ΝΟΚΙΑ Ε65
Πολύ όμορφο νέο κινητό από την ΝΟΚΙΑ.
Slide αι στην "επαγγελματική" σειρά.
Δεν ξέρω τιμή αλλά από προδιαγραφές σκίζει!!!
Αν αγόραζα σήμερα κινητό θα ήταν σίγουρα μέσα στην τελική 3άδα!!
Key features
Key features
  • Get more out of your workday with a range of business features: conference calling, voice recording, notepad, integrated handsfree speaker, talking ringtones, and Nokia Team Suite
  • Send messages using an extensive range of options: SMS, MMS with distribution lists, instant messages, and email
  • Access business functions quickly and easily: One Touch keys for conference calls, mute/unmute, and contacts
  • Talk around the world with quad-band coverage on up to five continents
  • Show your sense of style with the slim, stylish slide design
  • Work hard, play hard – listen to your favorite tunes or watch video clips with the music and media players
  • Take snapshots with the 2 megapixel camera
Operating frequency
Operating frequency
  • Quad-band: EGSM 850/900/1800/1900
  • WCDMA 2100
  • Voice over IP (VoIP) calls via integrated WLAN
    • WLAN: 802.11b, 802.11g*
    • WLAN Security: WPA2-Enterprise, WPA2-Personal, WPA-Enterprise, WPA-Personal
    • WLAN Quality of Service: WMM, U-APSD
Size
Size
  • Volume: 74 cc
  • Weight: 115 g
  • Dimensions: 105 x 49 x 15.5 mm
Display
Display
  • Active-matrix QVGA color display (240 x 320 pixels) with color support for up to 16 million colors
  • Display contrast and brightness control
User interface
User interface
  • S60 3rd Edition, built on the Symbian operating system
  • One Touch keys for mute/unmute, contacts, and conference calling
  • Five-way Nokia NaviTM key with two customizable soft keys, power key that can be used as profile key, and My Own key
  • S60 edit key located on the side of the device
  • Volume keys on the side of the device
Imaging
Imaging
Messaging
Messaging
  • Read email with attachments: supports POP/IMAP, SMTP, and IMAP4 with idle protocols
  • Instant messaging client (OMA IMPS 1.2)
  • Multimedia Messaging Service (MMS, ver. 1.2) for text, voice clips, video clips, and still images
  • SMS and MMS with distribution lists
  • Predictive text input T9
Multimedia
Multimedia
  • Video and audio streaming (3GPP & Real Media)
  • Music player (MP3/AAC) and media player
  • Open Mobile Alliance (OMA) digital rights management (DRM) 1.0 with forward lock
Memory functions
Memory functions
  • Up to 50 MB user memory
  • MicroSD memory card support
Applications
Applications
  • Java™ MIDP 2.0-based games and applications
  • Attachment viewers for documents, spreadsheets, and presentations
Connectivity
Connectivity
  • Dual Transfer Mode (MSC 9)
  • Bluetooth 1.2 wireless technology
  • Pop-Port™ connector
  • IrDA with transfer rate up to 115 kbps
Browsing
Browsing
  • HTML Nokia browser
  • XHTML browser (HTTP stack)
Data transfer
Data transfer
  • EGPRS multi-slot class 32 for 5 + 3 (receive + transmit) timeslots (up to 6 timeslots total for maximum download speeds of up to 296 kbps)
  • Multi-slot class 32 is also supported with GPRS for a maximum downlink rate of 67 kbps
  • Remote and local (peer-to-peer) synchronization of calendar, contacts, notes and to-do list via Bluetooth technology, IR, or USB connectivity cable
Personal information management (PIM)
  • Calendar with weekly view, contacts, to-do list, and notepad for short notes – all viewable while managing a phone call
Voice features
Voice features
  • One Touch keys for direct access to contacts, mute/unmute, and conference calling
  • Voice dialing
  • Voice commands for menu short cuts, keypad lock, and profiles
  • Voice recording to record your own notes or conversations
  • Talking ringtones mix the name of the caller with the ringtone so you know who’s calling without looking at the screen
  • Integrated handsfree speaker
  • Supported speech codecs: EFR, FR, AMR NB, HR
  • Conference calling
Digital services
Digital services
  • Over the air (OTA) downloads for ringtones, contacts, email, WAP, MMS, operator logos, and user group icons
  • Image upload/download
  • Smart content upload/download
  • Downloadable instrumental MIDI ringing tones
Other features
Other features
  • Add-on solutions enable integration into enterprise private branch exchange (PBX) infrastructure
Sales package contents
  • Nokia E65 receiver
  • Nokia Battery BL-5F
  • Nokia Travel Charger AC-4
  • Nokia Headset HS-5 (black)
  • Nokia Connectivity Cable CA-53
  • Nokia Carrying Pouch CP-18
Power management
Power management
Battery Talk time Standby time Capacity Battery BP-5FUp to 3 - 6 hours GSMUp to 1.8 – 2.5 hours WCDMAUp to 2.2 - 3 hours VoIPUp to 7 - 11 days GSMUp to 8 - 14 days WCDMAUp to 4 - 5 days GSM/WCDMA and WLAN1000 mAhOperation times vary depending on the network and usage.
Re: Απάντηση: ΝΟΚΙΑ Ε65
(ποτέ δεν κατάλαβα γιατί πρέπει το τηλέφωνο να έχει ραδιόφωνο)
Καλημέρα Σπυράκο!!!:happy_4:
Kάμερα 2ΜΡ είναι ήδη παραπάνω από αρκετή για μένα. Οπότε ΟΚ
Για το ραδιόφωνο......
Σπύρο, εσύ κι εγώ ζούμε (ευτυχώς) πολλά χιλιόμετρα πιο μακριά από την Αθήνα. Και πάμε στη δουλειά με τα οχήματά μας. Οπότε (τουλάχιστον για το αυτοκίνητο) μπορούμε να ακούμε τα νέα από το ραδιόφωνο του αυτοκινήτου μας.
Υπάρχουν όμως πάρα πολλοί που πάνε στη δουλειά τους καθημερινά με ΜΜΜ (ηλεκτρικό, λεωφορείο, μετρό) και η ύπαρξη ραδιοφώνου στο κινητό τους είναι πολύ σημαντική!!:happy_6:
minas
Πισιά
grrrr
με βάλατε σε λούκι τώρα.
Με μια πρώτη ματιά φαίνεται άψογο...
VG
Αν μπορεις να διαβασεις τα πολυ μικρα του γραμματα,καλο ειναι.
Γενικα τα business phones της Nokia ειναι καλα.
minas
Πισιά
Εμφανισιακά έχω κι εγώ κάποιες μικρές ενστάσεις, αλλά από τα χαρακτηριστικά του δε μου λείπει τίποτα...
Μάλιστα με κάνει να σκέφτομαι να αλλάξω το κινητό μου νωρίτερα. Όταν το δω και από κοντα θα έχω περισσότερα στοιχεία.
n_olympios
Μαντιναδόρος!
Αρκεί να θυμάστε ποιος πήρε πρώτος κινητό της σειράς Ε. :prof: :cool_3:
Μόλις απέκτησα το κινητό. Είναι γενικά πολύ πρακτικό και πολύ βολικό. Όμως δεν μπορω να πω ότι δεν θα με βόλευαν μεγαλύτερα γράμματα. Να ρωτήσω λοιπόν, δεν ειναι δυνατόν με τίποτα να αλλάξει το μέγεθος των γραμμάτων??
Ευχαριστώ
jimacid
