Κώστας Φ.
Ο ενισχυτής στα 525 Ευρώ χωρίς συναρμολόγηση και στα 630Ε έτοιμος. Το buffer στα 200Ε.
"Burson hail from Australia, they have a strong background in high performance voltage regulators and discrete component OpAmps. More recently Burson have produced their PI-100, a 75 watts into 8 Ohms (150 watts in 4 Ohms) integrated amplifier. My interest was roused by the Burson claims about their competing with the sound of tubes but without compromised tube-amplifier loudspeaker drive capabilities.
Burson don't claim revolutionary design features but they do claim to combine sensible design practices that result in excellent sonics and technical capabilities. The PI-100 does not use coupling capacitors so the signal path is not "voiced" by potentially coloring capacitors. Great fun can be had tweaking amplifiers by substituting different coupling capacitors but the inescapable fact is that the best coupling capacitor is no coupling capacitor. The power supplies are regulated and of course they are implemented with Burson's own super-regulators. All components are discrete; there are no integrated circuits in the amplifier. There are three inputs, a pair of which feed the volume control; the third input is cleverly configured as a power amplifier input.
My conclusion is that the BursonAudio PI-100 when operated as a power amplifier outperforms the KaT34 tube amplifier whether equipped with EL34 or KT88 tubes. Bear in mind my preference for tubes and that the KaT34 cost me around double the purchase price of the Burson. You may now appreciate that my conclusion took me somewhat by surprise. Clearly BursonAudio have achieved their goals.
BursonAudio designed their Audio buffer to offer an easy load to source components and to be able to drive amplifiers with ease. Burson's discrete power supply regulators are used and the circuit is fully discrete, there being no ICs in use. Unlike the X10D the Audio Buffer delivers gain of two times (6dB). There is a power button on the front panel while the rear panel has an IEC power socket and RCA phono sockets for input/output.
Conclusion
As an integrated amplifier the PI-100 offers little in the way of frills, the focus being on sound quality. Sound quality is above what I would have expected for the price, I would simplistically describe the sound as smooth and powerful. The clever PI-100 input arrangements mean it's a doodle to turn it into a power amplifier or you can use it with the Audio Buffer in front of it. My advice would be to consider purchasing a PI-100 as the first step, you really should consider using the Audio Buffer or a quality preamplifier with the PI-100. I should add that the buffer is not expensive and is worth trying in most systems to check if its effect is beneficial.
BursonAudio have recently introduced their preamplifier that matches the PI-100, this is based on the Audio Buffer but with more gain. I fully expect this to be the perfect partner to the PI-100. Take the PI-100 to the max with a good preamplifier as you may be well rewarded."
Full Review: enjoythemusic.com
Specifications
PI-100
Type: Stereo integrated amplifier
Frequency Response 10Hz to 120kHz (+/- 3dB)
Output Power: 75 wpc @ 8 Ohms (150 wpc @ 4 Ohms)
Operation: Class AB
S/N Ratio 96dB (CD, Line)
Input Sensitivity: 240mV
Input Impedance: 20kOhms
Dimensions: 430 x 100 x 360 (WxHxD in mm)
Weight: 13 kg
Price: $840 for barebones, $1010 complete (price in Australian dollars)
Audio Buffer
Frequency Response: 0Hz to 220kHz (-3dB)
Output Noise Level: 0.015MV (nil input)
Maximum Output Voltage: 12VRMS
Maximum Input Voltage: 6VRMS
SNR: 118dB
Gain: 6dB
Net Weight: 2 kg
Dimensions: 210 x 145 x 60 (W x H x D in mm)
Price: $325 (price in Australian dollars)
