Enas kainourgios zhtaei ta fwta sas...
katarxas na kalhsperisw olous sas kai na afxithw kalh xronia an kai ligo arga!poli prosfata anakalipsa to site sas giafto!LOipon twra stis giortes eipa na ftiaksw kai ena trito susthmataki gia to dwmatio gt sto saloni den xwraei kalodio pleon:crazy_3:!mousiki ithela na akouw apo to notebook mp3 kirios alla dennevriska llisi mexri pou diavasa gia ton dared mp-5!telika ton agorasa sindeete kai me usb oti prepei!to provlhma mou egite sto ti hxeia telika tha prepei na tou tairiaksw!ixitika einai apistefta ikanopoiithkos gia ta lefta tou!alla vgazei 2x13 watt opotre kai ta perissotera ixeia baseis/bibliothikhs logo tis evesthisias tous den me vriskoun simfwno(an kai paizei kala me 2 hxeia vashs idiokataskevhs peripou 89db/w/m an thimame kala)!epsaksa thn agora akousa arketa alla den me enthousiasane kai toso!En telei exw kataliksei se 2 diafofretikes liseis alla exw aporeia kai xreiazomai th voitheia sas!1on anaferomai sta klipsch rf-10(kserete ta mikra dapedou) ta opoia ta exw vrei sta 296euro kai prosopika ta theorw parapoli kala dedomenou oti exw adinamia sthn marka kai stis kornes tha einai poli efkolo fortio 8Ω kai exoun kai ipsili euaisthisia 96db opote den tha diskolepsoun ton mp-5!2on apo thn allh omws epsaksa kai epesa panw sta sonus faber concertino domus ta opoia me afisan anavdo molis ta akousahtan pragmathka magefthkh h ebeiria alla ta akousa me polla parapanw apo 13watt pou deinei o mikros mp-5 kai dedomenou ths evaisthisia tous 88db(twra to fortio den kserw allou vlepw 4Ω allou 6Ω)isws ton disolpsoun ti lete?Akoma iparxei kai kati allo ta concertino ftanoun mexri ta 50hz kai efoson akouw kai rock kai jazz ta baso isws na mou einai ena mikro provlhma to opoio dirthwnete vevaia me ena gouferaki!En katakleidi pistevete pws aksizei na ependisw sthn defterh lisi pou einai fanera pio akrivh h mhpws na arkestw sth efkolh men(pros pokthsh)alla kalh 1h lish ta klipsch????
perimenw apadiseis sas kai sas efxaristw ek ton protero
Ta Hxeia pou xreiazesai prepei na exoyn polla dB. Ta 96 tou protou Hxeiou einai kala, ta 88 OXI. Alitheia giati grafoume FrankoLevantinika ?
Απάντηση: Enas kainourgios zhtaei ta fwta sas...
grafw pio grigora etsi!den kserw den thewrw pws einai o monos paragodas ta db!koitakse t shsthmata pou proteinw gt i dignomia mou egite sto an tha akolouthisw thn pepathmenh diladi mikros enisxiths mikris apodothkothtas watt diladi ara ton voithame me ena efkolodigito hxeio h na kanw thn ipervolh mou me t concertino pou einai men pio diskola alla exoun aparamilo hxo(outos h allos h sonus faber den vgazei tuxaia modela einai ola ena kai ena mhpws na stirixtho sthn istoria kai to onoma ths)?
Φιλικη συμβουλη,αν γραψεις με ελληνικους χαρακτηρες θα ειναι πιο ξεκουραστο για τα μελη να διαβασουν τα μηνυματα σου αρα και για να σε βοηθησουν.
Re: Απάντηση: Enas kainourgios zhtaei ta fwta sas...
Συμβαινει να γνωριζω αυτο το θεμα καπως καλα. Εαν θελεις να αξιοποιησεις την δικη μου εμπειρια μην παρεις ΤΙΠΟΤΕ λιγοτερο απο 93 dB. Τα Sonus Faber ειναι εξαιρετικα Ηχεια και τα Τατρα εξαιρετικα φορτηγα, αλλα κανενα απο αυτα δεν σου κανει, λογω 13 Βαττ τα πρωτα, και λογω του οτι δεν κινεισαι κατεξοχην στην ερημο τα δευτερα.
Κυριε Μιχαλη σας ευχαριστω θερμα!Μαλλον το βλεπω να περναω σε αναβαθμιση του κεντρικου συστηματος αρχικα με τα concertino και μετα μαλλον θα παω σε καποια λυση λαμπατου amp ισως και ιβριδικου λογο απαιτουμενων watt και να παω στον μικρο τα diy μου που ειναι 93!Σκεφτομαι ακομα και για prima luna prol.2 αλλα εχουμε καιρο ακομα γι αυτα.....ελπιζω να ειστε εδω να μας βοηθατε....:prof:
Βρε Μηνα, σε εβρισα εγω ? Τι θα πει Κυριε ?
Οτι θελεις βγες εδω και πες το.
Για κατι πιο ιδιαιτερο υπαρχει το ΡΜ.
Τι περιπου ειναι τα DΙΥ ηχεια σου ??
Πληροφοριακα ο prol.2 βγαζει 2x 29 Watt, απο 2x KT88 Pushpull στο καναλι. Λιγα για ΚΤ88, οι οποιες θα μπορουσαν να δωσουν ΑΝΕΤΑ 2X 50 εως 2x 60 Watt, υπο αλλες συνθηκες.
ΟΣο για το τελευταιο εχεις αντιθετες πληροφοριες ??
Επισης οπως ισως παρατηρησες, προσωπικα δεν χρησιμοποιω τις διαφορες μουρες για να εκφρασω κατι. Καθε φορα που πηγα να το κανω δεν βρηκα μια που να περιγραφει ακριβως αυτο που θελω να εκφρασω. Αυτο, ας πουμε, τρεχα γυρευε πως θα το παρει ο αλλος :cool_1:. Αλλοι βεβαια τις χρησιμοποιουν συνεχως ....
Μα καλα μας δουλευουν τα περιοδικα???2Χ40 δεν ειναι ο προλ.2 με τις ΚΤ88???Tα ιδιοκατασκευης το ενα ζευγαρι ειναι 2δρομα με μεγαφωνο(bass)της spicom P-17-01 6 1/2 inc αυτα νομιζω που φοραει στο πισω μερος το sigma ultra 1000 και τουιτερακια δεν θυμαμαι ποια αλλα ειναι τουιτερ θολου τιτανιου:crazy_1:!8Ω και πρεπει να ειναι καπου στα 89-90db δεν ειμαι σιγουρος ισως και λιγο παραπανω παει καιρος,δεν τα εχω και μπροστα μου
ειναι στην πολη που σπουδαζω και εγω λογο καταληψεων στη γεννετηρα!Το cross και αυτο δεν θυμαμαι..
!Α επισης ειναι 100 watt(max input μετα εχουν προβλημα
),οπη bass reflex δεν τους εχω και μεσα ειναι γεμισμενα με υαλοβαμβακα παχους 5cm!Παιζουν απιστευτα ομορφα και μελωδικα αλλα εχουν ενα μειονεκτημα οτι αγαπανε πολυ την οπερα και γενικα τη φωνη μουσικη/ες που μεν ακουω αλλα οχι κατα κυριο λογο! Οσο για τις φατσες βοηθανε να γινετε καπως πιο εκφραστικο το κειμενο
To test στον Ηχο αναφερει σαν Ισχυ που ανακοινωνεται απο τον Κινεζο-Ολλανδο-Εβραιο κατασκευαστη 2x 40 Watt. Οι μετρησεις του περιοδικου για το κομματι του τεστ εδειξαν 2x 29 Watt. Δικες μου μετρησεις σε αλλο κομματι εδειξαν 2x 29 Watt, το ενα καναλι οδηγουμενο @1KHz, @ . Με τα δυο καναλια οδηγουμενα στις ιδιες συνθηκες 2x 27Watt.
Οποιοςδηποτε αλλος γνωστος σε μενα Ενισχυτης με 2x ΚΤ88 ΡΡ σε ταξη ΑΒ1 βγαζει τουλαχιστον 2x 55 Watt.
Εαν θελεις διαβασε εδω
http://www.Audiocraftworks.gr/gr/pages/arthra/erotapant/china.htm
ειναι στην πολη που σπουδαζω και εγω λογο καταληψεων στη γεννετηρα! Το cross και αυτο δεν θυμαμαι..
Γιατι οχι ? :crazy_1: Παρε ενα πολυβολο και ριχτους :crazy_1: :crazy_1: :crazy_1:
Η τελευταια μοδα μετα απο κατι τετοιο, ειναι να περνας στις τρυπες χαλκινα σωληνακια.
Ο υαλοβαμβακας δεν κανει καλο στην υγεια. ΑΚΥΡΟ ΤΟ ΠΕΡΙ ΤΡΥΠΩΝ. Δεν πρεπει να διαρρευσει το κακο υλικο. Εξαλλου ητανε πλακα.
Και τωρα σοβαρα : Οι Αυλοι του Bass Reflex ως γνωστον δεν γινονται στην τυχη ουτε καν κατ' εκτιμηση.
Διαβασε εδω
http://www.AudioCraftworks.gr/gr/pages/arthra/erotapant/bassreflex.htm
Αυτο εχει την μεγαλυτερη σημασια. Νομιζεις οτι καποιος που ΕΧΤΙΣΕ κορνες στο υπογειο του, ή ο αλλος που εχει 2 Τζακια σε Push Pull (δες τα στην High End) την βρισκουν περισσοτερο απο εμας ακουγοντας Μουσικη ? Ασε που θα αργησουν πολυ να αποδωσουν αυτες οι λυσεις μεχρι να στρωσουν τα Τουβλα. Το τελευταιο με επιφυλαξη, διοτι μπορει τα τουβλα να ειναι ειδικη παραγγελια Ματσαρισμενες παλλετες.
Γιατι το λες μειονεκτημα. Ειναι φανερο οτι τους εχεις δωσει απο μικρα την καταλληλη παιδεια. Την σημερον ημεραν τα νεα Ηχεια μεγαλωνουν με Οπρα αντι για οπερα.
Καλη Αποκρια "happy_1" :happy_5: :crazy_3: :cool_4: :bravo: :happy_4: :happy_9:
χαχααχαχαχα αγαπητε μιχαλη πεθανα στα γελια με το μυνημα σου:happy_5::happy_5::happy_5::happy_5:!οντως ο υαλοβαμβακας δεν κανει καλο αλλα οταν τα εφτιαχνα δεν ειχε γινει ο ντορος με αυτο το υλικο αν θυμαμαι καλα η απλα δεν το ηξερα!τεσπα εχω και αλλο ενα ζευγαρι αλλα θα στα πω αλλη φορα γιατι τωρα παω να παρω το αισθημα αλλιως θα πεσει Mitsuko......
Bcnu OM
(Be seeing you Old Mate)
Που το βρηκες αυτο το προσκοπακι !!!
Ή μηπως ειναι απ' το Τζιπανγκο ή την Καρθαια, 'ναθεμα τον Μαρκο Πολο.
Τι σκαλιζε ο Χριστιανος να βρει ? :happy_4: Την Mitsuko που λεει κι ο αλλος ?
opanamas
