God of War
Ξερει κανεις κανα site που να εχει τις λυσεις για το god of war γιατι εχω κολλησει σε μια πιστα και θα το σπασω το PS2 στο τελος. :rolleyes:
Εψαξα και εγω αλλα δεν βρηκα τιποτα...
There's a shiny object on the ground up the ramp, press the R2 button for a
quick scene and then continue along the path to a ramp which you can kick down
with the R2 button. Head back down to the save point room and go out the
door, this time take the upper left path. You'll come to a large ballista
(crossbow thing) which you can grab hold of with the R2 button. Push and kick
this thing down into the next room. Now in this room you will notice an odd
panel on the floor, go to the door beside it and use the R2 button to pull it
open. Inside a ton of enemies spawn but you can take them all out quickly
using the Poseidon's Rage. After they're taken care of go out and place the
ballista on the gear shaped panel in the floor, now pull the lever. Leave the
room and grab the ballista which has been turned 90 degrees and pull it off
the panel. Pull the lever once again to reset it and put the ballista back
on. Turn it one more time and it will be rotated to face toward that
immovable door. Set it in the middle of the room, then pull back and fire.
H λυση που εψαχνα !!!
Γιουπιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιι !!!!!!!!!!!!!
THANX Dimitri.
THANX Dimitri.
ολο αυτό έπρεπε να το σκεφτείς να το κάνεις μόνος σου?
ωχ ωχ
Ε............. Μα τι να πω...
Ειπαμε να παιξουμε ενα παιχνιδη και οχι να λυσουμε καμια εξισωση.
Αστα να πανε!
s channel
