Ξεκιναει η Ces
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Σε λιγες μολις ωρες ανοιγει τις πορτες της η περιφημη εκθεση CES που γινεται στο Las Vegas.
Οσοι θελουν να μαθουν τα τελευταια νεα-αλλα και τα τελευτα μοντελα- στον κοσμο της βιντεοπροβολης,ας μεινουν συντονισμενοι.
Οτι τελευταιο υπαρχει για τον νεο JVC, τον 1080ρ Benq αλλα και τον εκπληκτικο-απο οτι ακουμε-Meridian θα το μαθετε μεσα απο αυτο το thread οσο πιο συντομα γινεται;)
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Aρχισαν οι χοροι!
Για να δουμε πρωτες εντυπωσεις για τον JVC (HD-1 η RS-1) οπως αυτες αποτυπωθηκαν στο αμερικανικο avsforum:
"I saw the RS1 in the JVC suite this afternoon (thanks Tom for the location info!). For those heading over, it is in the bedroom of their suite, playing on a Stewart ST130 that is 8 feet wide.
I didn't have any measuring equipment, but Tom's compatriot reported that it was at 14 FL using the low lamp mode. Certainly seemed more than bright enough. They are using one of the 1st generation HD-DVD players from Toshiba and were playing Fast & Furious Tokyo. Not my personal favorite movie, but we found some scenes that gave the projector a chance to show off.
I can only say that the hype we've seen on the forum appears to be fully justified. What a picture--the colors are more than spot on and the contrast is a huge improvement compared to the past generation. I can see why everyone who's seen it is impressed. When I bought my Marantz VP12-S3, there was a huge difference in contrast between the best DLP and the best LCOS (and a higher price for LCOS). Now I'd say the "real world" contrast is essentially equal between the two (comparing the best of each) and it is certainly better than anyone who shopped for a digital projector 5 or more years ago would have dreamed possible.
The projector is on a small table at the back of the room, so it was possible to put my ear right next to the fan. It certainly puts out a fair amount of heat! I am particularly sensitive about noise and this has resolved my concerns. I would say that it puts out about the same amount of noise as my Marantz."
Να διευκρινίσουμε ότι με τον όρο «real world contrast», ο σχολιαστής εννοεί τη μεγάλη διαμάχη που έχει ξεσπάσει το τελευταίο διάστημα κυρίως στο αμερικάνικο forum, σχετικά με το ερώτημα για το πιο είδος μέτρησης του contrast παίζει το σημαντικότερο ρόλο κατά τη θέαση ταινιών, το On/off ή το ANSI;
Όπως είναι γνωστό, έχουμε δύο διαφορετικές σχολές, από τη μία πλευρά έχουμε τους SXRD της Sony Ruby και Pearl, αλλά και τον RS1 DILA της JVC που πετυχαίνουν πολύ υψηλό On/off contrast (είτε με τη χρήση δυναμικής ίριδας στη πρώτη περίπτωση είτε χωρίς στη δεύτερη) με νούμερα κοντά στο 15.000:1, αλλά με αντίστροφα πολύ χαμηλές τιμές μέτρησης στο ANSI contrast (σκακιέρα 4Χ4), που δεν ξεπερνούν το 270:1 (RS1) στη καλύτερη περίπτωση.
Από την άλλη μεριά, έχουμε τους τελευταίους εκπρόσωπους από το στρατόπεδο των DLP, με χαρακτηριστικότερο παράδειγμα το νέο Sharp 20000, ο οποίος πετυχαίνει χαμηλότερο μεν On/off contrast με μέτρηση περίπου στο 8.000:1, αλλά από την άλλη μεριά παρουσιάζει το υψηλότερο ANSI contrast που έχει μετρηθεί ποτέ σε ψηφιακό προβολέα, κάπου στο 850:1.
Τίθεται λοιπόν το μεγάλο ερώτημα: Ποιος συνδυασμός μετρήσεων του contrast θα αποδώσει τη καλύτερη εικόνα, ένας συνδυασμός 15.000:1 (On/off) με 250-270:1 (ANSI) δηλαδή η σχολή SXRD/DILA, ή 6.000 έως 8.000 (On/off) με 600-800 (ANSI) δηλαδή η σχολή DLP;
Με τα δεδομένα που έχω μέχρι στιγμής, τείνω να πιστεύω (όπως και πολλοί άλλοι) ότι στις χαμηλομεσαίες έως πολύ σκοτεινές σκηνές το On/off contrast είναι αυτό που παίζει το μεγαλύτερο ρόλο (με λίγα λόγια, λογικά, ο RS1 θα μας πετάξει τα μάτια έξω στη κλασική σκηνή στην αποθήκη του Van Helsing), αλλά όσο αρχίζει να ανεβαίνει η φωτεινότητα στο στιγμιότυπο που παρακολουθούμε (δηλαδή μεσουψηλές έως πολύ φωτεινές σκηνές) το ANSI contrast είναι αυτό που παίζει κυρίαρχο ρόλο.
Συμπερασματικά λοιπόν, θα μπορούσαμε να πούμε ότι αν βλέπεις κυρίως ταινίες μπλοκμπάστερ, τρόμου, θρίλλερ κτλ., με πολλές σκοτεινές σκηνές θα πρέπει μάλλον να διαλέξεις SXRD/DILA προβολέα, ενώ αν βλέπεις κυρίως κοινωνικές ταινίες καθώς και δορυφορικά προγράμματα (με διάφορα σπορ) διαλέγεις DLP προβολέα!
Πιάσε το αυγό και κούρεψέ το και πάρε το μαλλί του!!!
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Πολυ ενδιαφεροντα τα οσα μας ειπε ο Πανος και σαφως ειμαστε σε αναμονη για να κρινουμε με τα ματια μας.
Προς το παρον αρχισαν να βγαινουν οι πρωτες φωτογραφιες απο τις οποιες μπορειτε να παρετε ενα πρωτο δειγμα εδω:
http://www.hometheaterhifi.com/volume_14_1/show-report-ces-2007-index.html
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Δε μου λες Αντρικο , τωρα ξεμπερδεψα απο προβολεα, παλι με μπριζωνεις ?
Εσυ να κατσεις στα αυγα σου που μου θελεις και καινουργιο μηχανημα:lol:
Και τι επαθες σημερα?Εχεις γραψει ηδη 5 μηνυματα!!!:shock:
stavros.vatistas
