Playstation 3 firware update
Για δείτε:
PlayStation 3 Firmware v. 2.00 Update Details
Added on 14/05/2007.
The new PlayStation 3 firmware update is upon us and PSU has the latest details of all the updates. Note that the update isn't available yet for download, that these are just the details of what is to come. The new features/changes are as follows:
Users
- You can now password-protect user accounts.
Settings
- [Dynamic Normalizer] has been added as an option under [Sound Settings].
- [Energy Saver] has been added as an option.
- [Equalizer] has been added as a feature under [Music Settings].
- [Full] has been added as an option for [DVD Wide Display] under [BD / DVD Settings].
- [Photo Settings] has been added as an option.
- [PS / PS2 Settings] has been added as an option.
- [RSS Channel Settings] has been added as an option.
- [Sample Rate] has been added to [Audio CD Import] under [Music Settings].
- [Screen Saver] has been expanded under [Display Settings].
- The method of selecting an output resolution has been changed in [Video Output Settings] under [Display Settings].
- [Theme Settings] has been added as an option.
- [Zero Unused Disk Space] has been added as an option under [System Settings] > [Format Utility].
- Additional slideshow effects have been added.
- [Photo Effects] have been added as a feature.
- Wallpaper feature has been added.
- [Zoom] has been added as a feature.
Music
- Additional visualization effects have been added.
- CD information can now be entered.
- Three-speed fast forward and fast reverse has been added as a feature.
Video
- Files can now be played sequentially.
- You can now select [Zoom] under [Screen Mode] when playing video files saved on the hard disk or storage media.*.
*An appropriate USB adapter (not included) is required to use storage media with some models.
Game
- Support for PlayStation 3 format software titles has been expanded.
- XMB™ (XrossMediaBar) is now accessible during gameplay.
Network
- [RSS Channel] has been added as a feature.
Friends
- You can now have multiple chat sessions.
- You can now select an image to use as your Avatar from [Photo].
Other
- Date and Time is now shown when the PS button is pressed.
- File sorting has been changed.
- [Help] has been added as a feature.
- Playability status with the PS3™ system has changed for some PlayStation® and PlayStation®2 format titles.
To check on the latest status, visit the search site for compatible titles.
Σύμφωνα με ότι διαβάζω στο διαδίκτυο, το παραπάνω είναι φήμες κ όχι επίσημη δήλωση της Sony. Κάποιος το ανέβασε στην σελίδα της κ αμέσως το κατέβασαν.
Σίγουρα πάντως κάποια πράγματα είναι πολύ ενδιαφέροντα όπως τα : energy saver, equalizer, screen saver, themes, wallpaper, zoom κ το πιο σημαντικό ότι θα έχουμε πρόσβαση στο μενού του όταν παίζουμε παιχνίδια...
Δεν λέει πάντως κάτι εξωπραγματικό, όπως HD-DVD support( :happy_8:), επομένως, πάνω κάτω, πιστεύω αυτά θα ισχύσουν!!!
δεν λέει και τίποτα ουσιαστικό όμως...
πέρα απο τις άλλαγες στα settings και το θεμα συμβατότητας με τους νέους τιτλους για PS3 (ελεος;;; θέλει Update για να παίζει τους τίτλους που εχουν γραφτεί γι'αυτό το μηχανημα;;;) τα wallpapers, themes κλπ κλπ με αφηνουν αδιάφορο. :cool_3:
Για δείτε:
Settings
Μήπως εδώ κρύβεται το μαγικό 720p;;;; Μπορεί!!!:bravo:
Απάντηση: Playstation 3 firware update
Αντε να δουμε και το upscaling και την υποστηριξη των διαφορων hd format και να μην χρειαζεται να ανοιγεις το pc καθολου.
Ρε παιδια για μενα που δεν εχω ακομα internet access, πως μπορω να αποκτησω αυτα τα updates? και στη συνεχεια να τα εγκαταστησω?
Μπές εδώ http://uk.playstation.com/help-support/ps3/guides/detail/item48612/
κατέβαση την τελευταία έκδοση, και νομίζω, αν την περάσεις σε flashάκι και το βάλεις στο ps3, δεν έχεις κανένα πρόβλημα. Όπως και να έχει, κάπου στη σελίδα είναι οι οδηγίες εγκατάστασης!!
To latest update ειναι το 1.70 η το 2.0 που γραφεται εδω?
Κατεβαζοντας το τελευταιο version παιρνεις πακετο και τα προηγουμενα (π.χ. κατεβαζοντας το 1.70 παιρνεις μαζι και τα 1.60, 1.50 κ.λ.π)?
xfader
Το τελευταίο επίσημο update είναι το 1.70. Το 2.0 είναι ακόμα στο επίπεδο φήμης.
Χρειάζεται να εγκαταστήσεις μόνο το 1.70 και είσαι οκ! Περιλαμβάνει όλες τις βελτιώσεις των προηγουμένων εκδόσεων.
Giorgost
