"Σαπιζουν" τα Blu ray δισκακια?
Πάντως... οφείλω να σου ομολογήσω ότι πλέον θα το σκεφτώ διπλά για την αγορά br player….
Πρέπει να μαζέψω χρήματα και για καινούριο καταψύκτη!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Κάτσε στα HD-DVD που την βγάζεις φτηνά με μια κατσαρόλα και λίγο βράσιμο ...
Εχει παίδεμα βέβαια γιατί είναι πολλά, αλλά αν έχεις λίγο ιδέα από μαγειρική θα είσαι εντάξει.
(μόνο προσοχή μετά μην ακουμπήσουν άσχημα πουθενά)
Eκανα ένα search με τη λέξη boiling στο avsforum και γέμισε ο τόπος !!! βάζω εδώ λίγα από την αρχή γιατί έχει ενδιαφέρον ...
- they would not play and boiling helped some people and not others.
-I too have had problems with the Ultimate Matrix Collection playback on my 360 HD drive…yes, I did try boiling the disk (boy, do I feel stupid, like a freshman who bought tickets to the school swimming pool) and I tried the eject, load, eject, load, etc., etc., trick ad nauseum
-I tried boiling my problem UNIVERSAL discs and it did not work either. My wife is still telling people about it!
-Extra hot water (not boiling) and a little soap has worked great for me. It has solved both problems I have encountered with freezing- one with the Matrix, and the other with Superman Returns.
-Yes I am referring to brand new discs still needing to be cleaned. They seem to have some type of film residue others have reported seeing after boiling there discs..
-I still have some slight problems with some discs stuttering but since I started using the plexus spray (its a plastics cleaner) it probably wiped out 85% of the issues I was previously having with the discs. I think this is why the boiling may have actually helped some…
-I've tried about 5 times and it still doesn't load for me. Has anyone that has gotten it to work with their 360 add-on have any solutions? Does boiling work? Please help, thanks!
-After my boiling adventures with CoM, I always wait for the non-combo release now.
-Disc 1 "can not play disc"...so I ran it under very hot water for 2 minutes...now it just gets stuck indefinitely on "Reading disc"…Disc 3: gets stuck indefinitely on "Reading disc" …I'll try boiling tonight
-Had problems with the 2nd disc, low and behold the boiling trick worked plays fine now
-4 bad discs in 2 months is enough for me…. And boiling didn't work on reloaded, this trick worked on COM Good Sheppard and Smokin aces
-I'm not daring enough to try the boiling trick. I have contacted WB about the issue
-What's the deal with the boiling trick? I had the same error with 2 copies of Fearless and wasn't aware of this trick when I had them
-To try and get my disc to work based on all the boiling stories I tried a variety of cleaning methods.
First hot water and pat dry, no go.
Then plain Windex (nope doesn't damage dvd's done a million times), rinse and pat dry, still nothing.
Eventually I took to using a liberal amount of liquid dish soap and hot water and gently rubbing it on the surface (was careful not to scratch the surface), patted it dry (yay no scratches).Then it worked
Some others say that you may have to unplug and replug in the hd-dvd addon when it doesn't read.
-I just got my 2nd one from Netflix. The first one wouldn't even boot up, and the 2nd one gets the 4xxx error. I'm going to try the boiling water trick to see…
-The Good Shepherd=nothing but trouble, even after boiling! Smokin' Aces=hit or miss playability, also boiled! Maybe the little bitty scratches from the metal coat hanger lifting them out of boiling water didn't help
-Typically, the boiling trick is meant for combo flippers imho. You know, the latest Universal discs that Universal needs to cancel from now on.
-boiling was the only thing that worked for me even after 2 thorough cleanings and a firmware upgrade for my 360 add-on
-I tried the boiling fix and surprisingly enough my disc is now working and I haven't found any bad spots in the movie. I soaked the disc in a bowl of boiling water for 15 seconds and then cleaned it lightly in hot soapy water
http://www.avsforum.com/avs-vb/showthread.php?t=842373
Μπαχαχαχαχαχαχα!! Βράζουν τα hddvd??? Χριστέ μου! Δεχόμαστε επίθεση απο εξωγήινα high definition formats!
"Εγώ μια ταινία ήθελα να δω"
"Στους πόσους την έβρασες; Θέλει 112,67 βαθμους το hddvd και -7,89 το BR στην καταψυξη"
αχαχαχαχαχαχα
αχαχαχαχαχαχα
εμενα με το hd-dvd player μου εδωσαν και μια χυτρα δωρο!!!!!!!!!
ολα καλα λοιπον!!!!!!!!!!!!!!!!!!!!!!!!!!
Στο αμερικανικο AVS εχει ξεκινησει μια συζητηση σχετικα με προβληματα τα οποια εχουν καποιοι στα Blu ray δισκακια τους.
Το προβλημα εμφανιζεται με την μορφη κηλιδων και το ονομαζουν "σαπισμα" η "μουχλιασμα" των δισκων.
Οσο οι κηλιδες αυξανονται τοσο μειωνονται οι πιθανοτητες αναπαραγωγης.
Eσας σας εχει τυχει κατι παρομοιο?
nomizw oti isos exei pesi aroma panw h kati paremferi pou na periexei oinopneuma to exw pathi kai gw .eixa ena xexasmeno bd sto trapezaki mou kai opos evala aroma epesan stagonitses kai sto diskaki kai eixe gini akrivos etsi.kapou eixa diavasi oti ta blueray disc antexoun mexri kai 200 xrwnia den xerw kata poso alitheui auto alla den nomizw na sapizoun re paidia.euxaristo kai sorry an eipa m@l@kia
Απάντηση: "Σαπιζουν" τα Blu ray δισκακια?
ΠΡΟΣΕΧΩΣ ΠΛΥΝΤΗΡΙΟ - ΣΤΕΓΝΩΤΗΡΙΟ !!!
JL_
Μπήκα στην διαδικασία να κοιτάξω τα δισκάκια που έχω (Fantastic Four, Casino Royale, A Knight's Tale, Open Season) και ήταν όλα άψοξα. Καθρέφτες. Εκτός απο το Casino Royale Που έκανε κάτι "νερά" επάνω το δισκάκι. Δεν το εχω ξαναδεί. Πολύ πιθανον να μην ειναι και τίποτα. Για δείτε...
Τα "νερά" αυτά υπάρχουν σε όλα τα διασκάκια διπλής στρώσης και είναι στην ουσία ένα φαινόμενο εν είδει moire, που προκαλείται από την παραλλαγή της προβολής των δύο αυλακίων.
2xwria
