JL Audio Factory Tour
Κώστας Φ.
Την JL Audio τη γνωρίζουν σίγουρα όσοι έχουν ασχοληθεί με το car audio... Οι περισσότεροι ίσως να μην την είχατε ακούσει αλλά φροντίσαμε εμείς να τη μάθετε γιατί, εφόσον μπήκε και στα "χωράφια" του home-cinema, αξίζει πραγματικά να τη γνωρίσετε. :happy_9:
Έχει ενδιαφέρον να δείτε πως είναι οι χώροι της JL Audio και μερικές φωτογραφίες από τη διαδικασία κατασκευής των sub της...
Ξέρω πολλούς κατασκευαστές sub και, ειδικά, ηχείων, που θα ζήλευαν τις εγκαταστάσεις τους...
"One of the biggest misconceptions about JL Audio that I want to address right off the bat is that their products are overpriced. I see people complaining about this in the forums on a weekly basis, particularly about the Gothams. Honestly, they could charge more and the consumer would still be getting a bargain. I saw firsthand the amount of work that goes into creating one of those monsters, and it is absolutely insane. Their attention to detail, production methods, and quality control are some of the best I have ever seen in any industry. More on that later though, and now onto the tour..."
Φωτογραφίες από την κατασκευή του θηρίου με το όνομα Gotham:
Something that many of us were unaware of is that the Gotham enclosure is completely made of fiberglass. You can see the layers in this shot of the amplifier mount on the back. I have never seen a more solid enclosure than this. The process that they use to make these enclosures is top secret and many people even told them it was not possible. The engineers at JL found a way though and made an absolute work of art with the Gotham enclosure. They are not exactly easy to make though and it takes more than a month just to make the enclosure.
A cross section view of one of the Gotham cutouts. That is a serious amount of fiberglass. The thin almost cloth like piece coming off of the bottom of the cutout is actually a very thick paint imbedded with copper for shielding purposes.
Το αποτέλεσμα:
Σε κάποιο σημείο αναφέρεται:
We were told a customer had already ordered four Gothams for use in a single room.
Πληροφορίες που θέλουν τους Tsarouchas Bros να αγόρασαν τα 4 αυτά Gotham για το dedicated room που ετοιμάζουν ελέγχονται ως ανακριβείς. :crazy_3:
Και μερικές ακόμη φώτο:
[/IMG]
Δείτε τις διαστάσεις του μεγαφώνου και του τοροειδή σε σχέση με την κοπέλα... :cool_11:
Αυτά τα ολίγα από εμάς...
Περισσότερες φωτογραφίες και πληροφορίες για την εταιρεία και τις εντυπώσεις από το tour θα βρείτε στο audiojunkies.com
Κώστας Φ.
Απάντηση: JL Audio Factory Tour
Bump!
Μη μου πείτε ότι βαριέστε να βλέπετε φώτο! :mrgreen:
κουφαθηκαν τα συρματα δικε μου τι cnc ηταν αυτα
οσο για το σαμπ εχω πει μια Α-Β με ενα velodyne 1812 θα ηταν οτι πρεπει
ξερεις τι δεν μου αρεσε το καλωδιο ρευματος:cool_4: "happy_1"
α ξερεις και τι αλλο
η μπριζα στον τοιχο δεν ειναι furutech η oyaide:cool_4:
jimacid
