S1Digital Media Platinum
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Operating System:
Vista Home Premium
Processor & MB:
Intel Core 2 Duo E6600 CPU - 2.40GHz, 4MB L2 Cache, 1066 FSB - Cooler, quiter, more powerful
Intel G965WH MB with Intel Viiv Technology
Memory:
2048MB (2GB) DDR2 RAM
Hard Disk:
640GB to 1TB SATA Hard Drives with Native Command Queuing (NCQ) in RAID 0 or RAID 0+1 - for extremely high performance
Audio:
7.1 Channel High Definition Audio - with digital optical or analog outputs
- 95dB SNR
- Sample rates up 192kHz
- Eight Channel (4 DAC pairs and 2 stereo ADCs) with 24-bit resolution
Network:
10/100/1000 MB/s wired network connection, optional 802.11b/g wireless – so you can connect to the internet or a home network
Remote, Keyboard & Mouse:
Wireless remote and keyboard/mouse - control your Media Center from the couch
DVD:
HD-DVD, Blu-ray or DVD+DL drive – so you can burn your own DVDs and CDs for playback in standalone DVD and CD players (except HD-DVD option cannot burn discs).
Video Card:
Nvidia 7600GT (256MB RAM) – with DVI, HDMI (with HDCP), VGA (with adapter), Component video output. (Note the HDMI interface does not carry audio as well at this time)
TV Recording:
CableCARD or Dual Over the Air HDTV and Dual SDTV Tuners – watch and record your cable, satellite or OTA HDTV programs
Memory Card Reader:
42 memory card types
Color:
Black or Silver case – will fit right into your home entertainment center
Dimensions:
425 mm (W) x 170mm (H) x 425 mm (D)
http://www.s1digital.com/Media_Center_Platinum_HDTV_Edition_p/mcpe.htm
Απάντηση: S1Digital Media Platinum
nice thing αλλα και 2900$ ειναι πολλα τα λεφτα αρη
minas
Πισιά
Δεν κάθησα να διαβάσω πολλές λεπτομέρειες, αλλά πολλά ανεμιστήρια έχει :pc:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Re: Απάντηση: S1Digital Media Platinum
2900 ειναι πολλα αλλα εαν κοψεις απο καλωδια, isolators και τις αλλες μπουρδες που χαλας τα χρηματα σου θα σου ερθουν μια χαρα!:cool_4:
δεν ειναι θεμα που χαλαω τα λεφτα μου γιατι τα καλωδια τα isolators θα τα εχω και μετα απο 5 χρονια το εν λογω pc θα το εχω κανει σιντοθηκη μιας και αυτα που κανει τωρα σε 5 χρονια θα γελαμε με τις επιδοσεις του ενω το καλωδιο παλι θα φτιαχνει τον ηχο και τα isolators μια απο τα ιδια
pc και προβολια ΔΕΝ ΕΙΝΑΙ ΔΙΑΧΡΟΝΙΚΑ
κουφαθηκαν τα συρματα δικε μου
Εχω ακριβώς το ιδιο κουτί σε μαυρο και ειμαι ενας ευτυχής θεατής υψηλης ευκρίνειας.
Όταν πέσουν οι τιμες των drives συρταρωνω ένα και καθάρισα.
Andreas79
