MOTU M2 & M4
m1ts0s
News poster
M2 and M4 feature highlights
• 2-in / 2-out and 4-in / 4-out USB audio interfaces with studio-quality sound
• Best-in-class audio quality driven by ESS Sabre32 Ultra™ DAC Technology
• Best-in-class speed (ultra-low latency) for host software processing
• Best-in-class metering for all inputs/outputs with a full-color LCD
• 2x mic/line/hi-Z guitar inputs on combo XLR/TRS
• Individual preamp gain and 48V phantom power for each input
• 2x balanced 1/4-inch line inputs (M4 only)
• Hardware (direct) monitoring for each input
• Monitor mix knob to balance live inputs and computer playback (M4 only)
• Measured -129 dB EIN on mic inputs
• Balanced, DC-coupled 1/4-inch TRS outputs (2x for M2; 4x for M4)
• Measured 120 dB dynamic range on the 1/4-inch balanced TRS outputs
• RCA (unbalanced) analog outs that mirror 1/4-inch outs (2x for M2; 4x for M4)
• 1x headphone out (driven by ESS converters) with independent volume control
• MIDI in/out
• Support for 44.1 to 192 kHz sample rates
• USB audio class compliant for plug-and-play operation on Mac (no driver required)
• Windows driver with 2.5 ms Round Trip Latency (32 sample buffer at 96 kHz)
• Mac driver (optional, for 2.5 ms RTL@32/96 kHz and loopback feature)
• iOS compatible (USB audio class compliant)
• Driver loopback for capturing host output, live streaming and podcasting
• Bus powered USB-C (compatible with USB Type A) with power switch (USB cable included)
• Rugged metal construction
• Workstation software included (MOTU Performer Lite 10 and Ableton Live Lite 10)
• 100+ instruments (in Performer Lite)
• Over 6 GB of included free loops, samples and one-shots from industry leading libraries
• Kensington security slot
• Built in the USA
• Two-year warranty
Pricing and availability
The M2 ($169.95 USD) and M4 ($219.95 USD) are now shipping.
https://motu.com/products/m-series/m2/
https://motu.com/products/m-series/m4/
Μολις έπεσε το μάτι μου στη Μ4 στον Thomman και μου φαίνεται καλή επιλογή για αναπαραγωγή στο pc.
Την τόλμησε κανένας?
Επαναφέρω το θέμα. Ενδιαφέρομαι και εγώ για αγορά της Μ4 αλλά διαθεσιμότητα δεν υπάρχει...
Ξέρουμε διαφορές με την Μ2 εκτός από τα προφανή (στα i/o)?
wnet
Nearfield
άμα βρείτε την m4 (σε εύλογο χρονικό διάστημα) να με χέσετε :p
την παρακολουθώ στου Thomman μήνες, μόλις η αναμονή φτάσει στη 1 εβδομάδα... ξεκινάει πάλι από τις 7-8
Εκτός από τα Ι/Ο δεν έχω εντοπίσει άλλη διαφορά, εκτός του knob που διαλέγεις πόσο θα ακούσεις τα inputs κατευθείαν χωρίς latency και πόσο μέσω του DAW
DAMBO
