New Zidoo Z9X
Σιγά-σιγά έρχονται καλά πράγματα:
Fw 6.0.22_G
1. Add custom options for color depth and chroma of different resolutions and frame rates
2. Optimize the problem that the long key time of the remote control is too short
3. Local playback adds the function of matching frame rate and resolution
4. Modify the shortcut settings, the problem that the custom wallpaper cannot select the SMB path
5. Fix the problem that the HDMI Range setting cannot be saved, and the screen will flashing when switching to 16-235
6. Improve device compatibility, and solve some display devices that may flicker in automatic mode (EDID compatibility)
7. Modified the issue of some DV movies playing stuck
8. Fix the problem of asymmetrical upper and lower black borders in certain ratios of movies when using VS10 or LLDV mode
9. Fix the problem of incorrect ratio when online video is cut to 4K
10. Optimize online playback
11. Repair the poster wall cannot be restored from the original backup
12. Fix the problem that some projections cannot be switched to 3D mode
13. Add the function of turning off the TV when the machine sleeps CEC
14. Optimize the playback of DTS CUE music files
15. Fix the setting of bt2020 mode on TVs that do not support 10bit. Problem with abnormalresolution
16.Fixed the issue that the playback of 4K Blu-ray navigation would become 1080P
17. Optimized Blu-ray navigation frame rateswitching
18. Fix the problem that third-party players cannot play
19. The system adds a screen saver function
20. Fix the problem that the quick setting crashes when only the AV output is connected
21. Local player information button adds file name display
22. Fix the problem that the local player's bit rate gets wrong
23. Added HDR output display for local player information key
24. Add initial support for Dolby vision MKVs (experimental function, support Profile5, 8 MEL)
25. Fix the problem that the mobile APP cannot be restored to the factory
26. Quick setting adds CEC setting option
27. Fix the problem that the wallpaper of the file manager is not synchronized occasionally
28. Fix the problem that the color space of mobile APP cannot be set
29. Android mobile APP adds application installation function
30. Fix the problem that some U disk causes the machine to enter the reset interface
http://ota-cloudfront.zidoo.tv/Z9X/ota/Z9X_P_v6.0.22_G_202008111938_ota-package.zip
MD5:FDEE9B5DA1AB542F02E8760948387840
About Dolby vision MKVS Demo download:
http://www.makemkv.com/download/dvtest/
Model: Z9X
Version number: v6.0.30
System
1. Fix the problem that the AV output is not connected to the video cable and no sound output
2. Fix the problem of individual online video freezes
3. Add the Samba service function
4. Fix the DLNA screen projection function after entering the screen saver
5. Fix the fast forward of individual movies after the delay problems arise sound
6. Added support aiff music file
7. optimizing Bluetooth remote controller connected to Q
8. Repair sporadic not shutdown
9. Optimization of the remote control key function length
10. Fixing portion not be properly recognized the U disk the problem
11. optimized screen saver function
12. With mango TV repair equipment prompt root of
13. the adaptation ZDMC software
Player
1. fix the problem can not be switched chapter of
the problem press the function key when repairing pause to continue playing
3. optimization download subtitles
4. Add press the information button to display poster information
5. Optimize the forced subtitle function
6. Fix the problem that SMB videos cannot be played through ZDMC
7. Fix the problem that some TVs cannot be automatically played in 3D
10. Increase the HDR 12bit function
11. Fix the problem of some DV movie splash screens.
Picture Manager
1. New revision of the function
2. Added self Define the folder function
3. Add the function of setting the folder as a screen saver picture
4. Optimize the slide show function
Poster wall:
1. Upgrade version 4.0
2. Optimize the navigation interface sorting function
3. Fix the problem that Douban cannot match
4. Solve the direct play session Ignore the child lock problem
5. Fix the problem of incorrect data after sorting widgets
6. Optimize the local trailer ratio
7. Optimize the sorting function
8. Optimize the detail interface
Quick settings
1. Add Samba service switch
2. Optimize color settings
3. Increase color depth Compatible mode
Kαι απο βδομαδα ερχεται και αλλο....
Επίσης έχουμε και το νέο ZDMC 18.8 :
http://apidl.zidoo.tv/app/zdmc-18.8_rtk.apk
Μικρο ρετουσαρισμα σημερα:
Beta version 6.0.35 for Z9X,Z10 PRO,Z1000 PRO
Change logs:
System
1. Fix the no sound output problem for the AV output when video cable is not connected.
2. Fix the problem that some online videos are not playing smoothly.
3. Add Samba service functionality.
4. Fix the problem that DLNA cannot cast screen after entering the screensaver.
5. Fix the problem that the sound of some videos delay appears after fast-forward.
6. Add support for aiff music files.
7. Optimize the connection of the Bluetooth remote control.
8. Fix the problem that occasionally cannot be shut down.
9. Optimize the long key function of the remote control.
10. Fix the problem that some U disks cannot be recognized correctly.
11. Optimize the screen saver function.
12. Fix the problem that Mango TV prompts the device to be rooted.
13. ZDMC Adaptation.
14. Add supporting of IQiyi output raw sound.
15. Optimize the HDMI IN display.
16. Fix the problem of incorrect free space when copying by Samba.
17. Fix the problem that some mobile apps display in portrait mode.
18. Fix the problem that no HDR output when playing HDR videos with some projector.
19. Add the Czech language adaptation.
Video Player
1. Fix the issue that chapters cannot be switched.
2. Fix the problem of pressing the function key to continue playing during pause.
3. Optimize subtitle download
4. Add press the information button to display poster information.
5. Optimize the forced subtitle function.
6. Fix the problem that SMB videos cannot be played through ZDMC.
7. Fix the problem that some TVs cannot play in 3D automatically.
8. Add HDR 12 bits support.
9. Fix the flickering problem of some DV movies.
10. Fix the problem that there is no 3D effect when playing MKV 3D movies.
11. Optimize poster information display of player.
12. Fix the problem that some DV movies cannot be played.
Image Player
1. New feature revision.
2. Add custom folder function.
3. Add the function of setting the folder as a screen saver picture.
4. Optimize the slideshow function.
5. Fix the problem that the vertical picture is stretched in the slide show.
6. Add the function of exclude folder.
Home Theater
1. Update to version 4.0
2. Optimize the sorting function of the navigation interface.
4. Fix the problem that child lock will be ignored when playing directly.
5. Fix the problem of incorrect data after sorting widgets.
6. Optimize the ratio of local trailers.
7. Optimize sorting function.
8. Optimize the details interface.
9. Fix the problem of incorrect TV viewing history.
10. Fix the problem that the detailed title is too long.
11. Fix the problem that the letter navigation and the prompt picture on the left side appear at the same time when display in list mode.
12. Optimize TV series matching.
Settings
1. Add Samba service switch.
2. Optimize color settings.
3. Add Deep Color compatibility mode.
4. Add input method selection settings.
Media Center
1. Optimize the playback history display.
2. Added playback history display switch.
Bluray Navigation
1. Add function to display movie information when press information key.
2. Fix the problem of not being able to navigate after entering the screensaver.
Z9X:
v6.0.35
Download:http://apidl.zidoo.tv/Z9X/v6.0.35/Z9X_P_v6.0.35_202009031713_ota-package.zip
MD5: 93E9881CA2805C86FEAA2ECFF3B92C49
v6.0.35_G
Download:http://apidl.zidoo.tv/Z9X/v6.0.35/Z9X_P_v6.0.35_G_202009031800_ota-package.zip
MD5: BF7C2ACDFE666F86B23F08855CF37932
Z10 PRO:
v6.0.35
Download:http://apidl.zidoo.tv/Z10_PRO/v6.0.35/Z10-Pro_P_v6.0.35_202009031830_ota-package.zip
MD5: 6D3FCEA423F81A3DBD69A09ED4795237
v6.0.35_G
http://apidl.zidoo.tv/Z10_PRO/v6.0.35/Z10-Pro_P_v6.0.35_G_202009031852_ota-package.zip
MD5: 9791FA5FFBB6FA657DABD376EF792945
Z1000 PRO:
v6.0.35
Download:http://apidl.zidoo.tv/Z1000_PRO/v6.0.35/Z1000-Pro_P_v6.0.35_202009031927_ota-package.zip
MD5: F9ED62F5F5BDEE6EAC2C060C6C10C552
v6.0.35_G
Download:http://apidl.zidoo.tv/Z1000_PRO/v6.0.35/Z1000-Pro_P_v6.0.35_G_202009031950_ota-package.zip
MD5: F2DA9B7510F552AB81E09F2F1D4AD7BC
ZDMC:
Από ότι διάβασα δεν υποστηρίζει flac 5.1, αν ισχύει υπάρχει κάποιο άλλο media player που να υποστηρίζει?
Και ο καλύτερος τρόπος για αναπαραγωγή είναι να συνδεθεί sata. Σκληρός πάνω του?
Σας ευχαριστω
Νεο λογισμικο σημερα v6.0.66
Change logs:
System
1. Fixed the problem that the system time cannot be obtained in some regions
2. Optimized the problem that the player occasionally can not be turned off.
3. Optimized online video playback
4. Added multiple Dolby VS10 modes
5. Fixed the problem that the CEC function cannot be turned off occasionally
6. RS232 added color key adaptation and fixes the problem of not responding to commands in time after booting
7. Fixed the problem that the system occasionally displays a warning box
8. Added USB Audio output (PCM original sampling rate, DSD NativeοΌas a experimental function, Zidoo will not be responsible for USB DAC compatibility)
9. Optimized the problem of slow loading weather and status display on the main interface
10. Fixed the problem that the wireless hotspot does not take effect after restarting the device
11. USB audio switch, added VID/PID display.
12. Optimized the problem that the Wi-Fi list of quick settings sometimes does not display.
13. Optimized the display of Control4 driver.
14. Optimized the CEC switch.
15. Fixed HDMI resynchronization caused by the VSIF issue of some LG DV TV(This problem comes from LG, which is a temporary solution)
Video player
1. Fixed the problem that the current time of TS format replay occasionally gets incorrectly
2.Added HDR10+ information display
3. Optimized loading video UI display
4. Added ASS subtitle brightness setting
5. Added bookmark display mode
6. Added PGS subtitle brightness setting
7. Added CEC shortcut key adaptation
8. Optimized frame rate switching
9. Fixed the problem of garbled built-in text subtitles of some sources
10. Fixed the problem that some video sources can not get audio tracks
11. Fixed the problem that DV video and double-speed playback sometimes get stuck
12.Fixed the issue of some video playback screens
13. Optimized some UI display
14. Fixed the problem that song occasionally could not be played when switching to the next through the phone
15. Added MKV chapter information display
16. Fixed the issue of black screen when playing some videos
17. Optimized the display aspect ratio of some DVD and MKV(Yes, all of the DVDs have the right aspect ratio now)
18.Added the global video ratio switch
19. Support Dolby vision video shot by iphone 12
20. Fixed the problem that the DV test movie downloaded from Dolby official website cannot be played
21. Added PGS brightness setting for global or HDR environment
HDMI IN
1. Optimized resolution selection
2. Optimized the problem of lag when playing recorded video
3. Added 60fps recording
4. Fixed the problem that scheduled recording does not take effect
Quick setting
1. Optimized HDR settings
2. Added player bookmark settings
3. Fixed the problem that the default download subtitle list display error
4. Added wireless hotspot settings
Poster wall
1. NFO added Clear Logo support
2. Optimized the focus control of the device list
3. Optimized the UI display of poster details
4. Fixed the problem of abnormal data if the NFO file already exists when exporting NFO
5. Added more data information of NFO files, such as trailers, directors, actors, etc.
6. Optimized the loading speed of poster images
7. Fixed the problem of unsuccessful loading of poster pictures occasionally
8. Optimized native poster image loading function
9. Optimized data restore function
10. Added TV page selection function for series.
11. Fixed the problem of incorrect display of watch history
12. Fixed the problem that Blu-ray navigation can not be selected caused by the child lock
13. Optimized TVDB synchronizationdata of TVDB series
14.Optimized TV series poster title display
Music player
1. Optimized the accuracy of lyrics acquired from network
2. Optimized some UI display
3. Optimized online matching
4. Optimized the problem of garbled song names
5. Optimized song information editing
6. Fixed the problem of occasional crash when fastly switching DTS audio
7. Fixed the problem that the music cannot be switched to next when playing from the file manager
Acknowledgements:
Markswift2003
Sledgehamma
Nice monkey
Steelman1991
OlivierQC
Papirus
Z9X:
6.0.66(Without Google play)
http://apidl.zidoo.tv/Z9X/v6.0.66/Z9...ta-package.zip
MD5: 0D0A29725A4AEE31843F0D5FBF826FD8
V6.0.66_G(Build in Google play)
MD5: 1CD3CE11948EDD9E0ACF898AD6C1473E
Z10 Pro:
http://apidl.zidoo.tv/Z10_PRO/v6.0.6...ta-package.zip
MD5: C78B33CC91CBB786768B9D225B07A370
MD5: 338B27D8457450C16B4AE996971CDE5A
Z1000 Pro:
http://apidl.zidoo.tv/Z1000_PRO/v6.0...ta-package.zip
MD5: 24AA9A8D41C9BFB4A9AFDB508F1ECA7F
MD5: 49250197A5ACED37FDD221DD91CC4B6A
How to activate Google Play Store:
1. Open Play Store, then close it - this generates the GSF ID
2. Goto Settings/Other/About and take a note of the GSF ID
3. In a web browser, goto www.google.com/android/uncertified, log in and enter GSF ID and hit <Register>
4. Restart ZIDOO device.
Για το Zidoo έχω διαβάσει ότι η υποστήριξη σε 4Κ στις sreaming υπηρεσίες είναι λίγο μαιμού. Από το αυτό το Dune HD realbox και το Nvidia shield πιό θα διαλέγατε κυρίως για να αναπαραγωγή 4k MKV HD Audio;
Θες 4Κ από streaming υπηρεσία ή 4Κ από τοπικά αρχεία?
Αν είναι το πρώτο nvidia shield.
Αν είναι το δεύτερο Dune.
Αν θες και τα 2 μαζί τότε μόνο το shield έχει official άδεια για 4K Netflix.
Κατά την γνώμη μου ούτε το δεύτερο γιατί δεν έχει official google tv.
Αν θες μόνο streaming υπηρεσίες πας για shield.
Αν θες local 4K dune ή Zidoo με προτίμηση για μένα στο Zidoo
Ευχαριστώ για την απάντηση. Το Shield γιατί δεν είναι καλό για local 4K; Επίσης την HiMedia την ξέρει κανείς; Είναι πιό οικονομικά τα μοντέλα της. Επίσης το Dune real box είναι πιο οικονομικό από το Zidoo Z9x περίπου 60 Ευρώ από το ebay.
To shield μια χαρά είναι για local 4K είτε μέσω lan (το tube) είτε μέσω lan+usb (το pro) ΑΝ την παλεύεις μέσω kodi. Δεν έχει δικό του player.
Οι players των Zidoo /dune είναι ανώτεροι γιατί μπορούν να διαχειριστούν full BR/UHD iso/menus
(Μήπως μπερδεύεις το realbox με το dune HD pro 4K II ?
To πρώτο είναι ικανότατο player για local 4K αλλά με εντελως τυπικές streaming δυνατότητες της κατηγορίας , το δεύτερο ότι και το πρώτο δυνατότερο ακριβότερο καλύτερο με δυνατότητα Android TV αλλά δυστυχώς ΟΧΙ official certificate.
Προσωπικα επέλεξα την λύση Ζ9x για τα local files και shield tube για τα streamings.
ΑΝ το pro 4K II (RTD1619) ήταν certificate θα επέλεγα αυτό.
Δες όμως αν σε βολεύει εσένα -έχουμε παρουσίαση εδώ- και κάνεις δουλειά, θα γλιτώσεις και το δεύτερο remote ....)
Καινουριο λογισμικό σήμερα, v6.0.80
Προσοχή πιο θα βάλετε
System
1. Optimize system performance
2. Optimize the problem that WIFI cannot be turned on occasionally
3. Fix the problem that some Dolby vision videos cannot be played
4. Add multi-channel passthrou support for online streaming
5. Optimize online streaming playback
6. Optimize shock-wave noise problem when pause of individual amplifiers
Image Player
1. Fix the problem that the slideshow occasionally crashes when there are too many pictures
Quick Setting
1. Add SMB shared password, permissions and alias settings
2. Optimize interface display speed
3. Fix the occasional flashing back problem when pressing Home key
Poster Wall
1. Optimize the problem that posters cannot be displayed occasionally
2. Fix the problem that setting data cannot be restored when retstoring data
3. Optimize some interface
4. Optimize the poster saving catalog
5. Optimize the problem of occasional crash problem when scaning
Blu-ray Menu
1. Add PGS subtitle transparency adjustment
Local Player
1. Fix the problem that the menu interface cannot be displayed after the Blu-ray source switch titles
2. Fix the incorrect display ratios problem for several movies
3. Fix the no sound problem when playing individual videos
Music Player
1. Fix the problem that the cue song cannot be played when playing through the file manager
2. Fix the problem that the songs cannot be selected occasionally when playing SACD
3. Optimize lyrics searching function
4. Fix the problem that Zidoo Contoller APP cannot obtain singer information
5. Optimize the music playback interface
6. Optimized the problem that the application does not respond occasionally after adding a large number of songs
7. Optimized the problem that song list interface is stuck occasionally
8. Optimize the problem that the duration of the song cannot be obtained occasionally
9. Fix the problem that skipping to next songs when the former one is not finished
10. Optimize playback stability
Z9X:
6.0.80(Without Google play)
http://apidl.zidoo.tv/Z9X/v6.0.80/Z9...ta-package.zip
MD5: 29CBEE9B299BAAFEA2A5FA2395CA5A88
V6.0.80_G(Build in Google play)
MD5: 65E9EBC94EFB25C8B87BB0DB1BCDAECA
Z10 Pro:
Z1000 Pro:
Νέο λογισμικό v6.0.90
Change logs:
system
1. Fix the problem that some Dolby Vision videos are stuck (some MKV videos).
2. Fix that some TVs cannot output 3D by default.
3. Optimize online video streaming.
4. Optimize HDMI IN preview.
5. Fix the problem that the Blu-ray navigation cannot automatically frame rate switch.
6. Add Dolby Vision compatibility mode (this mode for the latest SONY 9000H firmware LLDV is abnormal, and some old LG TV HDMI IN models only support 2160P30 DV)..
player
1. Add UPNP video playback function.
2. Fix individual movies will be rustle of PCM audio.
3. Fix some videos cannot be played.
4. Fix the problem of audio slow output when paused.
5. Optimize bookmark playback function.
6. Optimize the subtitle download function.
7. Optimize the problem that the external srt subtitle will occasionally flash.
8. Fix output information display error problem on the information display interface.
Poster wall
1. Optimize NFO analysis.
2. Optimize part of the UI.
music player
1. Increase UPNP music playback function.
2. Optimize lyrics function.
3. Fix the problem that the song cannot be cut normally after playing from the file manager.
4. Optimize information acquisition in detail page.
File manager
1. Increase UPNP function.
2. Optimize NAS boot and mount speed.
3. Optimize UI.
Picture manager
1. Increase network picture page.
2. Add UPNP picture slideshow.
3. Fix the problem that the system music does not stop when slideshow.
Quick setting
1. Increase the compatibility mode switch of transparent transmission power amplifier (for some power amplifiers).
2. Increase the time setting of the bookmark function.
3. Add Dolby Vision compatibility mode.
4. Add resolution lock function.
Mobile APP (scan the QR code of the machine to download and update)
1. Fix the problem that the music search page cannot play music.
2. File manager adds UPNP function.
3. Optimize the cue music playback function.
4. Optimize music favourite function.
5. Added music play-list mode.
6. Optimize some UI.
Z9X:
v6.0.90(Without Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_202012311835_ota-package.zip
MD5:20B87A79C5F46626C450B7F7371F0439
v6.0.90_G(Build in Google play)
http://apidl.zidoo.tv/Z9X/v6.0.90/Z9X_P_v6.0.90_G_202012311849_ota-package.zip
MD5: DB3F350CA1001B1EB62DF02E5D4818E2
Z10 Pro:
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_202012311756_ota-package.zip
MD5: 9BCC4311FF818BD27C14E3F3D2C3ACB2
http://apidl.zidoo.tv/Z10_PRO/v6.0.90/Z10-Pro_P_v6.0.90_G_202012311810_ota-package.zip
MD5: C3D9D028D6F92B1E49CECBD56C091ECB
Z1000 Pro:
v6.0.66(Without Google play)
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_202012311707_ota-package.zip
MD5: 433F983521D9FCF04E9224954808379E
http://apidl.zidoo.tv/Z1000_PRO/v6.0.90/Z1000-Pro_P_v6.0.90_G_202012311723_ota-package.zip
MD5: 92F96C617370D71A848C90D84B5FC31F
UHD3000:
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_202012311612_ota-package.zip
MD5:C25559805AD181A6D72331774EB73AAD
http://apidl.zidoo.tv/uhd3000/v6.0.90/UHD3000_P_v6.0.90_G_202012311638_ota-package.zip
MD5: 1EBCD1E225686CA4A20C985DE7A0B17
είναι εντάξει το το τελευταίο fw, το έχει δοκιμάσει κανείς ? ή να περάσουμε το προηγούμενο?
Εχω βαλει το fw 6.0.90 και θέλω να γυρίσω στο μαμίσιο fw. Γίνεται? Σημειωτέων δεν έχω κάνει αφού έβαλα το 6.0.90 εργοστασιακές ρυθμίσεις.
Apo βλακεία, έσβησα το νετφλιξ στο z9x...
Πως το ξαναβάζω;
Πήγα στο www.apkmirror.com kai το εγκατέστησα αλλά οι έκδόσεις που είχε, δεν συνεργάζονται με το τηλεκοντρόλ (θέλει ποντίκι) και νομίζω ότι δεν παίζουν 4Κ και μάλλον ούτε 5.1. Στις επιλογές ήχου δεν το έγραφε και δυστυχώς δεν έχω AVR αυτη τη στιγμή για να το έβλεπα....
Πως το ξαναβάζω;
Λογικά η Zidoo εχει δικο της πειραγμένο build.
Δεν ξερω αν το γλιτώνεις το reset.
Ριξε και ενα ερώτημα στο φορουμ τους.
Tasosnissanp12
