CD Player διά χειρός Tim de Paravicini...
Κώστας Φ.
Legendary hi-fi designer Tim de Paravicini of EAR (Esoteric Audio Research) has launched his first-ever CD player in over 30 years of making hi-fi.
In fact, the new acute player is EAR's first foray into the digital domain since its inception in 1976. What sets it apart from the competition is that aside from the Wolfson 24-bit/29kHz oversampling DAC used, everything else is said to be of Tim's own design.
A break from the norm
At £2,700, the new acute is not cheap, but this is no ordinary player, either. Hand-built in Britain and made to sound 'like vinyl', one thing that makes the acute unusual is the use of analogue filters instead of the more common digital variety.
Another is the valve line output stage, which is also found in EAR's pro audio equipment. Both factors will inevitably give the player vinyl-like sound and help the digital newcomer settle into EAR's exclusively analogue product portfolio.
The player also has a 5-volt output so it can be used directly with power amplifiers - the volume being adjusted by the player's front-panel control.
Tim has made the acute available in standard 17-inch widths for domestic applications and 19-inch rack-mount widths for studio installations.
tech.co.uk
LUXMAN
2700 λιρες για να παιζει σαν πικαπ .
Δεν τις δινει καποιος να παρει ενα πικαπ ;;:happy_9:
Gebreselassie
Μαύρος!
Είδες τι μ@λακίες λέει ο κόσμος για να πουλήσει? :happy_9:
Να δω από που θα μαζέψουμε τα σαγόνια του Κωσταυτιά όταν το δει. Έχει έρωτα με τον... Τιμόθεο. "happy_1"
Gebreselassie
Μαύρος!
Όχι μόνον τον πούλησε, αλλά δεν τον αγόρασα κιόλας, παρότι με τα ταπεινά ενεργά b&w κελαηδούσε. Τον (τους - μονομπλόκ ήταν) τσίμπησε ένας αγγλάκος.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: CD Player διά χειρός Tim de Paravicini...
Hand-built in Britain and made to sound 'like vinyl', one thing that makes the acute unusual is the use of analogue filters instead of the more common digital variety. http://www.tech.co.uk/home-entertai...ists-first-ever-cd-player?articleid=145749189
τι εννοεί ο ποιητής θα ακούγετε σαν βινύλιο;
θα έχει και αυτό θόρυβο επιφανείας;
θα πηδά και η βελόνα άμα λάχει;
έ,ρε θύματα που υπάρχουν στην πιάτσα...
Για να μην παρεξηγιόμαστε το μηχάνημα μπορεί αν είναι τέλειο αλλά ο Τιμόθεος στοχεύει πλέον σε θύματα. Πέρυσι κυκλοφόρησε το πρώτο του πλατό (μόνο 130 χρόνια μετά την δημιουργία του Φωνόγραφου από τον Thomas Alva Edison) και τώρα μας λέει ότι κατασκεύασε το πρώτο CD μετά από 30 χρόνια και το παρουσιάζουν ως είδηση. Ε, αυτό είναι πρόοδος. Του πήρε 100 χρόνια λιγότερο για να ασχοληθεί με τα ψηφιακά...
Η ουσία είναι ότι η EAR μέχρι στιγμής παρήγαγε μόνο ενισχυτικά, ενώ εδώ και 2 χρόνια παράγει και πηγές. Μην εκπληχθείτε λοιπόν αν του χρόνου δείτε και ηχεία.
Όσο για την τιμή £2700 είναι 4000€ και $5500. Ότι ψηφιακά φίλτρα και να βάλει κάποιος είναι πολύ ακριβό για ένα μετασκευασμένο ARCAM...
The Acute starts out as an Arcam unit, with the wonderful Wolfson DACs.
http://www.positive-feedback.com/Issue27/acute.htm
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Re: CD Player διά χειρός Tim de Paravicini...
Πες στον Κωσταυτιά να αγοράσει καλύτερα ένα ARCAM κι αυτός και ας το ψοφήσει στο πείραγμα. Θα του βγει φθηνότερα, άσε που θα έχει και κάτι να ασχολείται τις κρύες νύχτες του χειμώνα στο νησί.
Oπως και να έχει το πράμα, το ξεκούραστο άκουσμα του βινυλίου, ελάχιστες εως ανύπαρκτες ψηφιακές πηγές το καταφέρνουν.
Μπα, ο κωσταυτιάς, μετακόμισε στην συνπρωτεύουσα και τον έχουν φάει οι υποχρεώσεις...:happy_9:
jimacid
