DIY Paradise - Monica, Maggie, Charlize
Κώστας Φ.
Γενικώς γράφονται καλά λόγια στο internet για τα συγκεκριμένα kit.
Υπάρχει φυσικά η δυνατότητα παραγγελίας έτοιμων των συσκευών και αυτό ακριβώς έκαναν στο 6moons για το συγκεκριμένο review. Ο Charlize δεν διαφέρει και πολύ απο τις υπόλοιπες λύσεις που χρησιμοποιούν Tripath modules (θα έλεγε μάλιστα πως με Trends και Kingrex η θέση του είναι δύσκολη), αλλά ο προ (Maggie) και το DAC (Monica) παρουσιάζουν ιδιαίτερο ενδιαφέρον, δεδομένης και της χαμηλής τιμής τους σε μορφή Kit.
Οι υπό δοκιμή συσκευές:
Maggie Autoformer Volume Control ($430)
Charlize Amplifier class-T ($340)
Monica DAC ($300)
Αντιγράφω απο τα...6 φεγγάρια:
"The digital to analog converter under review is called the Monica and was designed by Yeo himself, to currently be in its second iteration. It's a non-oversampling DAC using a TDA1545A chip.
CK Kok designed the 10wpc class-T amp that goes by Charlize. It utilizes a Tripath TA 2020 chip...
Requiring no power connections at all is the Ew CG-designed Maggie, a passive autoformer attenuator with C-Core transformers wound in house. I'm told these C-Core transformers were selected after testing various types. C-cores were found to be superior due to flatter frequency response, tighter bass, greater high frequency extension and reduced magnetic leakage leading to lower inductance. A 22-stop stepped Alps attenuator has a very sturdy feel and features front center. Not your usual wiper-type resistive potentiometer, volume is controlled by connecting each click stop directly to one of the C-Core's various autoformer taps. Around back are connections for a single stereo input and output utilizing the same RCAs found elsewhere.
Of course, for the true do-it-yourselfer, DIY Paradise will sell you the Monica PCB module for $135 plus approximately $30 shipping, the Maggie autoformers for $260 and the Charlize amplifier module for $110.
Conclusion
I'm aware that these DIY components have competition out there. Where class-T amplifiers are concerned, I've already mentioned Trends and Kingrex, already reviewed on 6moons as well as Sonic Impact, Red Wine and others. How the DIY Paradise Charlize compares I can't say as I haven't used any of the competition. I'm also aware that some of the competition is asking for even less coin than DIY Paradise. I will add that DIY Paradise products can be ordered in at least two different styles of wooden boxes and you can assemble a complete system (with the exception of a CD transport) with matching cosmetics. That'll be worth something to certain buyers. No matter how you look at it, these components represent real value. When I accepted the DIY Paradise review assignment, I didn't have a clue how good these class-T amplifiers could sound.
I can confidently state that within the parameters of the caveats pointed out -- which in the right system could actually be benefits -- the Charlize, Monica and Maggie each present the potential buyer (or DIY builder) with very solid performance and a value quotient that's off the charts. With each subsequent listen during the review period, I found myself more and more impressed. No, in absolute terms they weren't giant killers - they weren't better than or even quite as good as my reference components. They are, however, products of extreme value. Where they fell short of my gear, they did so in esoteric areas of performance. As a system, the DIY components weren't quite as liquid, not quite as detailed and insightful and they did shrink the scale of the presentation to a minor degree. But at their price, they came much closer than they had any right to. I can't imagine this amount of money buying a better performing DAC, passive attenuator and power amplifier package. But until I have more experience with class-T amplification, I'll have to reserve judgment as to just how award-worthy the Charlize amplifier actually is. However, there's no doubt that in the extreme low-price category, the Monica DAC is a clear Blue Moon contender.
Full Review
DAC
AMP
PRE
και δε τα βαζανε ολα σε ενα κουτι
να μη μενει και αδειο...
Ιδου η κακη εννοια του Audio DIY.
Διαστροφη και Κιτς και εγκεφαλικο φραππε και διακορευση των Ηλεκτρονικων και επιστροφη του Ροκοκο, με ισχυρη δοση φιγουραλληγοριας και μπινεδισμου.
Μου θυμιζει κατι Αθηναιικα σαλονακια 2.80 χ 3.20 σε πολυκατοικια εποχης της μεγαλης εσωτερικης μεταναστευσης, με τον καναπε-κρεββατι απο μελαμινη, στολισμενα σαν λατερνες, υπερφορτωμενα με ψευτικα διακοσμητικα, καδρακια, σουβενιρ απο την Αιδηψο, πιατακια, γυαλικα, ξυλινα πανηγυρτζιδικα αγαλματακια και παντος ειδους ετεροκλητο μπιχλιμπιδι, με τους κρυφους φωτισμοι και τους "φτωχους αλλα τιμιους" και δακρυβρεχτους "λαικους" καλιτεχνε.
Ιδου η τεχνη της παραλλαγης ή πως θα αποφυγεις την πραγματικη σχεδιαστικη και εξελικτικη δουλεια (που δεν εισαι σε θεση να κανεις) αντικαθιστωντας την με λυσεις απο τα ετοιματζιδικα και ντυνωντας την τεχνολογικη σου γυμνια με εντυπωσιακα ρουχαλακια, πετωντας την μπαλλα στην κερκιδα (στον ξυλουργο και τον λουστραδορο). Κατι τετοια στον κυκλο μου τα ονομαζουμε Περιστεριωνες και τα υποδεχομαστε με εκδηλωσεις που εμπιπτουν στον νομο 4000 "περι Τεντυμποισμου"
Σχεδιασε λεει .... Τι σχεδιασε ?? Τις κουτες ??
Αφου ολα τα αλλα ειναι ετοιμα.
Αληθεια, με τι ρευμα δουλευουν τα Ηργαλια ?
Ο "τελικος" τροφοδοτειται απο εκεινο το βυσματακι για πακ απο φορτιστη για σκουπακι ?
Ομως ολα τα ειχε η Μαριωρη, ο χειροποιητος μετ/στης με το step attenuator της ελλειπε, με την μακαροναδα απο καλωδια, και το κουτι εντος κουτιου για τον Double-C core. Και ποσα ζηταει για αυτο ??
Πιο πολλα και απο τον ενισχυτη.
Και να τι γραφει εκεινος ο ΓΕΛΟΙΟΣ οτι ακουει στο
Μaggie Autoformer Volume Control ($430) .... a passive autoformer attenuator with C-Core transformers wound in house. I'm told these C-Core transformers were selected after testing various types. C-cores were found to be superior due to flatter frequency response, tighter bass, greater high frequency extension and reduced magnetic leakage leading to lower inductance.
Compared to what ΡΕ ??
Μηπως Compared to any good quality potmeter ??
Παραπερα ..
I can confidently state that within the parameters of the caveats pointed out -- which in the right system could actually be benefits -- the Charlize, Monica and Maggie each present the potential buyer (or DIY builder) with very solid performance and a value quotient that's off the charts. With each subsequent listen during the review period, I found myself more and more impressed ... Καθως πεφτανε τα ψιλα.
Ομως ... No, in absolute terms they weren't giant killers - they weren't better than or even quite as good as my reference components. They are, however, products of extreme value.
Αυτα τα λεει μηπως γλυτωσει τα γιαουρτια μεν, αλλα απ' την αλλη να πεσει και το χαρτζιλικι.
Where they fell short of my gear, they did so in esoteric areas of performance. Ψυχολογια - Καρτεσιος As a system, the DIY components weren't quite as liquid, not quite as detailed and insightful ... Ενδοσκοπικα ?? ... and they did shrink the scale of the presentation to a minor degree. But at their price, they came much closer than they had any right to. I can't imagine this amount of money buying a better performing DAC, passive attenuator and power amplifier package. But until I have more experience with class-T amplification, I'll have to reserve judgment as to just how award-worthy the Charlize amplifier actually is. However, there's no doubt that in the extreme low price category ... $430 για ρυθμιση Εντασης ... Monica DAC - ξαδερφη της Νταιζυ Ντακ - is a clear Blue Moon contender.
Αι σιχτιρ πεζεβεγκηδες ...
Κώστας Φ.
Απάντηση: DIY Paradise - Monica, Maggie, Charlize
Χαχαχα!
Οι περιγραφές σου είναι όλα τα λεφτά, Μιχάλη... :respect:
Λέτε να φτιάξουμε κανένα sub-forum "Reviewing the Reviewers"?
Με Σπέρτο, Κόγια, Μπλάτσιο στο team δε θα μείνει τίποτα όρθιο! :cool_1:
Re: Απάντηση: DIY Paradise - Monica, Maggie, Charlize
Χαχαχα!
Βρε συ, με το λαπτοπ κατεβαινεις για μπανιο ?
Ετσι οπως πας σε λιγο θα ψαχνεσαι για κανενα φορητο Δορυφορικο του Inmarsat για τις δυσκολες παραλιες.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: DIY Paradise - Monica, Maggie, Charlize
Σαφώς και θα μπορούσαν να μπούν όλα στο ίδιο κουτί αλλά τότε το συνολικό κέρδος θα έπεφτε κατακόρυφα. Πόσο να το πουλήσει το ένα κουτάκι ο άνθρωπος...
Λοιπον το πραγμα δεν ειναι αστειο.
Οταν φτιαχνεις ενα μηχανημα κυττας εκτος του οτι πρεπει να ειναι τεχνικα αρτιο, να ειναι και σουλουπωμενο σε καποιο βαθμο με βαση το γουστο σου, ή αυτο που θεωρεις σαν ευρυτερα αποδεκτο αισθητικα.
Το να δινεις προτεραιοτητα στην μορφη του πραγματος σημαινει οτι δεν εχεις τιποτε σπουδαιο να παρουσιασεις απο πλευρας περιεχομενου, ή θεωρεις οτι θα ψαρωσεις κοσμο με το μπιχλιμπιδι και θα κριθεις με προεξεχουσα την φορμαλιστικη αντιληψη.
Εαν επιδιωκεις να μεταθεσεις το βαρος ενος τεχνολογικου κατασκευασματος απο την λειτουργικοτητα και αξιοπιστια προς την κατευθυνση της εμφανισης, σαφως επιδιωκεις εν γνωσει σου να εξαπατησεις τον απειρο καταναλωτη. Γνωστη ιστορια αλλα να που επαναλαμβανεται, γιατι ο κοσμος βριθει απο ατομα που μη διαθετοντας τεχνικα κριτηρια εντυπωσιαζονται απο το περιβλημα.
Να μην θεωρηθω μισογυνης αλλα αυτη ειναι κατα κανονα και η γυναικεια προσεγγιση
- Αχ δεν ειναι γλυκα ?
- Μα κυρια μου το αλλο εχει δισκοφρενα σε ολους τους τροχους.
- Εμενα αυτο μου αρεσει. Το εχετε σε εκρου ?
Εξ ου και τα γυναικεια ονοματα των μοντελων.
Κώστας Φ.
Ώπ, πότε τα γράψατε όλα αυτά και γιατί μου εμφανίζει τα μηνύματά σας ως αναγνωσμένα?! Πρέπει να σταματήσω να διαβάζω το forum όταν γυρνάω απο νυχτερινή διασκέδαση γιατί την επόμενη μέρα δε θυμάμαι τίποτα... :crazy_1:
Πάντως οι τιμές σε μορφή Kit είναι αρκετά προσιτές (και έτσι πουλάνε κυρίως) και το βάζεις σε κουτάκι του γούστου σου.
Μιχάλη, αυτό που είπες για τον Pre (πως είναι ακριβός κλπ.) να το πάρεις πίσω! :happy_9:
Δεν ξερω ρε παιδακι μου.
Ισως να μου εχουν μεινει παιδικα τραυματα.
Ξερεις οταν ημουν μικρος, στο σπιτι μου τρωγαμε με κληρο.
Απο τοτε μετραω το χρημα σε σουβλακια.
Ξερεις ποσα σουβλακια τρως εαν παραληψεις την ρυθμιση εντασης ?
Όταν πρωτοδιάβασα τον τίτλο, νόμιζα ότι μιλάμε για νέα θρησκεία που προσφέρει DIY μετά θάνατον ζωή, με τη Μόνικα (μία είναι η Μόνικα), τη Σαρλίζ (μία είναι η Σαρλίζ) και κάποια Μάγκυ που δεν ξέρω ποιά είναι, αλλά μάλλον είναι φίλη των άλλων δύο, οπότε θα είναι μια χαρά. :happy_5:
Μπήκα για να δω πού θα γραφτώ σε αυτή τη θρησκεία, αλλά πάλι για άσχετα ακαταλαβίστικα λέτε...
Νομιζω οτι η Μαγκυ πρεπει να ειναι η περιφημη Μαγκυ Μαιη, που εβγαλε Βeyond Local Repair τον Rod Stewart.
Αλλα τι σημασια εχει ?
Εαν διαβαζες Βρασιδας - Γιακουμης - Τιμολεων θα θυμοσουν το ξεχασμενο πηγαδι που καραδοκουσε το θυμα του ?
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
που το θυμήθηκες το πηγάδι.
Ο Θείος Μήτσος τελικά είναι διαχρονικός...
Re: Απάντηση: Re: DIY Paradise - Monica, Maggie, Charlize
Άσε που θα ψοφήσει της πείνας ...και ο λουστραδόρος! :happy_8: :happy_5:
Christos Kourmouzoglou
