Oppo DV-970HD universal player
Κώστας Φ.
Δοκιμή των audio δυνατοτήτων του DV-970HD απο το Stereophile.
"There's an old Spanish proverb: "If six people call you an ass, start braying." A contemporary corollary might be that if enough audiophiles insist a product is the best ever, it behooves the "experts" to check it out. At least, that was John Atkinson's thinking when he suggested I audition the Oppo Digital DV-970HD universal disc player ($149).
"The DV-970 has created quite a buzz on the Internet as a budget competitor for expensive high-end music players, even though it's obviously aimed at the A/V market. I'm interested in discovering what an experienced listener thinks of it." That's JA all over—he was buttering me up, hoping I wouldn't notice the danger of reviewing a true budget product: At $149, there's probably not one Stereophile reader who couldn't afford to snap up an Oppo just to see if it was really as good or as bad as I say it is. And that's when the game of Pin the Tail on the Reviewer would begin. JA will have a fat "Letters" section for months, as advocates and naysayers manage to agree on one thing: that I was horrendously wrong. I knew that JA knew that I knew. I took the assignment anyway. It's my job.
So how good can a $149 player be? The Oppo DV-970HD is very good. Using its internal D/A converters, the Oppo produces listenable, detailed, extremely satisfying sound from pretty much every optical-disc format currently available. However, as a standalone universal player, it won't cause Krell's Dan D'Agostino or Ayre's Charlie Hansen any sleepless nights.
On the other hand, the DV-970HD is aimed at A/V enthusiasts, who generally use their players' digital outputs and perform the D/A conversion offboard. If you have a hi-rez DAC that can utilize 96kHz signals, you can benefit from that increased bandwidth, as I did. If you have HDMI-compatible gear, you can benefit from 24-bit word length as well, although I did not audition the DV-970HD that way, since none of my A/V gear supports that standard (I'm hi-fi proud, but HT poor).
I was impressed by the Oppo DV-970HD. It looks good, it feels solid and reassuringly well-built, and I was impressed by the company's service ethic. I see why it has become a favorite among consumers. Its performance as a standalone player wasn't where I felt its true potential lies, but when connected to a good DAC it punched way outside its class.
Here's the part that may truly mark me as an ass: After I'd done everything I've written about here, I finally installed the DV-970HD in my home theater, where I discovered that it's also an extremely impressive DVD player. If you like that sort of thing." -- Wes Phillips
Full Review
Κώστας Φ.
Απάντηση: Re: Oppo DV-970HD universal player
Οι μετρήσεις του πάντως ήταν κωμικοτραγικές.
Nαι, οι μετρήσεις ήταν κάπως - αλλά δεν ξέρω πως συγκρίνονται με άλλα dvd player της ίδιας κατηγορίας τιμής.
Το γιατί κόβει τις "λέξεις" στα 16bit δεν το κατάλαβα, για να πω την αλήθεια...Kαι μπόλικο jitter.
Δεν υπάρχουν αντίστοιχες μετρήσεις. Τα περιοδικά αυτά αποφεύγουν τις φτηνές συσκευές. Ο μόνος λόγος που έγινε αυτό το τεστ ήταν για να γίνει κόντρα με τον TAS.
Κώστας Φ.
Α, αυτό δεν το ήξερα για το TAS. Ξέρω ότι υπάρχει κόντρα αλλά δεν πήγε το μυαλό μου.
Πάντως κάτι μου λέει ότι τα ίδια και χειρότερα θα μετράνε και οι υπόλοιπες συσκευές σε αυτή την κατηγορία τιμής. Σίγουρα η αξία του Oppo είναι δεδομένη ως DVD player με άριστο value for money (και στο ηχητικό κομμάτι) αλλά Hi-End Audio player δε μπορεί να χαρακτηριστεί. Δεν το λάνσαρε ως τέτοιο η Oppo φυσικά αλλά πολλοί "users" το περιγράφουν ως τέτοιο. Καλό είναι να ξέρουμε τι ακούμε και γιατί το ακούμε - ακόμα και όταν αυτό που ακούμε μας αρέσει/δένει με το υπόλοιπο σύστημά μας.
Aν και τώρα τελευταία έμαθα ότι οι χάλια μετρήσεις είναι μέρος του Hi-End απλά λέγονται "άποψη του κατασκευαστή". :respect:
Re: Απάντηση: Re: Oppo DV-970HD universal player
"It's not a bug, it's a feature" :crazy_1:
Το τεστ αυτό ασχολείται αποκλειστικά με τις δυνατότητες βίντεο.
Κώστας Φ.
Απάντηση: Oppo DV-970HD universal player
Χμμ, ορίστε και μερικές μετρήσεις απο ένα DVD player της Rotel, το RDV-03, που είναι περίπου στα 300 ευρώ - courtesy of TNT Audio.
Review
Μετρήσεις
Evasound
