JBL Synthesis
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Πριν λιγο διαβασα μια ειδηση πως στο φεστιβαλ των Καννων θα χρησιμοποιησουν αποκλειστικα τα συστηματα ηχου Synthesis Atlas
http://www.soundinvestment.co.za/JBLSynthesis/JBLFrame.htm
Ξερουμε για τις σειρες αυτες απο το ξεκινημα σχεδον τπυ Home Theater
Δειτε ας πουμε κατι "συμβατικο" για μικροτερους χωρους
S4HC 1 Main In Wall Centre Speaker Video Shielded
S4VC 2 Main In Wall left and Right Speaker
S4B 4 In Wall Multi Pole Ambient Surround Speakers
S4-PCB 7 Pre Construction Brackets one for each in wall speaker
S4-RFB 7 Retro Fit Brackets One for each In Wall Speaker
PS1400BLK/230 2 14" Powered Sub Woofer 400w
SDP-5 1 Digital Surround Processor
SDEC2500/230 1 System Digital Equalizer
S7150/230 1 Seven Channel Amplifier 150w per Channel
S2500IC 1 System Interconnect Pack
Ισως η πλεον ολοκληρωμενη λυση?
Nick Arvanitakis
Audio Pro
Αυτο ειναι αλλο ΑTLAS?
JBL Synthesis - Atlas
For Rooms up to 1300m3
SK2-1000BT3Dual 10" Hercules L/R and Centre SpeakersSIS-EX418" Sub WoofersS4A6Di-Pole Ambient Surround SpeakersSDP-401Digital Surround ProcessorSDEC2500/2301Digital System Equalizer/crossoverS7150/2302Seven x 160w per Channel AmplifiersS800/230210 x Amplifiers 2x200w or 1x800w in bridged Mono S1000IC2System Interconnect Packs
Nick Arvanitakis
Audio Pro
Ελα βρε Ανδρεα και με τρομαξες
JBL Synthesis - Four
Flush Mounted Solution For Rooms up to 210m3
το 4 ΕΒΑΛΕς!!
Nick Arvanitakis
Audio Pro
Επ ευκαιρια...
http://www.jblsynthesis.com/product...EVEREST&Language=ENG&Country=GR&Region=EUROPE
[FONT=Arial, Helvetica, sans-serif]SYNTHESIS® EVEREST THE NAME IS AN UNDERSTATEMENT[/FONT]
[FONT=Arial, Helvetica, sans-serif]THE HIGHEST PEAK IN AUDIO REDEFINED. Of those who seek perfection in sound reproduction, only a handful have actually achieved it. It is a rare occurrence when an individual or group is able to triumph over the constraints of technological reality just once. At JBL, this has happened eight times. In each case, our engineers were told to build the speaker system they had always wanted to build. Whatever resources were required would be available. Thus began an ongoing investigation into new frontiers of sound reproduction, beginning in 1950 and continuing to the present day. The products that have resulted from this venture are now known as the JBL Project loudspeakers. Each represents the absolute peak of every technological, material and engineering innovation available at that time, combined into a single system. They are Hartsfield, Paragon, Project Everest DD55000, K2 S9500/7500, K2 S5500, K2 S9800 and K2 S5800. The newest is Project Everest DD66000. Three Project Everest DD66000 speakers in front of you, eight SK2-1000 surrounds and four 18-inch S1S-EX subwoofers, powered by no fewer than eleven S820 amplifiers, create the most realistic and inspiring system JBL Synthesis has ever designed. Hearing is believing.[/FONT]
FROM 3,500 TO 100,000 CUBIC FEET
99– 2,832 CUBICMETERS8800 WATTS96dB HIGH FREQUENCY96dB LOW FREQUENCY
SYSTEM CONTAINS:11 – S800 2 x 200 Watt, 1 x 800 Watt THX® Power Amplifier 1 – SDP40HD THX® Surround Processor/System Controller with HDMI 1 – SDEC-4000 Synthesis 12 Channel Input and 20 Channel Output Digital Equlizer System 8 – SK2-1000BT (Black Texture) DUAL 10" 3 WAY LCR SPEAKER 4 – S1S-EX 18" (457mm) THX Ultra2 Subwoofer 3 – DD66000EB - EVEREST II 3-Way, Dual 15" Floorstanding Loudspeaker - Ebony Finish
[FONT=Arial, Helvetica, sans-serif]S800 [/FONT][FONT=Arial, Helvetica, sans-serif]2 x 200 Watt, 1 x 800 Watt THX® Power Amplifier[/FONT]
[FONT=Arial, Helvetica, sans-serif]SK2-1000BT (Black Texture) [/FONT]
[FONT=Arial, Helvetica, sans-serif]DUAL 10" 3 WAY LCR SPEAKER [/FONT]
[FONT=Arial, Helvetica, sans-serif]SDP40HD [/FONT]
[FONT=Arial, Helvetica, sans-serif]THX® Surround Processor/System Controller with HDMI[/FONT]
[FONT=Arial, Helvetica, sans-serif]S1S-EX [/FONT]
[FONT=Arial, Helvetica, sans-serif]18" (457mm) THX Ultra2 Subwoofer [/FONT]
[FONT=Arial, Helvetica, sans-serif]SDEC-4000 [/FONT]
[FONT=Arial, Helvetica, sans-serif]Synthesis 12 Channel Input and 20 Channel Output Digital Equlizer System[/FONT]
[FONT=Arial, Helvetica, sans-serif]DD66000EB - EVEREST II [/FONT]
[FONT=Arial, Helvetica, sans-serif]3-Way, Dual 15" Floorstanding Loudspeaker - Ebony Finish [/FONT]
δεν κανει 1 μυριο αλλα σιγουρα ταχει τα λεφτα του!
παντως αυτο τον λεξικον σε μαυρο πολυ τον γουσταρω. δεν μπορω να καταλαβω γιατι η μαμα εταιρεια τον βγαζει μονο σε ασπρο
Nick Arvanitakis
Audio Pro
Καλη ερωτηση!
Λες να δινουν κουτακι μπογια δωρο?:cool_4:
μπα σε μενα δεν εστειλαν. γνωριζει κανεις τι παιζει απο τιμες τουλαχιστον οσο αφορα τον προ για να κανουμε μια μικρη συγκριση?
jimacid
