Bluesound Node 2i
Σκεφτομαι την αγορα του . Αν το εχει καποιος κατοχος να μας δωσει καποιες εντυπωσεις
Εκτος απο το streaming ειναι και προενισχυτης με εξοδο subwoofer η οποια απο οτι διαβαζω , μεσω της εφαρμογης κανει cross στα 80hz (fixed)
Επισης εχει bass and treble control
Καποιες επιπροσθετες πληροφοριες που θα μπορουσαν να ενδιαφερουν καποιον κατοπιν επικοινωνιας που ειχα με το τμημα υποστηριξης . Απαντησαν σε 24 ωρες
1) Has the RCA audio output at the backside fixed AND variable option?
All of the outputs at the back of the Node 2i can be set to either fixed or variable volume via our BluOS Controller App. This setting is located under Settings -> Player -> Audio -> Output Level Fixed (ON/OFF). I would strongly advise lowering the volume on your external amplifier first, before enabling this setting, for safety reasons.
2) What exactly is the voltage output from the RCA audio out?
The Analog RCA Output Voltage would be 3/5 volts (=0.6V)
3) Can I crossover the bass frequency of the Bluesound node 2i through the BluOS app?
You can adjust the crossover bass frequency on the Node 2i within our BluOS Controller App. This setting is located under Settings -> Player-> Audio -> Subwoofer (ON), and a crossover frequency slider will appear. From here, you can feel free to adjust the slider accordingly. Please note that 80 Hz is the default crossover frequency on our Bluesound Players.
4) Can I control bass and treble through the BlueOS app?
That is correct, so once you enable the Tone Control setting, a treble and bass slider will appear for you to adjust accordingly. Once again, this setting is located under Settings -> Player -> Audio -> Tone Controls (ON) within our BluOS Controller App for the Node 2i.
5) Is the wireless network compatible with wireless mode b,g,n?
That is correct, so our generation 2i Bluesound Players will support WiFi b/g/n as well.
6) Is the Risk guarantee policy - money return - apply also if I buy it from external dealers/resellers?
This will depend on the external dealer/reseller you purchase from. Therefore, it will always be best to contact them and double-check if this is the case.
7) Would you recommend wireless or wired mode with streamer and why?
Personally, I would always recommend going wired if possible due to it being more reliable compared to WiFi in terms of connectivity. However, with that being said, if WiFi is the only/best route due to the location or environment, then as long as the WiFi signal strength of the Node 2i (or any of our other BluOS/Bluesound Players) is above -55 dBm you should be good to go.
Στην κατηγορία τιμής του είναι η καλύτερη επιλογή και με την καλύτερη application-λειτουργικο, για τέτοιου τύπου συσκευές. Αν θέλεις κάτι καλύτερο ηχητικά, λειτουργικά κλπ πρέπει να πας προς το χιλιάρικο. Από την άλλη όμως, ένας συνδυασμός raspberry pi4+allo digione+volumio, μαζί με ένα dac κατηγορίας 300 ευρώ, θα δώσει καλύτερο ηχητικό αποτέλεσμα, με σχεδόν την ίδια ευελιξία-λειτουργικοτητα.
ifievadam
Ο Amir πολλες συσκευες τις μετραει απο τεχνικης / κατασκευαστικης αποψης
Αν διαβαζουμε προσεχτικα θα δουμε οτι τα noise που μετρα ειναι μη ακουστικα και oi διαφορες του sinad ειναι αμελητεες.
Tanto δεν ειναι ακριβως το ιδιο . Καταρχην εχεις ενα streamer με προ function , bass cross
και επισης μια συσκευη . Μπορεις να το συγκρινεις με το Yamaha wxc-50 το οποιο εχει 330€ αλλα ηχητικα ,βαση ολων των review αλλα και συγκρινοντας τα χαρακτηριστικα τους ειναι καλυτερο το bluesound.
Γνωστό το wxc-50 και στους δυο μας....... χειρότερο ηχητικά απο το node, το λειτουργικό musicCast όχι τόσο κάλο όσο το BlueOS, πιο πρακτικό σαν προενισχυτής όμως, με ποτενσιόμετρο έντασης και επιλογές εισόδων. Αν κάποιος χρειάζεται το κροσαρισμα για το υπογουφερ και ρυθμίσεις μπάσων πρίμων κλπ, προφανώς δεν πάει στον συνδυασμό που ανέφερα. Ηχητικά όμως μπορείς να πετύχεις καλύτερο αποτέλεσμα, ενώ πολλά dac αυτής της κατηγορίας έχουν την δυνατότητα να δουλέψουν σαν προ (ρύθμιση έντασης-επιλογη εισόδου).
Πρεπει να μπορουμε να διαχωριζουμε τις αναγκες μας γιατι το καθε χαρακτηριστικο το πληρωνεις ,ειτε λεγετε φορητος ενισχυτης ακουστικων , προενισχυτης , streamer , bluetooth κλπ
Προσωπικα ψαχνω streamer να αντικαταστησω το arcam irdac που εχω ωστε να μην χρειαζεται να ανοιγω τον υπολογιστη . Υπαρχει και η σκεψη να χρησιμοποιησω το streamer ως προ στον ενισχυτη μου που εχει amp in .
Θα παρεις χειροτερο αποτελεσμα ηχητικα,αν ειχες μονο τελικο ενισχυτη θα ειχες λογο,αλλα τωρα οχι.Αν εχεις το irdac II,νομιζω η πιο απλη και οικονομικη επιλογη θα ηταν να δανειστεις απο μελος του φορουμ,ενα raspberry και να δοκιμασεις αν σε βολευει ο συνδυασμος με το volumio. Ουσιαστικα θα κανεις το ιδιο πραγμα με το node,απο την application θα ανοιγεις το streamer,ενω το να εχεις και ακομα ενα κουτακι ,με μεγεθος οσο ενα πακετο τσιγαρων, δεν ειναι και ουσιαστικη διαφορα.
dimoslecce
