσει ενα ή αν εχει Ε1 που το καλυπτει να μας πει και εμας. Δεν ξερω ρε παιδια μηχανηματα που κοστιζουν 3 - 4 - 10 χιλιαρικα ισως και να τα αποκτησεις καποτε ακομα και αν δεν εισαι απλας...μερακι και οικονομια για την τρελα σου. 200 χιλιαρικα ομως παει αλλου το πραγμα. Υποθετω οτι θες αλλα 300 τουλαχιστον για ηχεια ενισχυτες καλωδια κλπ. Οκ παραιτουμαι
Goldmund λέω το στούντιο, για dd, άσε το ριφερενς.
Δεν ήταν τόσο ακριβό το στούντιο, είχε κι ένα στουντιέτο, φτηνότερο.
Χτυπούσε δυνατά νούμερα σε wow & flutter, δεν ήταν μεταξωτές κορδέλες, αλλά εντάξει, βαρουσαν στο ψαχνό..
Το ριφερενς ήταν εκεί που λες, αλλά νομίζω ήταν belt drive.
Ωραίο το ΥΑΜΑΗΑ.
Παντως αρκετά κομμάτια σειράς QL που κυκλοφορούν ακόμα ,έχουν ένα θεματάκι με το αντίβαρο του βραχίονα που έχει κρεμάσει προς τα κάτω ,μάλλον λόγω πολυμερισμού κάποιου λάστιχου που το συγκρατούσε .
Ζαχάρωνα κάποτε ένα QL7 ,αλλά έπεσα πάνω σε τέτοια ακριβώς περίπτωση και δεν το πήρα.
Σωστος σε ολα
Studietto
και Studio
απ οτι φαινεται και στα 2 υπαρχουν εκδοσεις linear και μη
Οι τιμες σαν μεταχειρισμενα με μια γρηγορη ματια ειναι γυρω στα 3Κ για το studio και τα μισα για το αλλο. ....
Και εγω στα 44 μου νομιζω οτι αρχισα να πολυμεριζομαι σιγα σιγα!!!!!!!!!!!!!!!!!! θα παω για service
Α να μπράβο, αυτά.
Αν και δε "γεμίζουν το μάτι" όπως άλλα "γυαλιστερά" πικάπ, ωστόσο προφανώς έχουν εξαιρετικό μοτέρ, μεγάλης ακρίβειας και πολύ χαμηλών θορύβων, με άριστο wow & flutter και ο παράλληλος βραχίονας είναι εκ των πραγμάτων καλύτερος στην αναπαραγωγή.
Τα είχα δει λάιβ και τα δύο με βραχίονα παράλληλης μετατόπισης, ήταν πολύ ψαρωτικά από κοντά...
Κάποτε τα ζαχάρωνα, άλλα πολλά τα λεφτά..
Τώρα τα 3 χιλιάρικα που λες, ακούγονται μάλλον νορμάλ..
Άμα βρεις καλό μάστορα για να επισκευαστείς ,πες μου και εμένα..στα 47 το χρειάζομαι λίγο παραπάνω από σένα το σέρβις.;)
Όσο δγυο KH 310!:tongue:
Α να μπράβο, αυτά.
Νομιζω ειναι αρκετα σπανια για να τα βρεις να πουλιουνται σαν μεταχειρισμενα
παντως δεν υπαρχει οροφη σε οποιοδηποτε ειδος οταν πουλας κατι που απευθυνεται στα χομπι του κοσμου.
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Αυτό δεν το ήξερα.
Κρίμα να έχει τέτοια θέματα ένα τέτοιο κατασκεύασμα.
Καλά που δεν το πήρα!! :)
Αυτό δεν το ήξερα.
Λες να είχες πρόβλημα εσύ να το σιάξεις;
Λογικά με ένα ίδιας διαμέτρου λάστιχο από αντίστοιχο υλικό ,θα ερχόταν στα ίσα του.
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Όντως θα μπορούσε.
Σήμερα υπάρχει ένα υλικό ελαστομερές σαν το λάστιχο καουτσούκ, αλλά σε κοκκινωπό χρώμα.
Είναι ιδανικό για απορρόφηση κραδασμών σε βαριές κατασκευές, π.χ. στην στήριξη των μηχανών για τα ασανσέρ, αλλά μπορείς να το χρησιμοποιήσεις και στην θέση αυτού του αντίβαρου στο πικάπ που συζητάμε.
Το καλό είναι ότι τορνίρεται, φρεζάρεται και τρυπιέται με σχετική δυσκολία μεν, αλλά μπορείς να πετύχεις ακρίβεια διαστάσεων.
To QL-5 που υπάρχει ακόμα στο πατρικό μου πάντως δεν έχει αυτό το πρόβλημα, έχει όμως πρόβλημα στο arm lift από παλιά...
AudioFuture
