Nagra CDP CD player
Κώστας Φ.
Mε Philips CD-Pro2M transport, τροφοδοσία σε ξεχωριστό σασί, εξόδους Βalanced XLR, RCA, coaxial S/PDIF, AES/EBU, TosLink, χαρακτηριστική εμφάνιση Nagra και τιμή $13.495.
Aντιγράφω απο το review του Stereophile:
"The actual transport module in the CDP's mono-block tray is a Philips CD-Pro2M, which is used stock, other than Nagra's addition of their own suspension system and locking disc weight. The electronics were all developed in-house by Nagra, starting with PLL resynchronization of the signal and low-jitter, high-precision, voltage-controlled crystal oscillators (VCXOs). The resynced signal is fed to an 8x-oversampling Burr-Brown sigma-delta D/A converter and thence to Burr-Brown output devices.
The ACPS II power supply contains not only the AC transformer, but the regulator and smoothing circuits as well. It outputs 12V DC to the CDP via a ferrite-treated cable. The CDP itself has nine discrete power supplies: the digital circuits use decoupling converters, synchronized to the reference clock of the transport module, while the analog boards use additional low-noise regulators.
The program code is stored on flash EPROM and can be updated at the Nagra factory. The bits'n'bobs are all prime quality: the printed-circuit boards are multilayer, with separate power and ground planes. Capacitors are from Wima; the rotary control is from Elma.
When it comes to construction and performance, the Nagra CDP is one of the best CD players I've ever heard or caressed. If you're even the slightest bit prone to pure gizmoid lust, you'll be a goner the minute you get your hands on one.
Here in the real world, many of us must also consider the question of value. Although I feel that Nagra has met its design brief in building a player capable of extracting every detail lurking in a CD's bits, I'd have a hard time justifying its $13,495 price simply in order to obtain the extra performance over my $5950 Ayre C-5xe—but then, I had to pinch pennies so hard to buy the Ayre that Abe Lincoln actually scowled at me.
Besides, that's putting my wallet in your pocket. If owning something that ranks among the best of its type is important to you and price isn't that big a consideration, you might well consider the Nagra CDP.
But if cost is an object to you, as it is to me, and you're easily swayed by components engineered to fulfill their function with maximum physical and sonic quality, just shut your eyes, stuff your fingers in your ears, and walk on by quickly, muttering, "Get thee behind me." Lust can be the very devil to overcome."
-- Wes Phillips
Εργαστηριακές Μετρήσεις:
"The Nagra CDP's digital-domain measurements, especially regarding its ability to cope with data errors and its rejection of jitter, are among the best I have encountered. Considered purely as a CD transport, it doesn't get any better than this. In the analog domain, the CDP works best with higher impedances, when it is almost beyond reproach, though the de-emphasis did raise my eyebrows a tad. I do wonder, however, if its signatures of harmonic and intermodulation distortion correlate with the somewhat forward soundstage presentation WP noted in his auditioning." -- John Atkinson
Full Review
Gebreselassie
Μαύρος!
Κορυφή η Nagra, θα προτιμήσω όμως το γραφτήρι της με τον σκληρό...
Απάντηση: Nagra CDP CD player
δεινο εργαλειο
Κώστας Φ.
Nagra CDP CD Player
Price: $13,495 USD.
Review Summary
Sound
"The Nagra CDP is a thoroughly modern digital source. At no point does it make concessions to analog by sweetening or warming up the matter-of-fact nature of digital playback, and at the same time it improves on a few of digital's traditional strengths. Above all, the CDP illuminates everything on a recording -- instrumental lines and voices, the space in which they exist, any tape hiss present, everything."
Features
"The CDP is actually a two-box CD player. Its separate ACPS-II power supply provides 12V DC to nine discrete power supplies. The ACPS-II houses the transformer and regulator along with 'smoothing circuits,' and it connects via a removable umbilical." The CDP is "balanced from the transport to the DAC -- a Burr-Brown 24-bit/192kHz number -- then single ended to the discrete gain sections. The CDP eschews upsampling in favor of conventional 8x oversampling."
Use
"The CDP has both single-ended and balanced outputs, though the latter are included for the sake of compatibility, not as the terminating point of a fully balanced circuit…. With the CDP I found that I preferred the single-ended outputs to the balanced (at matched levels, of course), which didn't sound quite as transparent."
Value
"The Nagra CDP sure isn't cheap, but nothing made so fine is. It has the heirloom quality of a Swiss watch and the appeal of a dish of Swiss chocolate."
Full Review: Soundstage!
Spiromag
