Technics SL-1200G, που το πουλάνε, ρε παιδιά;
Σκέφτομαι να το τσιμπήσω, αλλά δε το πουλάει κανείς στην Ελλάδα και στην Intertech, μετά απο 20 προσπάθειες, νόμιζαν ότι τους ζήταγα εμπλουτισμένο ουράνιο.
Λέω να δώσω το Linn και να χω το Technics.
richersounds.com/technics-sl1200g.html
Technics SL1200G
Direct Drive Turntable
Stock erratic / 0% Interest Free Credit *
Skip to the end of the images gallery
Skip to the beginning of the images gallery
image_1
Technics SL1200G - direct drive turntable | Richer Sounds
image_2
image_1
image_2
image_3
image_4
image_5
image_6
image_7
image_8
Best sellers right now...
Product information
* 18 months 0% Interest Free Credit is available on this Direct Drive Turntable via telesales only, please call for details. Terms and conditions apply. Subject to application, financial circumstances and borrowing history. Click here for more info. Offer excludes Clearance, Refurbished and Open Box products.
Click here to see our range of Turntable Accessories.
The legend not only lives but is better than ever, with the Technics SL1200G.
A legend in the home, studio and club
Developed as a turntable that was sturdy enough to be used professionally but simple and attractive enough to use at home, the Technics SL1200 was a hit from the beginning. Starting life in the early '70s, the SL1200 lived through five versions (in the UK) and, even at its demise in around 2010 was still seen by many as the reference deck for club use. Now it's back and, in G form, it's the best ever regular model!
The best SL1200 ever
The Technics SL1200 has always been superbly built but this is even better. Added to the existing three-layer chassis is a new, 10mm thick top panel, crafted from solid aluminium. This provides superior damping for a more dynamic sound. A newly developed, coreless motor is used to cut down on vibration with twin rotors providing high torque and an even load on the bearing. In short, the new SL1200G shouldn't just be the best-sounding but also the hardest wearing - with a weight of 18kg to prove it.
High spec magnesium tonearm
Unique to the top spec SL1200G is a magnesium tonearm (the standard models feature an aluminium one). Lightweight magnesium offers a high damping effect; quelling distortion. It’s also extremely rigid, helping the tonearm offer the most precise and detailed sound. High precision bearings and Technics’ gimbal suspension provide the smoothest tracking
Connect your own cables
Rather than using static cables, the SL1200G features brass-milled, gold-plated phono terminals. These let you choose your own length and quality of cable that's worthy of a deck of this capability.
Increased pitch control
A new 'x2' button lets you double the range of the pitch control from +/- 8% to +/-16%. This extra range makes it even more flexible as a mixing tool and even handier in the studio than ever.
Whether it's for use at home or earning its keep in clubs, the Technics SL1200G is simply the best of the best.
Specification
Customer Reviews
£2649RRP £3499
SAVE
£850
ika
News
για ρώτα εδώ μπας και
Κατά την ταπεινή μου γνώμη, πάνω από τα δυο-τρία χιλιάρικα, όλα τα πικάπ το ίδιο ακούγονται.
Η ταπεινή σου γνώμη για την τράμπα που σκέφτεσαι δεν ισχύει (τα έχω και τα δύο), εκτός αν βαρέθηκες να βλέπεις το Linn!
το G έχεις;
το G έχεις;
¨όχι, το MKII, στο οποίο άλλαξα βραχίωνα.
Μην περιμένεις τις τρελλές διαφορές από το νέο, μην περιμένεις και ομοιότητες με το Linn όμως...το οποίο παρεπιμπτόντως γιατί το αγόρασες?
Δε μετάνιωσα που αγόρασα το Linn, ίσα-ίσα.
Απλά θέλω να δοκιμάσω και το καινούργιο SL1200G, που είναι και πιο εύχρηστο από το LP12.
Άμα μας βάλουν και τα αναδρομικά αύριο-μεθαύριο, το «χτύπησα»!
Και με μια Nagaoka 150, θα κελαϊδάει!
Κράτα και το Linn άν έχεις παληά βινύλια,,,,τζαζ-μπλουζ, μικρά σύνολα κλασσικής, τέλεια με το εγγλέζικο.
Ποιο μοδέρνα-σύγχρονα έργα, χτύπησε τα αλύπητα με τον ζχιστομάτη!!
Τι αναδρομικά?? :drinks:
Τα αναδρομικά της σύνταξης, βρε!
Που ζεις;
Έλεγα να πάρω καμια Ιντρακάτ, αλλά προτιμώ το Technics, αρκεί να το βρω!
Στρήμερ πάρε(καλό), νάχεις ατελείωτη δισκοθήκη!!
Εννοείται συνδρομή σε Τιντάλ και στην πλατφόρμα Ρουν και άκου ατελείωτα σε α' ποιότητα!;)
Έχω Streamer (καλό), αλλά δεν θέλω τίποτα συνδρομητικό (Tidal, Roon, Netflix, Office 365, κλπ.)
Πάντως, για πικάπ μιλάμε και για βινύλια (ξέρεις, εκείνα τα μαύρα που κάνουν χρατς/χρουτς και τα χαρτονένια εξώφυλλα τους μυρίζουν τόσο "χαρτονένια")
Καλήμερα marba1065
Εγώ αγόρασα από το ebay σε μια προσφορά καινούργιο το Technics SL-1200GR με μια κεφαλή Ortofon 2m black και είμαι ευχαριστημένος, και είχα πριν το mk2
Εσύ που ενδιαφέρεσαι για το 1200G στο ebay υπάρχει αυτό που κάνεις και μία προσφορά........
Τώρα για κεφαλή καλό θα ήταν να κοιτάξεις κάποια καλύτερη και σε θέμα τιμής π.χ. Ortofon Cadenza Bronze
Ποιο από τα δυο πικάπ θα παίζει καλύτερα μόνο μια δοκιμή θα τη καταλάβεις όλα τα άλλα είναι υποθέσεις.
Καλή Αγορά. :thumbsup:
Τελικά κατάφερα να μιλήσω με τον υπεύθυνο στην Intertech για τα Technics, ο οποίος με ενημέρωσε ότι τα όλη η γκάμα των πικάπ δεν προορίζονται για την Ελληνική αγορά όπότε δεν μπορούν να τα φέρουν, και ότι αυτό είναι απόφαση της μητρικής εταιρίας στην Ευρώπη και όχι της εδώ αντιπροσωπείας.
Κοιτάω και το ebay και συνεχίζω την αναζήτηση.
Επίσης εδώ:
Έχω αγοράσει αρκετές φορές απ' αυτούς, είναι γρήγοροι και σοβαροί. Επίσης, απαντάνε μέσω μέιλ σε οποιαδήποτε απορία έχεις, πολύ γρήγορα. Πιστεύω ότι θα σε κατευθύνουν σωστά και στο θέμα της κεφαλής.
  • rose.athens
dimastro
