coreAVC 1.6.0.0
Aπό το Changelog:
CoreAVC H.264 Video Codec - Version 1.6.0.0 (20071029)
- Add: Rewrite of the DirectShow wrapper for better compability
- Add: Option to override other h.264/AVC decoders (Merit change)
- Add: Rewrite of the configuration dialog to be cleaner
- Add: RGB656 and RGB555 Output format support
- Fix: Resizing problems with MediaPortal's TS Reader filter
- Fix: Small others fixes
http://www.coreavc.com/
Απάντηση: coreAVC 1.6.0.0
Λέγανε πως θα τον κάνουν πιο οικονομικό σε χρήση cpu..
Το δοκίμασε κανείς για να δει αν ισχύει;
gkontoletas
trouble in my brain
Οι τρεις εκδοσεις του CoreAVC.
Όπως καταλαβαίνετε την καλή δουλεία θα την κάνει η Enterprise Edition, η απλή έκδοση δεν υποστηρίζει ΗΑ
CoreAVC Standard Edition*
Fits perfectly if you want to playback standard H.264 videos like the ones created for the iPod, PSP or High Definition movie trailers found on Apple.com
- H.264 Baseline, Main, High profile support
- No Interlaced support
- No SMP support
- No GPU support
$7.95
CoreAVC Professional Edition
Plays everything that CoreAVC Standard Edition does but adds support for everyone that needs support for SAT TV, IPTV, DVB. For the highend video zealots CoreAVC Professional Edition even supports SMP processors like the Intel® CoreTM 2 Duo, allowing for even fast multitasking while playing back high-definition CoreAVC H.264 video.
- Interlaced support (PAFF and MBAFF)
- SMP (multi-core CPU) support (limit 4)
- GPU support (to be added**)
$14.95
CoreAVC Enterprise Edition* COMING SOON!
Plays everything that CoreAVC Standard Edition does but adds support for windows video systems that need support for SAT TV, IPTV, DVB. For the highend video zealots CoreAVC Professional Edition even supports SMP processors like the Intel® CoreTM 2 Duo, allowing for even fast multitasking while playing back high-definition CoreAVC H.264 video.
- H.264 Baseline, Main, Extended, High, High10, 4:2:2, 4:4:4 support
- Interlaced support (full)
- SMP support
- GPU support
Εnterprize δεν υπάρχει ακόμα...
Και στην pro είναι στα μελλοντικά σχέδια...
Πάντως αφού το έχουν ανακοινώσει, και στην προ θα δώσουν την ικανότητα για ΗΑ...
hatzopou
