London Decca Reference cartridge
Κώστας Φ.
London Reference Phono Cartridge
Technical Specifications:
Type: Moving-iron/positive scan phono cartridge
Output: 5mV
Tracking force: 1.5 not to exceed 2 grams
Input impedance: 100 to 300pF
Compliance laterally: 15 x 10-6cm/dyne
vertically: 10 x 10-6cm/dyne
MSRP: $5295
"The London Reference, previously known as the Decca Cartridge, has been in production longer than stereo has been around. As a stereo cartridge, it had it’s beginning in the seventies as the Decca Phono Cartridge.
Theoretically, because of their magnet designs, the Decca and London Reference cartridges should suffer a little by comparison with the best moving-coils and moving-magnets. However, in practice, I did not find this to the be the case. I think this is because soundstaging has more to do with low-level detail retrieval than it does with separation of the two channels. So it is not surprising that a cartridge that excels at detail and information also excels at special information. The Decca is exceptionally good at letting you hear acoustical information of the hall or venue. In my experience, this is another trait that leads to a believable soundstage.
IN CONCLUSION
If you can put up with and take care of these two quirks, the London Reference Phono Cartridge is indeed exactly that: a reference cartridge, one that sets a reference for transparency, immediacy, and music is-in-your-room experience."
Full Review: DAGOGO.com
Κώστας Φ.
Απάντηση: London Decca Reference cartridge
66,1875 φορές καλύτερη (αν εξισώσουμε € με $).
Ερώτηση παγίδα είναι αυτή, Μαρίνο? Φαντάζομαι δεν υπάρχει σύγκριση.
Στη χαμηλή κατηγορία τιμής προτιμώ τις Denon πάντως...
LUXMAN
Re: Απάντηση: London Decca Reference cartridge
66,1875 φορές καλύτερη.
Κατι μυριστηκες !! :happy_5: :happy_5:
Που παει το μυαλο σου ;;;
Ποσο περισσοτερη (και ποσο σωστοτερα) πληροφορια αντλει απο ενα δισκο ;;
LUXMAN
Που ειναι οι συνηθεις καλωδιοδιωκτες ;;; Δεν συγκινουνται με κεφαλες ;;;
Η υποκρισια τους σ ολο της το μεγαλειο !!
Ημίθεος
Μη μπερδεύεις τις γεννήτριες εναλλασσόμενου ρεύματος με τα καλώδια.
Αν κατάλαβα καλά είναι η παλιά κλασσική Decca; Εχω την εντύπωση ότι για τα χρήματα που ζητάει μαλλον έχει ξεπεραστεί, βέβαια έχω χρόνια να την ακούσω και δεν την άκουσα με καινούριες σχεδιάσεις phono κλπ.
Τσαμπα ειναι . Ποσο καλυτερη ειναι απο π.χ. την ORTOFON 520 των 80 ευρω ;;;
Ρε παιδιά γιατί 'πάτε' από το ένα άκρο στο άλλο?? Από τα 5.500 ε στα 80 ε ??
Δηλαδή ενδιάμεση κατηγορία που να παίζει καλά δεν υπάρχει???
Οι shelter 501, benz ace, grado reference, denon δηλαδή δεν παίζουν καλά ή είναι ακριβές??? Έλεος πια... Δηλαδή ή πάμε στα υπερτιμημένα hi-end φετίχ ή στις μπουρούχες??? Άμα τα σκάμε σε αυτοκίνητα και ζαντολάστιχα ή για κουρτίνες και χαλιά για το σπίτι είναι χαλάλι... Άμα έρθει η ώρα να πάρουμε ένα μηχανάκι της προκοπής μας ξυνίζουν τα 500 ευρώ και πρέπει να πάρουμε τη μπουρούχα των 80 και καλά γιατί δεν έχει διαφορά... Κατά τα άλλα 'αγαπάμε' τη μουσική...
Κώστας Φ.
Απάντηση: Re: London Decca Reference cartridge
Eπί της ουσίας είναι η ίδια κεφαλή, ναι.
Αυτό βέβαια δεν είναι κατ'ανάγκην κακό, η DL-103 της Denon βγαίνει ίδια κι απαράλλαχτη απο το 1962 και εξακολουθεί να παίζει απίστευτα καλά για τα χρήματα που ζητάει, απλά, όπως λες κι εσύ, στην κατηγορία τιμής της Decca ο ανταγωνισμός λειτουργεί τελείως διαφορετικά...
LUXMAN
Η ερωτηση ηταν παγιδα . Απευθυνονταν στους "καλωδιοδιωκτες" .
Σαφως και υπαρχει διαφορα και μαλιστα μεγαλη γι αυτους που ακουνε βυνιλιο .
LUXMAN
Αααα.... αυτες δικαιουνται να κοστιζουν 3286 φορες περισσοτερο , η ακριβοτερη απο την φθηνοτερη :happy_4:
Παιδιά κυκλοφορεί και decca Marroon στις 450 λίρες Αγγλίας.
Σε σχέση με Grado, Nagaoka ή άλλη της ίδιας τιμής τι παίζει;
Έχει ακούσει κανείς κάτι από Decca?
wendigo
