Focal Electra 1037 Be loudspeaker
Κώστας Φ.
O Michael Fremer γράφει πολύ καλά λόγια στο review και ο Atkinson, απο το εργαστήρι του Stereophile, είπε "WoW!".
Προσωπικά δεν ξέρω πως παίζουν, αλλά τα άτιμα είναι κουκλιά...
"Focal's new Electra 1037 Be ($10,995) is essentially a larger, more powerful 1027 Be, with the latter speaker's basic architecture and components. Both are three-way, bottom-ported designs, and both feature Focal's exclusive 1" inverted beryllium-dome tweeter with Infinite Acoustic Loading (IAL) enclosure and 6½" W midrange cone. In place of the 1027's two 6½" W cones, the 1037 features three 7" W drivers, which should result in improved bass extension, dynamic capabilities, and sensitivity.
The Electra 1037 Be's stack of three woofers necessitated a 6" height increase over the 1027, to 49", though the 1037 is only 1" wider and 2" deeper. Still, it weighs almost 40 lbs more: 112 lbs each. The result is a tall, graceful, imposing, wedge-shaped structure with stained redwood side cheeks, glossy, black curved baffle, recessed drivers, and flush-mounted grilles. It's probably the most attractive-looking speaker Focal has produced.
Conclusion
That a company can design and build outstanding drive-units does not guarantee that that company can make great loudspeakers. Over the years, though admittedly under less-than-ideal show conditions, I've never walked away from a Focal-JMlab demo with a great deal of enthusiasm. In the early years, I thought the company's bigger speakers sounded too bright and falsely "airy." Even the latest version of the Grand Utopia Be, which I heard in the company's own huge, well-treated listening room, while exquisite on top and in the mids and able to deliver the full weight and dynamic capabilities of the finest symphonic recordings, sounded overstuffed on the bottom and too full in the midbass, though I understand why others might like such a sound.
The Electra 1037 Bes were a different story: a pair of attractively modern-looking, beautifully built, moderately priced (by today's high-end standards) loudspeakers that seemed to deliver a seamless, coherent, faultless presentation in terms of tonality, harmonics, and rhythm, with limitations only at the extremes of frequency, dynamics, and soundstaging. I never found them too bright or too dull, or too lean, or too anything. The few "not quite enoughs" were omissions so far out of range that I could easily ignore them.
The Electra 1037 Bes remained in my system for almost three months, yet try as I might, I couldn't find a seam in the speaker's frequency balance. I'm certain that, at least in my room, it produced the smoothest, most coherent frequency response of any speaker I've reviewed, and especially of any model that extends down into the 30Hz region. The result was among the most convincing and believable expression of instrumental harmonics I've heard.
The Electra 1037s had limitations at the extremes of frequency and dynamics, and their soundstaging was less than expansive. If I had to assign any negative attribute to the Focal's overall presentation, it would be that it was on the somewhat dry and reserved side. But if you crave real detail, accurate instrumental timbres, rhythmic certitude, utter transparency, overall coherence, musical believability, and—especially—a speaker that, while it might not bowl you over on first hearing, over the long run will keep bringing you back to the listening room, and keep you happy and enthralled through every listening session, I can't imagine a better $11,000 candidate than the Focal Electra 1037 Be. When the design expertise that went into this loudspeaker is applied to a refreshing of the top of Focal's line, watch out."
-- Michael Fremer
The Focal Electra 1037 Be offers superb measured performance, but I keep returning to that in-room response (fig.6), one of the best I have encountered. Wow! -- John Atkinson
Full Review
Κώστας Φ.
Απάντηση: Re: Focal Electra 1037 Be loudspeaker
Να σου πω ....παλι το TWEETER θα κανει "υπερωριες" :happy_4:
Χμμ, μάλλον το συγκεκριμένο αποτελεί εξαίρεση, Μαρίνο!
Διάβασε το conclusion να δεις τι λέει ο reviewer για προηγούμενα μοντέλα και πόσο διαφέρει το 1037 απο αυτά, δες και το In-room response που έβγαλε ο Atkinson και θα καταλάβεις! :cool_4:
Ημίθεος
Ωραία κατασκευή και εξαιρετικά μεγάφωνα, αλλά από πού κι ως πού 8ωμο;
Κώστας Φ.
Απάντηση: Focal Electra 1037 Be loudspeaker
Ε, ξέρεις πως είναι αυτά τώρα... :mrgreen:
"The Focal Electra 1037 Be was significantly more sensitive than normal at an estimated 90dB(B)/2.83V/m. However, its plot of impedance magnitude and electrical phase (fig.1) indicates that it is a demanding load for the partnering amplifier in the lower midrange and bass. Not only is there a minimum value of 3 ohms at 33Hz, but there is a combination of 4.25 ohms and –47.5° capacitive phase angle at 27.3Hz. Fortunately, music with significant energy below 40Hz is relatively rare, but an amplifier that has no trouble driving 4 ohm loads at high levels will still be required. The fact that the impedance remains above 10 ohms for much of the treble means that the 1037 Be will tend to sound shelved-up in the highs with tube amplification."
LUXMAN
Re: Απάντηση: Re: Focal Electra 1037 Be loudspeaker
Χμμμ.....για να ειμαι ειλικρινης δεν διαβασα το κειμενο . Αν οντως συμβαινει κατι τετοιο τοτε θα απολυθηκε ο κρετινος σχεδιαστης ηχειων που ειχαν επι χρονια . Καιρος ηταν .....
Κώστας Φ.
Αν θελεις πες το να παμε καπου να τ ακουσεις, πραγματικα ειναι πολυ ομορφα .
Χμμ, δε μας τα είπες αυτά!
Φεύγω αύριο να πάω να καταστρέψω το εξοχικό ενός φίλου στο Πόρτο Χέλι. Θα είμαι πίσω σε μία εβδομάδα, οπότε και κανονίζουμε ακρόαση. :cool_4: :happy_2:
Μεσα :cool_4: και γω φευγω για 5-6 μερουλες οποτε μετα απο αυτο κανονιζουμε . :cool_2:
Κώστας Φ.
Γιώργο, άμα κατέβεις Κρήτη για ακροάσεις θα τρέχουμε?! Έχουμε άλλα αξιοθέατα εδώ - και δεν εννοώ τον Λαζάρου! :mrgreen:
Re: Απάντηση: Focal Electra 1037 Be loudspeaker
υπεροχα
οδηγουνται και απο φορητο μπ3...
47 μοιρες απαπαπαπα...
Κώστας Φ.
Απάντηση: Re: Απάντηση: Focal Electra 1037 Be loudspeaker
Ας μου τα φέρει εμένα ο Άη Βασίλης και αναλαμβάνω εγώ να βρω ενισχυτή να τα οδηγήσει! :crazy_3:
Μεταξύ μας, έχουμε δει και πολύ χειρότερα... Εντάξει, δεν είναι το εύκολο φορτίο που φαίνεται στα specs του κατασκευαστή αλλά το πράγμα δεν είναι τίποτα καλύτερο και τίποτα χειρότερο απο αυτό που λέει ο Atkinson:
"...it is a demanding load for the partnering amplifier in the lower midrange and bass. Not only is there a minimum value of 3 ohms at 33Hz, but there is a combination of 4.25 ohms and –47.5° capacitive phase angle at 27.3Hz. Fortunately, music with significant energy below 40Hz is relatively rare, but an amplifier that has no trouble driving 4 ohm loads at high levels will still be required."
Πάντως εδώ (στο Ηράκλειο) υπάρχει το ηχείο και μετά απο 200 ώρες στρώσιμο μπορώ να πώ οτι είναι αποκάλυψη - αλλά και το "μικρό" 1027 ήταν πολύ καλό (τόσο που το πήρα σπίτι) οπότε δε με σόκαρε. Φυσική εξέλιξη...
Η πρόσκληση προς ακρόαση είναι ανοιχτή!
Κώστας Φ.
Μάνο, να μας περιμένεις μόλις επιστρέψουμε απο τις ολιγοήμερες διακοπές μας!
Ευχαριστούμε για την πρόσκληση! :cool_4:
Oxι τρεξίματα και κουραστικά πράγματα.
Χ Α Λ Α Ρ Α... και ωραία.:happy_2:
Κώστας Φ.
Γιάννη, we are back έτσι?!
Μάνο, στρώσανε τα Focal?!
Κώστας Φ.
H ακρόαση έγινε!
Ακούσαμε τα Focal και όχι μόνο...
Περισσότερες λεπτομέρειες και φωτογραφικό υλικό στο thread που θα ανοίξω αύριο.
Μάνο ευχαριστούμε!
Κώστας Φ.
H ακρόαση έγινε!
Μάνο ευχαριστούμε!
Click for more. :cool_4:
x x x BLOODBATH x x x
