AMR CD77
Θεωρείται παγκόσμιος απο τα πιο υποσχόμενα καινούργια players (NOS Tubes):
CD-77 Reference Class Compact Disk Processor AMR's design brief was simple in essence but complex in execution: "to match and exceed the performance of the new Super Audio CD®." To achieve this lofty objective, the CD-77 is able to lay claim to a unique approach in design and manufacture.
To begin, the proprietary top-loading transport mechanism is a painstaking amalgamation of genuine Sony and Philips components best suited to the application.
At the heart, the Digital to Analogue Converter is the "King of the Multibit" – the Philips TDA1541A chipset, which is accompanied with a leading-edge circuit incorporating the latest CPLD (Complex Programmable Logic Device) and DSP (Digital Signal Processing) devices. Combined with a revolutionary analogue stage using pure New Old Stock valves, the musical performance of the CD-77 must be heard to be believed.
The CD-77 is unrelenting in its maximisation of the sonic performance and pushes the performance of CD to a new level that seriously questions the ability of Super Audio CD®... It is one of the select few that bridges the performance gap between compact disk and vinyl or analogue master tapes.
Compact Disk Processor Specifications
Operation modes: • Direct Master I; no digital or analogue filter • Direct Master II; no digital filter, anti-sin(x)/(x) analogue filter • Oversampling 2X • Oversampling 4X • Upsampling 96KHz • Upsampling 192KHz Compact Disk Drive: Custom, Toploading Digital Audio Inputs: 1 x USB interface Analog Outputs: 1 X RCA; 1 X XLR per Channel Output voltage ( Digital Full Scale) : >2V Output Impedance: < 200 Ohm Frequency Response: 20Hz to 20 kHz +0.0, -0.5dB Signal-to-noise ratio 'A' Weighted: > 100 dB Total Harmonic Dist. + Noise ( THD +N ): <0.3% Dynamic range: >90 dB Channel separation: >100 dB Power consumption: Standby: 45 W Power on: 90W Rated voltage: 90V-135V & 190V-260V AC Colour: Champagne or Titanium Dimensions: 17.9in W by 6.2in H by 18.3in D 46cm W by 16cm H by 47cm D Weight: CD Processor: 77 lbs/35 kg Shipped: 101.5 lbs/ 46 kg
http://www.amr-audio.co.uk/
Gebreselassie
Μαύρος!
Νομίζω ότι γενικώς μιλάμε για μια αρκετά ενδιαφέρουσα εταιρία.
http://www.amr-audio.co.uk/Templates/tech.html
- Σε ότι αφορά στο player, σημαντικό στοιχείο ο τρόπος που ισχυρίζονται ότι βρήκαν, έτσι ώστε οι διαφορές θερμοκρασίας να μην επηρεάζουν το ρολόι της συσκευής, κάτι παρόμοιο με αυτό που λένε ότι έχουν τα studio της JVC που ασχολούνται με τα XRCD. Άντε μπας και αρχίσουμε να κλείνουμε κάποτε τα cdplayers μας γιατί έχουν λιώσει... :happy_9:
Ειναι προς τιμη τους νομιζω που βαζουν τοση τεχνικη πληροφορα στο site τους!
Νομιζω οτι η τιμη τους ειναι γυρω στα 8000 δολαρια, χτυπωντας ομως player πολλαπλασιας τιμης...Ετσι λεγεται τουλαχιστον.Παρουσιαστηκε τωρα στη hi-end στο Μοναχο.
Εχω την εντυπωση οτι οσα κατασκευασαν εχουν πουληθει και υπαρχει λιστα αναμονης!
Gebreselassie
Μαύρος!
Καλά μην τρελαίνεσαι δεν λένε και τίποτα τρελές λεπτομέρειες, γενικότητες γράφουν, χρήσιμες βεβαίως.
Μου τη σπάει ελαφρώς ότι θεωρούν εαυτούς κύρους γρανάζηδες και βαφτίζουν τεχνολογίες, αλλά από την άλλη, σε σχέση με μερικά μεγαλο-ονόματα που απλά συναρμολογούν, αυτοί φαίνεται ότι την ψάχνουν αρκετά, οπότε δικαιολογούνται...
Κώστας Φ.
Απάντηση: AMR CD77
Kαι ένα review απο το 6moons.com εδώ (μαζί με τον dual mono ενισχυτή τους).
Καλα εδω βαζουν σε καλωδια τετοια συσκευασια δεν θα βαλουν σε cd player....
καλώδια σε flight case με τεστ και audiophile σιντι και μυστήρια αντικραδασμικά? ουάου.
Παντως οσο το βλεπω μου αρεσει ολο και πιο πολυ......Δυστυχως δεν βλεπω να ερχεται κανα κομματι στην Eλλαδα συντομα για να το ακουγαμε.Φυσικα δεν υπαρχει αντιπροσωπος.
Lino
