The THD Wars Are Over? - New Op-Amps Promise High-End Sound
Κώστας Φ.
"Back in the bad old pioneer days of high fidelity, the 1960s and early 1970s, amplifier manufacturers embarked on a specifications war, claiming ever lower percentages of total harmonic distortion. But, as J. Gordon Holt presciently pointed out in the 1960s, without reference to the spectrum of the distortion harmonics, the actual percentage was not in itself a reliable indicator of an amplifier's sound quality. And as those early low-THD models had distortion spectra that were heavily biased toward the sonically objectionable fifth, seventh, and ninth harmonics, and suffered from other related ills, they tended to sound quite nasty.
Sense prevailed, and the next several generations of amplifiers may have had higher THD levels, but with distortion spectra comprising the relatively innocuous second and third harmonics, they also tended to sound sweet.
But there is no doubt in my mind, especially in a world where it is possible for recordings to offer true high-resolution sound, that amplifiers (and preamplifiers) will sound better, the less spuriae with which they contaminate the signals passing through them. Recent power amplifiers from Halcro, mbl, Simaudio Moon, and Musical Fidelity have offered THD and noise levels that are more typical of a good preamplifier, while modern preamplifiers in general are significantly quieter and more linear than those of even a decade ago. In fact, some amplifiers are so quiet and have so little distortion that they are very difficult to measure!
I feel this evolution has been in part due to the quality of the parts emanating from the chip foundries of major analog integrated-circuit manufacturers like Burr-Brown, Analog Devices, and National Semiconductor. And on Monday, July 23, National Semiconductor announced a new family of high voltage operational-amplifier (op-amp) chips that can achieve just 0.00003% THD+ noise. That means that with a full-scale signal, the combination of noise and distortion lies an extraordinary 130dB below the signal!
These new op-amps, the LME49860 dual op-amp (capable of running on ±22V voltage rails), LME49710 single op-amp, LME49720 dual op-amp, and LME49740 quad op-amp (these three all capable of running on ±17V rails) are manufactured with a process said to be capable of providing a much better match than before between the on-chip npn and pnp transistors. The noise contribution of the op-amp is specified as just 2.7 nanovolts/rootHz, the gain-bandwidth product a very high 55MHz, the slew rate ±20V/µs, and the maximum output current a high 26mA, the latter enabling the chip to drive 600 ohm loads without breaking a sweat.
Audio designers have a rule of thumb that the specifications of the individual parts used in an amplifier must be 10x better than the final specification of the component as a whole. These new op-amps from National Semiconductor will make designers' lives considerably easier, it appears.
What is more interesting to audiophiles rather than nerds like me is that National Semiconductor set up a dedicated listening room at their Santa Clara, CA headquarters to evaluate their audio chips. Under the charge of National's principal audio applications engineer Mark Brasfield, whose MSB digital products have long been audiophile favorites, the room has built-in high-, mid- and low-frequency diffusers and selected tube traps, and features Wilson WATT/Puppy 7 speakers.
I hope in the fall to be able to spend some time listening in that room."
-- John Atkinson
stereophile.com
Κώστας Φ.
Απάντηση: The THD Wars Are Over? - New Op-Amps Promise High-End Sound
"A new generation of operational amplifiers (op-amps) and power-amplifier drivers from National Semiconductor might result in a wholesale improvement in sound quality across a wide range of audio products.
Op-amps are everywhere: preamplifier linestages, CD players, digital-to-analog converters, and the front ends of power amplifiers, to name just a few product categories. Any component with analog input or output jacks probably employs several op-amps.
Many high-end product designers face the decision of whether to use op-amps in their products or to realize the circuit with discrete transistors and associated parts (resistors and capacitors). Op-amps are much smaller, cheaper, and easier to implement than discrete circuits.
An op-amp a fraction the size of a postage stamp can replace a dozen or more discrete components that would consume several square inches of circuit-board real estate. Historically, op-amps have not matched the sound quality of a well-designed discrete circuit (tube or transistor).
The highest-end products use discrete circuits exclusively; a few designers would never even consider using an op-amp. That’s largely because the op-amps available today are designed for mass-market applications where low cost is the primary consideration.
But National Semiconductor, a giant in the integrated-circuit industry (revenues of nearly $2 billion), has begun shipping a new family of premium op-amps that were designed from the ground up for optimum sonic performance.
National’s goal from the outset was to develop an entirely new breed of op-amp whose technical and sonic performance met or exceeded that of a discrete circuit. The result is the LME49xxx series of devices, which sports noise, distortion, and bandwidth specifications that are unprecedented in a monolithic (integrated circuit) audio amplifier.
For example, THD+N (total harmonic distortion plus noise) is specified at just 0.00003%, and the gain bandwidth is 55MHz.
As we all know, great specs don’t guarantee great sound quality. Surprisingly, National Semiconductor also realized this and built a dedicated listening room to evaluate the sound quality of its new performance-audio products. The listening room features a fully floating floor and complete treatment with diffusers and bass absorbers.
The electronics are custom designed, and the monoblock power amplifiers drive Wilson WATT/Puppy 7 loudspeakers. It’s unusual, to say the least, for an integrated-circuit manufacturer to perform listening evaluations on its products.
The company simultaneously announced the LME49810, a 200V IC that replaces the discrete driver stage in a power amplifier. A power amplifier’s driver stage takes in a line-level signal and amplifies it to drive the amplifier’s output transistors. The LME49810 replaces the approximately 25 components of a discrete driver stage.
The LME49xxx series of op-amps is aimed at higher-end audio-video receivers (those starting at about $3k at retail), high-end preamps, CD players, digital-to-analog converters, and power amplifiers. The devices are also starting to be used in professional products (a recording console uses hundreds of op-amps).
National Semiconductor wouldn’t specify which high-end manufacturers will be using these new op-amps, but suggested that the list reads like a Who’s Who in high-end audio. (An illustration in National Semiconductor’s literature shows a Mark Levinson product.)
The company reports that high-end designers who have tried the new op-amps are extremely enthusiastic about the new devices’ sound quality. If these new op-amps are indeed a breakthrough, listeners might enjoy a significant step up in sound quality in a variety of products."
Robert Harley's Blog - avguide.com
Πρωτον - φασινειτινγκ πραματα.
Δευτερον - διερωτωμαι πως την μετρανε αυτην την παραμορφωση. Χρειαζεται οργανο με διακριτικη ικανοτητα μια τουλαχιστον ταξη μεγεθους υψηλοτερη απο το προς μετρηση εξαρτημα.
Τριτον - να δεις που θα βρεθουν ακροατες που παλι θα παραπονουνται: Φερτε - πισω - την παραμορφωση μας
Τεταρτον - να δουμε ποιος θα πληρωσει τον λογαριασμο
Κώστας Φ.
Απάντηση: Re: The THD Wars Are Over? - New Op-Amps Promise High-End Sound
Και να δεις που δεν θα δίνουνε δωρεάν samples οι τσίπιδες (ή καλύτερα...chipιδες)... :happy_9:
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
αυτοί υπάρχουν και τώρα...
SET με 10% παραμόρφωση και 10w και το ονομάζουν High end τρομάρα τους...
Και το δικό μου στοκ είναι, αλλά στρωμένο σε τοστιέρα και λαδωμένο αρκετά, για να μην έχει μεγάλη αντίσταση, να γλιστράνε καλύτερα τα ηλεκτρόνια...
Κώστας Φ.
:respect:
Eμ...Χαλάλι όμως! Έτσι τσίμπησες 3 ολόκληρα (mW, μην παρεξηγηθούμε)! :happy_9:
ΑΠΟΣΤΟΛΟΣ ΣΕΛΒΗΣ
