Technotrend S2-3200 HDTV-S2 + Remote + Budget-CI
Χρήστος Ακρατόπουλος
[FONT=Helvetica,Arial,sans-serif]The best value, the right features all in a PCI card. [/FONT][FONT=Helvetica,Arial,sans-serif]The model TT-budget S2-3200 represents a low-cost reception device for basic applications. It features a [/FONT][FONT=Helvetica,Arial,sans-serif]complete DVB satellite receiver to receive data broadcasts, digital TV as well as radio programs and [/FONT][FONT=Helvetica,Arial,sans-serif]provides high-speed internet access. The TT-budget S2-3200, was especially designed to meet the [/FONT][FONT=Helvetica,Arial,sans-serif]demands of the mass market end consumer for easy of operation and plug & play installation and is a way to [/FONT][FONT=Helvetica,Arial,sans-serif]access the internet at DVB-compliant high-speed at the best value available. [/FONT][FONT=Helvetica,Arial,sans-serif]The incoming DVB transport stream is delivered to the PCI bus at a speed of up to 72 Mbps. An optimized software filter [/FONT][FONT=Helvetica,Arial,sans-serif]driver manages data processing downstream by filtering. An MPEG2 / MPEG4 software decoder for TV and radio [/FONT][FONT=Helvetica,Arial,sans-serif]applications is included for reception of digital TV and radio broadcasts. The TV and radio applications include features such [/FONT][FONT=Helvetica,Arial,sans-serif]as automatic channel parsing and record/playback capabilities.[/FONT]
[FONT=Helvetica,Arial,sans-serif]Pay TV applications can be supported by an optional CI extension. [/FONT][FONT=Helvetica,Arial,sans-serif]More than one budget card can be installed in one PC to receive [/FONT][FONT=Helvetica,Arial,sans-serif]various channels simultaneously. An easy-to-use multilingual data [/FONT][FONT=Helvetica,Arial,sans-serif]management utility is provided to adjust channel and filter settings and [/FONT][FONT=Helvetica,Arial,sans-serif]to monitor incoming data. For third-party software developers an open [/FONT][FONT=Helvetica,Arial,sans-serif]API (application programming interface) is available.
[/FONT]
[FONT=Helvetica,Arial,sans-serif]Basics
[/FONT][FONT=Helvetica,Arial,sans-serif]• Low-cost PCI card for Free-TV and data application[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DVB® satellite receiver accordingly to EN 302 307[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Video and Audio decoding via software decoder[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Recording and Play back of TV/Radio programs[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Time shift support[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Teletext decoding by software[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Multicast Management support by NDIS driver[/FONT]
[FONT=Helvetica,Arial,sans-serif]• MPEG2 Transport Stream support: ISO/IEC 13818-1[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DVB-Video/-Audio support: ISO/IEC 13818-2, -3[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DVB-Data support: EN 301 192
[/FONT][FONT=Helvetica,Arial,sans-serif]RF specification
[/FONT][FONT=Helvetica,Arial,sans-serif]• Frequency range: 950-2150 MHz[/FONT]
[FONT=Helvetica,Arial,sans-serif]• QPSK demodulation accordingly to EN 302 307[/FONT]
[FONT=Helvetica,Arial,sans-serif]• RF input level: -65 up to –25 dBm[/FONT]
[FONT=Helvetica,Arial,sans-serif]• input connector: IEC F-type female[/FONT]
[FONT=Helvetica,Arial,sans-serif]• LNB control: 14/18V, 22 kHz, Tone Burst, DiSEqC 1.0, max. 400 mA
[/FONT][FONT=Helvetica,Arial,sans-serif]For DVB-S
[/FONT][FONT=Helvetica,Arial,sans-serif]• SCPC/MCPC support up to 45 Msymbols/s[/FONT]
[FONT=Helvetica,Arial,sans-serif]• QPSK with supported rates 1/2, 2/3, 3/4, 5/6, 6/7, 7/8[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Viterbi soft decoder rate ½[/FONT]
[FONT=Helvetica,Arial,sans-serif]• outer Reed-Solomon decoder as per DVB-S system[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Up to 60 Mbps channel bit rate[/FONT]
[FONT=Helvetica,Arial,sans-serif]Technical Specification TT-budget S2-3200[/FONT]
[FONT=Helvetica,Arial,sans-serif]TechnoTrend AG © 2006 Page 2 of 2 1.0
[/FONT][FONT=Helvetica,Arial,sans-serif]For DVB-S2
[/FONT][FONT=Helvetica,Arial,sans-serif]• SCPC/MCPC support up to 30 Msymbols/s[/FONT]
[FONT=Helvetica,Arial,sans-serif]• QPSK and 8PSK with supported rates[/FONT]
[FONT=Helvetica,Arial,sans-serif]• 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9[/FONT]
[FONT=Helvetica,Arial,sans-serif]• LDPC and BCH decoder as per DVB-S2 requirements[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Digital Nyquist root filter with 0.20, 0.25, 0.35 roll-off factors[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Up to 90 Mbps channel bit rate
[/FONT][FONT=Helvetica,Arial,sans-serif]Advanced Functionality
[/FONT][FONT=Helvetica,Arial,sans-serif]• HDTV support; AC3 5.1 Software decoder[/FONT]
[FONT=Helvetica,Arial,sans-serif]• TV, Radio and data services on notebooks or PC via USB 2.0 interface[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Representation, Record (incl. Timer) and Playback of TV and Radio services[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Operation System support: Windows XP[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Time shift features and record timer[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Extended EPG functionality[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Teletext support[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Automatic Channel Setup using IP multicast group address[/FONT]
[FONT=Helvetica,Arial,sans-serif]• IP-Unicast Transport using dynamic IP address to MAC address mapping[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Support MAC Address Filtering[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Use of up to 255 PID filters[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Download MPEG-2 PES speed up to 90 Mbit/s
[/FONT][FONT=Helvetica,Arial,sans-serif]Minimum PC requirements
[/FONT][FONT=Helvetica,Arial,sans-serif]• Pentium III 1GHz[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Supported Operating System: Windows 2000, XP™[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DirectX 9 or higher[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Sound card[/FONT]
[FONT=Helvetica,Arial,sans-serif]• CD-Rom (Driver and Software installation)
[/FONT][FONT=Helvetica,Arial,sans-serif]For HDTV (1080i / MPEG4 (AVC/H.264) )
[/FONT][FONT=Helvetica,Arial,sans-serif]3.4 GHz P4 (Single Core with Hyperthreading) or[/FONT]
[FONT=Helvetica,Arial,sans-serif]2.2 GHz AMD 3500+ or[/FONT]
[FONT=Helvetica,Arial,sans-serif]Dual Core P4 D820 / D830 or[/FONT]
[FONT=Helvetica,Arial,sans-serif]Dual Core AMD X2 3800+[/FONT]
[FONT=Helvetica,Arial,sans-serif]with graphics card: [/FONT][FONT=Helvetica,Arial,sans-serif]ATI X1600/X1800 or NVidia 6600GT/7600GT
[/FONT][FONT=Helvetica,Arial,sans-serif]Accessoires
[/FONT][FONT=Helvetica,Arial,sans-serif]• Receiver and CI PCI board (CI is included) each ca. 120 x 106 x 18 [mm][/FONT]
[FONT=Helvetica,Arial,sans-serif]• 1 connection flat ribbon cable to link receiver and CI board (included)[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Master CD-ROM with driver and application software[/FONT]
[FONT=Helvetica,Arial,sans-serif]• License for MPEG2 and MPEG4 (AVC/H.264) - Software[/FONT]
[FONT=Helvetica,Arial,sans-serif]decoder[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Common Interface extension for Pay-TV[/FONT]
[FONT=Helvetica,Arial,sans-serif]Standard and Regulation Compliance[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DVB® satellite standard EN 302 307[/FONT]
[FONT=Helvetica,Arial,sans-serif]• MPEG2 Transport Stream support to ISO/IEC 13818-1[/FONT]
[FONT=Helvetica,Arial,sans-serif]• DVB-Video/-Audio support to ISO/IEC 13818-2,-3[/FONT]
[FONT=Helvetica,Arial,sans-serif]• Safety and EMC regulations: EN 60950, EN 55022 and EN 55024
ΤΙΜΗ 135 ΕΥΡΩ εδώ:
http://www.dvbshop.net/product_info...end-S2-3200-HDTV-S2---Remote---Budget-CI.html
ΤΙΜΗ 129 ΕΥΡΩ εδώ:
http://shop.technotrend.de/shop.php...sid=a40466da647ff3de583beeaaeff88d6e&s=&id=42
[/FONT]
Εγώ την έχω πάρει ήδη από τα Χριστούγεννα από το dvbshop , ακόμα όμως περιμένει στο κουτάκι της για το νέο μου HTPC .... ;-)
Welcome to the Club!
Μην το καθυστερείς γιατί χάνεις!
Μαζι με ενα τ-ρεξ 4.6 εχεις πρεμιερ HD!
Αν κανω λαθος ας με διορθωσουν, αλλα νομιζω με 1.10-1.20 το εχεις ανετα. Ειναι στον Astra.
Αν καταφερω να στησω σωστα το πιατο μου, μαλλον θα εχω και γω, και χωρις t-rex.
Ρε παιδια συγγνωμη για το off-topic, αν δεν θελετε να απαντησετε εδω για να μη χαλασετε το θεμα, απαντηστε σε pm. Γυρισα σημερα by hand το πιατο απο hotbird σε astra με τη βοηθεια μονο ενος soft sat finder. Αποτελεσμα? Βλεπω μονο καθετες, και καθολου οριζοντιες. και οι καθετες οσο μεγαλωνουν χανω την ενταση του σηματος. Μπορει να μου πει καποιος τι διορθωτικες κινησεις να κανω?
Ευχαριστω θερμα.
Απάντηση: Re: Technotrend S2-3200 HDTV-S2 + Remote + Budget-CI
Είμαστε τουλάχιστον 2 άτομα που θα θέλαμε να την δοκιμάσουμε στα δικά μας htpc...
Τι λες; το κανονίζουμε;
Για Αθήνα ξεχάστε το Premiere HD !!! Θέλει 3.5μ πιάτο και άνω... ;-)
Όσο για το T-rex 4.6, το diablo κάνει τα ίδια και παραπάνω (tps) πράγματα...!! ;-)
Τάσο να παραγείλουμε 3 ετσι για δοκιμές καλές? Και ένα καλό 4.6 Trex?
Μεσα ειμαι κανονιστε το και call me.... οσο για το πιατακι των 3,5μ εχω 2 :respect: στο υπογειο και καθονται και ειναι και prime focus....:smoking:
GTX
Για πείτε πόσες θέλουμε να πάω καμιά βόλτα από κεί αύριο (είναι κοντά στο γραφείο) να δω μπας και μας κάνει καμιά καλύτερη τιμή και να δω τί παίζει με Ci γιατί δεν πρέπει να το έχει μαζί :cool_4:
Προσοχή , μάγκες, η συγκεκριμένη είναι μεν ίδια (hardware) με την Technotrend , η Technisat ¨ομως ακόμα δεν έχει κυκλοφορήσει το ci της....
Από την άλλη το ci της Technotrend παίζει μια χαρά με την Skystar HD, οπότε αν το θέλετε και αυτό, μάλλον συμφέρει η αγορά από έξω της Technotrend πακέτο με το CI (ίδια τιμή με την skystar hd, + τιμή του CI + μεταφορικά)
Δυστυχως το Progdvb δεν την βλεπει... Την εχω και την δουλευω εδω και λιγο καιρο αλλα δεν εχω καταφερει και πολλα.
Το ενσωματωμενο προγραμμα που εχει δεν με βολευει καθολου. Εχω κινητο πιατο και οταν παω να σκαναρω αλλο δορυφορο δεν μου φτιαχνει αλλη λιστα για τα προγραμματα τα πεταει ολα μαζι και γινεται της ποπης....
Το dvbviewer παντως δουλεψε κανονικα και το dvbdream.
Κανουν βεβαια καποια κολληματα αλλα υποψιαζομαι οτι φταιει που το pc μου χρειαζεται κανενα format για να ερθει στα ισα του...
Με μοντουλα δεν εχω δοκιμασει ακομα αλλα εχω παραγγειλει μια diablo και μολις την προγραμματισω και τη βαλω θα σας πω...
Αν παρεπιπτωντος ξερει κανεις καμια σελιδα με υλικο για την μοντουλα αυτη ας στειλει κανενα pm.
  • loggeo
mrkgeo
