χωρις λογια
και δεν μας βλεπω να βγαινουμε αλλα να πηγαινουμε πιο βαθεια στη σπηλια
ευτηχως πιο μεσα θα ειναι πιο καθαρα οποτε θα εχουμε φρεσκο χωρο για βρωμισμα say loud I am derti and I am proud
μωρε τι ενισχυτικα ειναι αυτα ναυτιλομενα ειναι ,και αυτα τα παλιοηχεια χαλι μαυρο
minas
Πισιά
Σνιφ....πάντα είχα αδυναμία στις κόρνες, αλλά είναι....ακριβό σπορ :crazy_1:
το glenfidiech και το glenrothesh οσο πιο παλια τοσο πιο καλα και ακριβα
Nick Arvanitakis
Audio Pro
[FONT=Arial, Helvetica, sans-serif]JBL SYNTHESIS ATLAS POWER BY THE CUBIC FOOT[/FONT]
[FONT=Arial, Helvetica, sans-serif]THE FRONT SOUNDSTAGE INCLUDES three SK2-1000 four-way speaker systems with dual 10-inch woofers, featuring beryllium midrange and ultrahigh-frequency compression drivers in a specially designed Bi-Radial combination horn, incorporating JBL’s most advanced professional technologies. Enveloping the listener, and invisible to the naked eye, six S4A multipole in-wall ambient surround speakers, each with three 1" titanium high-frequency tweeters, two 4" mid-bass drivers and one 8" dual-coil woofer. Powerful, rich bass emanates from four S1S-EX 18" 800-watt subwoofers. The electronics package includes the SDP-40 processor/controller, SDEC-2500A digital equalizer, two S7150 (7 x 160-watt) and four S800 (1 x 800) power amplifiers. Designed for listening rooms of up to 45,000 cubic feet.[/FONT]
45,000 CUBIC FEET
1,270 CUBIC METERS3520 WATTS94dB CINEMA HIGH FREQUENCY94dB MUSIC HIGH FREQUENCY96dB LOW FREQUENCY
SYSTEM CONTAINS:3 – SK2-1000DG 3-Way, Dual 10-Inch Center Speaker 4 – S1S-EX 18" (457mm) THX Ultra2 Subwoofer 6 – S4AI Vertical or Horizontal Multipolar Flush-Mount THX® Surround Loudspeaker 1 – SDP-40 THX® Surround Processor/System Controller 1 – SDEC-4000 Synthesis 12 Channel Input and 20 Channel Output Digital Equlizer System 4 – S800 2 x 200 Watt, 1 x 800 Watt THX® Power Amplifier 2 – S7150 7 x 160 Watt THX® Power Amplifier
[FONT=Arial, Helvetica, sans-serif]SK2-1000DG [/FONT]
[FONT=Arial, Helvetica, sans-serif]3-Way, Dual 10-Inch Center Speaker [/FONT]
[FONT=Arial, Helvetica, sans-serif]SDEC-4000 [/FONT]
[FONT=Arial, Helvetica, sans-serif]Synthesis 12 Channel Input and 20 Channel Output Digital Equlizer System [/FONT]
[FONT=Arial, Helvetica, sans-serif]S1S-EX [/FONT]
[FONT=Arial, Helvetica, sans-serif]18" (457mm) THX Ultra2 Subwoofer [/FONT]
[FONT=Arial, Helvetica, sans-serif]S800 [/FONT]
[FONT=Arial, Helvetica, sans-serif]2 x 200 Watt, 1 x 800 Watt THX® Power Amplifier [/FONT]
[FONT=Arial, Helvetica, sans-serif]S4AI [/FONT]
[FONT=Arial, Helvetica, sans-serif]Vertical or Horizontal Multipolar Flush-Mount THX® Surround Loudspeaker [/FONT]
[FONT=Arial, Helvetica, sans-serif]S7150 [/FONT]
[FONT=Arial, Helvetica, sans-serif]7 x 160 Watt THX® Power Amplifier [/FONT]
[FONT=Arial, Helvetica, sans-serif]SDP-40 [/FONT]
[FONT=Arial, Helvetica, sans-serif]THX® Surround Processor/System Controller [/FONT]
Αυτο σ αρεσει?:cool_4:
τι να τις κανω τις balance στο 1 μετρο interconect
jimacid
