PIONEER S-1EX
Ενα από τα πιο ενδιαφέροντα και συζητημένα ηχεία
της εποχής μας !
Η κορυφαία τεχνογνωσία της TAD υλοποιημένη με
μάλλον ιδανικό τρόπο σε κόμπακτ διαστάσεις!
Θέλετε να το ακούσουμε ;
Gebreselassie
Μαύρος!
της εποχής μας !
Θέλουμε λέει..... :bravo: :bravo: :bravo:
Κώστας Φ.
Απάντηση: PIONEER S-1EX
Ωχ, ωχ....Παρακαλώ μπορεί να γίνει σε 2 μηνάκια η παρουσίαση?! Πρέπει να φύγω για Αγγλία και δε θα αντέξω να χάσω τέτοιο event...15 Ιουνίου είναι καλά!
Έχω βαρεθεί να διαβάζω ύμνους για τα Pioneer και ψοφάω να τα ακούσω! :happy_2:
Μη με κάνετε να σαμποτάρω τη διαδικασία! Ευχαριστώ εκ των προτέρων για την κατανόηση! :respect:
Re: Απάντηση: PIONEER S-1EX
Μαααααααααλον τοτε θα γινει!!!:happy_8:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
http://www.stereophile.com/floorloudspeakers/307piosex/
Conclusions
I never bought into "trickle down economics" before, but Pioneer and Andrew Jones have applied the audio technology they learned in making the TAD Model 1 to a much less expensive speaker that has retained a disproportionate amount of the TAD's performance. Sure, $9000 is not pocket change. On the other hand, the S-1EX is fully competitive with higher-priced speakers that have spent time in my listening room, such as the B&W 802D ($12,000/pair) and the now-discontinued Revel Ultima Studio ($15,000/pair)—and with anything I've heard in demos. In regard to ease of placement in a domestic room not exclusively dedicated to listening, the S-1EX surpassed all other speakers I've used. This means that anyone who buys the Pioneer is more likely to enjoy optimum results than with more finicky speakers. If you've read this far, you know that I love the Pioneer S-1EX. It is a full-range speaker with great transparency, dynamic potency, and truly neutral tonality. The speaker's ease of placement and setup are aided by its ability to immediately and easily reveal how it is affected by changes in position—when the Pioneers are in the right places, you'll know it. Then you'll stop thinking about the S-1EX and all its technological features, because you'll be listening to the music. Ladies and gentlemen, we have a winner. "
Είδα το ηχείο από κοντά λίγη ώρα μετά την έξοδο του
από την συσκευασία του .
Το συγκεκριμένο φινίρισμα δεν το είχα ξαναδεί .
Είναι στο επίπεδο των ακριβών Ναυτίλων .
Η γενικότερη ποιότητα κατασκευής φαίνεται εξαιρετική.
Για τον ήχο είναι νωρίς ακόμη για να εκφέρουμε σχόλια.
Θα αρκεστώ σε μια ατάκα του Gio που με βρίσκει
απόλυτα σύμφωνο : "Εδώ υπάρχει πολύ ζουμί !"
ps Χάρηκα που γνώρισα από κοντά τον Κώστα EAR !
Μια ιδιαίτερα ευγενική και ενδιαφέρουσα φυσιογνωμία
που αδικείται κατάφωρα από τις φωτογραφίες !
Ενας άνθρωπος που απολαμβάνεις να περνάς την ώρα σου
μαζί του συζητώντας σε υψηλό επίπεδο για οτιδήποτε !
Κώστας Φ.
Άλλο ένα review, αυτή τη φορά απο το Positive-Feedback.com, ΕΔΩ.
"The S-1EX is an engineering marvel and sounds as they should. Give 'em a listen!"
(με τον πόνο μου παίζει αυτός... :pc: )
http://www.positive-feedback.com/Issue30/pioneer_s1ex.htm
Specifications
Enclosure; Front-vented bass reflex, Floor-standing type
Speakers (Tweeter): Concentric driver: 1-3/8 in. (3.5cm) Beryllium dome
Speakers (Midrange): Concentric driver: 5-1/2 in. (14cm) Magnesium cone
Speakers (Bass): 7-1/16 in. (18cm) Aramid cone (x2)
Frequency Range: 28 - 100,000 Hz
Sensitivity (2.83 V/1 m): 89.5 dB SPL
Nominal Impendance: 6 Ohms
Maximum Power Input: 200 W
Cross-over Frequencies: 400 Hz, 2 kHz
Dimensions (WxHxD) - inches: 16-5/8 x 50-1/2 x 24
Dimensions (WxHxD) - mm: 422 x 1283 x 609
Weight: 145 lbs. 8 oz.
Finishes: Cabinet: Genuine Dark Teak veneer (satin finish)
Grille: Black cloth
S-1EX loudspeakers
Retail: $9000 pair
Gebreselassie
Μαύρος!
Παιδιά ο Βασίλης έχει μπλέξει με κάτι δουλειές, θα έχουμε νέα μέχρι το μεσημέρι.
Η ακρόαση θα γίνει αύριο στις 14.00 περίπου στον γνωστό
χώρο της ηχοέκφρασης .
Για προφανείς και γνωστούς λόγους θα ακολουθηθεί μια τακτική
ανάλογη (όχι φυσικά όμοια) με αυτή που χρησιμοποιείται στα τελευταία
τεστ των βιντεοπροβολέων .
1)Θα έχουν συμμετοχή μόνο 4 άτομα .
2)Κάθε ένα από αυτά θα φέρει τα cd που χρησιμοποιεί συνήθως στο
δικό του σύστημα για ακουστικές εκτιμήσεις .
3) Κάθε ένας θα κάθεται στην ιδανική θέση ακρόασης για 15-20 min
και θα ακούει το δικό του μουσικό υλικό στις στάθμες δικής του
επιλογής
Εάν θέλει μπορεί να είναι και μόνος του στον χώρο ακρόασης !
4) Μετά την ολοκλήρωση των ατομικών ακροάσεων μπορούμε να
ασχοληθούμε με το σύστημα με όποιο τρόπο θέλουμε με την μορφή
των ακροάσεων που υλοποιούνταν παλαιότερα.
5) Οι 4 που θα δηλώσουν πρώτοι συμμετοχή θα αποτελέσουν και
το πάνελ των ακροατών .
6) Κατά την διάρκεια των ακροάσεων επιβάλλεται για πρόδηλους λόγους
να μην περιφέρεται κανείς άσκοπα και να μην γίνονται συζητήσεις
7) Εξυπακούεται ότι θα πάρουμε απλά μια πρώτη γεύση από ένα σύστημα
σε ένα χώρο χωρίς να γνωρίζουμε αν τα ηχεία αξιοποιούνται στο
maximum των δυνατοτήτων τους . Και αυτό γιατί χρειάζεται επαρκής
χρόνος και ψάξιμο για το tuning και το fine tuning ενός συστήματος .
Και τέτοιος χρόνος απλά δεν υπάρχει για αντικειμενικούς και
υποκειμενικούς λόγους .
Christos Kourmouzoglou
