The Anatek CM 0.5 Preamplifier & MB50 Monoblocks
Κώστας Φ.
Preamp £1450
Poweramp £2650 (pair)
"Anatek Acoustics (previously Anatek Audio, by the way) is a young English audio company, based in Worthing, South England. The A50 was their first product, and was very positively reviewed, not only by me. The amp is based on a patented circuit that combines Class A, non switching behaviour with high efficiency, making it run as cool as a 'normal' amp, but sounding like a real Class A one. It impressed me and I still own my A50 and use it with pleasure. I did modify it, however, as I am an incurable tweaker and the amp had some minor weaknesses. The main problem was a bad volume control, which I replaced with a very nice Dact CT2 stepped attenuator. That made a positive difference. Even better was my next tweak: replacing the input capacitors with ClarityCap SA's.
Although tweaking is fun, it is also risky and quite a bit of work. That's why I was especially interested in the MB50 power amps. They are based on the same clever circuit, but built with much higher quality components. There's a price to pay for that however, as the monoblocks are each about the same price as the A50 integrated, while delivering the same power into 8 ohm, and a bit more into 4. That does add up to twice the price of the integrated, just for the power amps.
Conclusion
I can be very short about the preamp: excellent as it sounds, I just think it is far too expensive for what it is. There are equally good passive preamps available for much less; the Django just one of them. The monoblocks, however, are a different story. They're not cheap either, but worth every penny in my opinion. They have the ability to open up a system and bring out the best in all partnering equipment. These elegant little monoblocks have a way of drawing you into the music that is highly addictive, without ever drawing attention to themselves. If you need a lot of power they obviously won't do, but if 50 Watts is enough for you then these are as fine a pair of poweramps as you are likely to find at this price. Very highly recommended."
Full Review
Pre Inside ( :happy_5: )
Power Inside
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: The Anatek CM 0.5 Preamplifier & MB50 Monoblocks
Χαχα, ένα άδειο κουτάκι, ένα ποτενσιόμετρο, ένας επιλογέας και μία μικρή πλακέτα με 2-3 ολοκληρωμένα και βύσματα RCA £1450 (δηλ. 2200€ περίπου).
Για κορόιδα ψάχνει κι αυτός...
Θέλω οπωσδήποτε φωτογραφία του κατασκευαστή για να τον ανεβάσω στο πάνθεον των λαμόγιων που ετοιμάζω.
Ημίθεος
Τί σημασία έχει; Μέχρι να στρώσουν, θα έχει βγάλει ο Ήλιος κέρατα... :happy_9:
Άσχετοι! :twisted: wall_1
Δεν είναι άδειο το κουτί του προ.
Γεμάτο είναι.
Αέρα. :shock:
Αέρα ρουφηγμένο από τις παγωμένες κορυφές του Κλοντάικ, ειδικά ιονισμένο και τοποθετημένο με ...τάξη...στο ευρύχωρο κουτί.
Αέρα hi-end! :crazy_1: :happy_5: :happy_5: :happy_5:
vlasis
Φωτογράφος!
Bρε παιδια μηπως εβγαλαν την φωτο πριν βαλουν και τα υπολοιπα μεσα?????????χιχιχιχιχι.........Αυτα ειναι στην κατηγορια ΚΑRAHIEND!!!!!!!!(Μηπως τα υπολοιπα ειναι βιδωμενα στο καπακι και οταν κουμπωσει γεμιζει το κουτακι????χαχαχαχαχα
Αυτοί είναι προκλητικοί πουλάνε άδεια κουτιά και τα προμοτάρουν κιόλας για να τα θαυμάσουμε.
Αν και φαντάζομαι κάποιοι θα τα θαυμάζουν λέγοντας χμμμ ωραίο λιτό χωρίς πολλά πολλά στον δρόμο του σήματος....
Όχι βέβαια οτι και ο τελικός είναι κάτι το αξιόλογο....
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: The Anatek CM 0.5 Preamplifier & MB50 Monoblocks
τι λιτό και πράσινα άλογα...
Αν ήθελα να κάνει κάτι σωστό στην κατεύθυνση που διάλεξε θα προσπαθούσε τουλάχιστον να ελαχιστοποιήσει την διαδρομή του σήματος...
Αλλά ούτε αυτό δεν κάνει. Στέλνει το σήμα από τον επιλογέα στο ποτενσιόμετρο που είναι στην πρόσοψη και από εκεί στην έξοδο που είναι στο πίσω μέρος. Χάθηκε ο αθεόφοβος να βάλει μία επέκταση στο ποτενσιόμετρο ώστε να το τοποθετήσει στο πίσω μέρος του κουτιού και τουλάχιστον το σήμα να έχει μικρότερη διαδρομή;
Πόσο επιπλέον θα κόστιζε η προέκταση αυτή;
Ξαναβάλτο ρε συ, μπας και καταλάβω τι είδους super τεχνολογία χρησιμοποιεί :crazy_1:
Αυτά είναι ρεεεεεεεεεεεεεεεεεεεεεεεεεεεε
Τι NASA και λαλακίες μου λέτε μετά
Gebreselassie
Μαύρος!
Άμα φωνάξεις στο εσωτερικό του, κάνει echo... :happy_9:
Που είναι ο προ... προ... προ... προ... :crazy_3:
mrkgeo
